NWHov reacted to a post in a topic: I'm north of Line A and just made a big mistake!
WRYZ926 replied to NWHov's topic in FCC Rules Discussion
Pretty much any and all federal regulations were written by lawyers for lawyers. None are easy for the average person to understand. And as we see with FCC regulations and NFA/GCA regulations, some portions can and do conflict with each other. I don't blame you for wanting clarification if the line A issue might affect you or not. I also would not take what is posted on any forum as 100% correct without first verifying the information. I dealt with enough conflicting and/or confusing regulations back when I had my FFL. And it has not gotten any easier when dealing with the NFA and GCA. -
You might want to look at the Diamond SRH320A. Not exactly cheap. SRH320A Triband HT Antenna.pdf
DRKSKY joined the community
NWHov replied to NWHov's topic in FCC Rules Discussion
Right! I just don't like basing my understanding of the rules from a consensus of experienced users saying the rule is not longer on their license. If I was to go this alone (without this forum) how would I come to understand all this? marcspaz did a great job explaining in above post. If § 95.309 wasn't there, I would be satisfied with concluding Line A is not a GMRS thing anymore, but it's there and a GMRS user should not have to research treaties and international agreements to get yet another indirect answer to a poorly written rule. -
ISN radios are not designed for voice, nor emergency operations. They are normally used for OT device control and monitoring. Usually the power is low, the ranges isn't very far per watt, and in general are typically programmed for some specific industry business. What are you trying to accomplish?
WQXE568 joined the community
I just want to get comments on these radios if they're dependable during emergency use
WRUU653 reacted to a post in a topic: POTA Question
WRYK294 joined the community
SteveShannon reacted to a post in a topic: POTA Question
WRYZ926 reacted to a post in a topic: POTA Question
TNFrank reacted to a post in a topic: POTA Question
Awesome link, thanks. Looks like LMR-400 would work well. At 220MHz and 20ft@10W I'd only get a 26% power loss so I'd still be putting out over 7W of power.
You will not see any loss or gain on 2m using 25 feet of RG8X. You will see a loss of 1-2 watts ERP (output at the antenna) using 25 feet of RG58. You would be okay with either coax as long as you stay at 35 feet or less. This was figured using an antenna with only 1 dB of gain. The more gain the antenna has the higher the ERP will be. The https://kv5r.com/ham-radio/coax-loss-calculator/ is an excellent source to figure out line loss with the different types of coax. Using any type of portable J pole or similar antenna up high will help extend your range when using a hand held radio. I have built a 2m j pole using faraday cloth and getting it up at 20-25 feet above the ground made a vast improvement. I can get into the local 2m repeater that's 22.5 miles away with a 5 watt HT but there is some noise on my transmission. I was told that I sounded like I was on my base radio when using the same HT connected to the faraday j pole.
marcspaz reacted to a post in a topic: I'm north of Line A and just made a big mistake!
Straight forward and/or simple to understand along with the federal government in the same sentence makes as much sense as military and intelligence used in the same sentence. This topic comes up regularly and the answers are always the same each time. I know my original official copy of my GMRS license issued in October 2023 had the line A restriction on it while a newer copy downloaded a few months ago does not have the line a restriction. I have driven myself batty trying to read, understand, and explain NFA and GCA regulations to people. I will let other members here explain the FCC regulations. PS: NFA and GCA makes as much sense as FCC regs do. -
Somehow posted the PPOTA reply twice.
The best is still John Kruk of Yaesu's PPOTA. Porta Potties OTA. He has cups and T-Shirts etc. that he hands out to in person visitors at Ham Fests.
WSHP964 joined the community
WSJJ659 joined the community
LeoG started following How Do you Get Permission
Being inside a bowl is no place for a repeater. My house is near the river so I'm pretty low down. My shop is in one of the higher parts of the town which believe me isn't high at all. About 100' higher than my house. And the coverage is nothing to talk about. Keeps me in touch with the wife within town mostly. It will be going higher, but still it's not 500+ feet up which is what you need to start getting decent coverage in my area. To many hills and valleys along with loads of trees full of leaves to suck up the signal.
This ^^^ I would add also that a lot of people assume Amazon will be the cheapest but many things like radios, cable, antennas, and other things you’ll find are less from places like DX Engineering, Ham Radio Outlet, Gigaparts… it’s definitely worth shopping around and comparing from reputable places. Make sure you factor shipping cost though but sometimes you’ll find what you want is cheaper at one place over two or three others for whatever reason and it doesn’t always seem to be the same place that’s cheaper… just my two cents, that I saved lol.
WRCL209 joined the community
It works!
Personally I wouldn’t use either one of those. I would buy a better known brand such as ABR, M&P, DX Engineering, Times-Microwave, Belden, etc. The way to make certain you’re getting a quality product is to buy from a vendor you trust to provide quality products. If you buy an unknown cable from an unknown vendor on Amazon you’re completely responsible for assessing the quality.
https://www.amazon.com/MOOKEERF-KMR400-PL259-Male-Cable/dp/B094D3DFG3 There's also a KMR400 cable too.
