^Come to my place sometime and show me how your HT will go 50 miles. I'll buy the beer.
wow
marcspaz reacted to an answer to a question: Daiwa CN901V SWR/PWR Meter for GMRS
WRYZ926 replied to BobDiamond's question in Technical Discussion
WOW! someone's off their meds again. @marcspaz gave good advice. -
WRTC928 reacted to an answer to a question: Daiwa CN901V SWR/PWR Meter for GMRS
I used GMRS radios when I moved from Alaska to Oklahoma 3 years ago. There were 4 of us with an RV and a pickup truck pulling a trailer. There are long stretches of the Alaska Highway where cell service is nonexistent. It was orders of magnitude better than pulling over and talking in person when we needed to pass on information.
WRUE951 reacted to an answer to a question: Daiwa CN901V SWR/PWR Meter for GMRS
BobDiamond replied to BobDiamond's question in Technical Discussion
Thanks for your reply. Turns out the jumper cable has an intermittent short. And I bought that cable custom made to length using Times low loss cable from a company called ShowMeCables.com. So that will be returned to them. I located another jumper cable in my "junk box" of radio stuff and all is working perfectly now. -
WSIK532 joined the community
BobDiamond reacted to an answer to a question: Daiwa CN901V SWR/PWR Meter for GMRS
brndnmrrs joined the community
kirk5056 reacted to a post in a topic: Moving experience
WSIH254 joined the community
recondo35 joined the community
WSIJ461 reacted to a post in a topic: You just got your GMRS license, now you want your own repeater?
WSIJ461 joined the community
marcspaz replied to BobDiamond's question in Technical Discussion
Make sure the meter is on and on the 200w scale. (Yes, it has an off button) Also be very sure you did not mix up the antenna connection and Transmit connection. If you get them backwards, the meter doesn't move. As mentioned above, make sure it's set to AVG and not PEP. If the meter is set correctly, the next thing I would question is the coax between the radio and meter having a short. -
WRUE951 replied to BobDiamond's question in Technical Discussion
couple years ago someone did a full write-up on that SWR/PWR meter here. Do a search see if you can find... And even though i have Socalgmrs blocked he message squeaked through,, perhaps because I'm on my Windows Box. Just block the idiot and don't pay any attention to Negative Nancy.. That's what we call him -
@Socalgmrs why are you still here? -
Update: This is on every Thursday at 1900 hrs. 700 is the strongest local repeater -- good for ~35 miles.
Socalgmrs replied to BobDiamond's question in Technical Discussion
Woxoun kg-1000,Daiwa CN-901V…… You forgot to name drop your coax…. Or give a model number to the diamond antenna glad I don’t worry about swr. I just buy good antennas and run it. I’ve got better things to do then spend time watching my swr meter. But any one that spends $400 on a radio and another $250 on an swr meter and who knows what on an antenna has issues anyway. I’d bet cheap coax and junky antenna has something to do with it. for $650 a can set up 3 50w base stations that radiate over 550w with 200mile range. And all with no swr meter or silly questions to a stranger group of man-queen worshipers. -
the Daiwa is kind of a funky meter, Don't use the P.E.P. and try. -
genericradio joined the community
My wife was super impressed. She might be ready for an amateur license some day. We had an interesting announcement about the state patrol. I thanked some people way ahead of me, but there was no way for me to exceed the limit. I did tell me to look at a mountain range off to the left and the view was amazing. Nice people along the way.
Hmm, I didn't know that those anonymous people types do that in basements. We don't have basements in Cactusland. That must be what they do in Tornado Land.
Bogieboy01 reacted to a post in a topic: Moving experience
Bogieboy01 reacted to a post in a topic: Deregulation; here’s your opportunity to make a difference!
WSAM454 replied to BobDiamond's question in Technical Discussion
Are you sure the jumper cable to the meter isgood? Can you use a double female SO-239 in place of the meter to see if things return to normal. If they do, then something is wrong with the meter. If not, then possibly a bad jumper cable. -
I have a Wouxun KG1000G+ with power supply that I am using as a GMRS base station with a Comet vertical on the roof of my house. Transceiver connected direct to the antenna works perfectly. I just put a Daiwa CN-901V SWR/PWR meter in line and the meter is not showing any output power and it seems to be attenuating both the receive and transmit signal significantly. The meter is brand new, out of the box. I checked the obvious, radio to meter input, meter output to antenna, and 13.8VDC applied to the meter. But with the radio set to 50 watts output the Daiwa CN-901V shows nothing. What could be wrong aside from a defective brand-new meter?
WRYZ926 replied to SteveShannon's topic in FCC Rules Discussion
I think that the nursing home took the hint and changed to a different channel, I haven't heard them on channel 17 for about a week now. I decided to talk to another guy on channel 17 one day and we are both using 50 watt radios