LOL, test questions, yep, I know. A lot of stuff I learned in Tech School at DeVry is coming in handy now. Also, that's one reason I'm sticking at 2M, it's the lowest my radio will do and there's quite a few repeaters here for 2M. I'll need to see just how far from the tripod I'll actually be and see how close I can cut the distance.
Thanks guys, I try the suggestions and follow back
Losses through any coax go up as the frequency goes up. RG-58 is terrible for UHF. RG8x is better than RG58 but still poor compared to something like LMR400. Each person must calculate what the actual losses will be and decide whether they can afford that amount of losses. What’s worse, the losses are expressed in decibels which can be confusing until you become familiar. A loss of 3 decibels means you lost 50%. A loss of 6 decibels means you lost 75%. Every coax company has charts that show us how much loss they have at a particular frequency, usually for 100 feet or 100 meters. Be careful not to compare the two. A meter is more than three feet. Losses increase with length as well but that’s a linear relationship: twice as long equals twice the losses if the frequency is the same. Most of us find a calculator online to calculate the losses at the exact frequency and length of the type of cable you’re looking at. Just google “coax loss calculator“ and you’ll find one. This is the most common one: https://kv5r.com/ham-radio/coax-loss-calculator/
WRXS344 joined the community
I am happy with the Nagoya 320A I have. Works well on all three bands
I, unfortunately or otherwise, do not have a castle atop a golden hillside. It's a split level in a depression, surrounded by foothills. I can hit their repeater to get over the hills but within the bowl, my friends and I are trying to put something up to link us all without having to simplex around the bowl, relaying messages. We wouldn't and couldn't compete with this other local group. Our thought is, though, if we can take our traffic off the mountaintop and keep it in the bowl, it's a win-win for everyone. We don't have to pay and they have more bandwidth to talk about smoking meat, going to Wally World, eating at Sonics, and talking about the good old days of CB and sending postcards. Or whatever it is they talk about. But your point is well made about the rent/lease of a repeater. I had no idea it could be that expensive. Dues, at that point, make sense. Like I said before, go easy on me. I'm new.
Getting their repeater up on the tower was probably a few thousand monies to get it installed and probably several hundred to $1k - $2k per month, every month, depending on the location. That's why they charge for people to use the "free public service" which is neither free nor a public service. When I put up MY repeater, open for everyone to use for free, the cost was around $1k .. $500 for the repeater (used Vertex 7000), the coax, mast/hardware, etc and paying a professional to climb on my dangerously sloped 3-story castle-roof to install it all.. (I got the antenna for free!).. But my advantage is that I live atop a golden hillside overlooking the slums below which is almost as good of a location as the very expensive towers very near me.. not quite, but close enough, so i have decent coverage. Sticking your pole in the ground with your RT97L would work, but would not have near the reach as their tower on the mountain.. unless you are like me and have a castle atop a golden hillside.
I'm currently looking into it, actually. A few of us, actually. And we're looking at the Retevis RT97L to do the job. The problem is that they have the high ground; literally on top of a mountain on a tower. I've been around long enough to know that you're being sarcastic, but explain it to me like I'm five years old. What are the costs associated with maintaining a repeater? I know you did it for awhile. Am I naive? $600 for the RT97L, another grand, say, for a good antenna and some coax. Mount 'er on a pole and voila? Fix stuff as it breaks? I assume, for some, there might be a lease or rental for the space on a tower? That wouldn't be the case for me as a member in our group has space for it on his property and is willing to host it. Tell me, Queen of GMRS, what am I missing?
Forgive me, I misspoke. You are, as I presume is usually the case, correct. To the last part of your post, I think the issue that most of the people local to this group have is that the group doesn't publish any data regarding their intake and expenses. I'm too green to know if that's a requirement or not, but they hold Thursday night nets and do them live on YouTube and their production studio looks like it would put an NFL TV trailer to shame. People wonder where all that money is coming from. Not to mention one of their senior member started an online radio sales company and advertises for it over the net every week. It's...odd, to say the least.
This is what I've been using trying to figure out how much loss I'm going to deal with running a line out to my backyard: KV5R Coax Loss Calculator 144mhz with 25' of RG8X is probably going to be about a ~21% loss. 450mhz drops down to 38% loss. I actually don't know of anything short of like LMR-400 that doesn't have high loss with VHF/UHF, but now you're getting into stuff that's almost three bucks a foot. Edit: I have no idea where my mag mount base went, but I'm pretty sure it uses a 16' RG8X line and even with the loss, like 4W at 450mhz out on my porch is WAY better than 5W in this RF dead spot I've created in my office with all the monitors, computers, and metal peg boards. You may not notice the loss with a short run.
You probably should use this coax from Gigaparts: ABR400-Ultra Flex 18ft RG8 Coax Jumper w/ PL259 Ends 25400F-PL-18 $72.95
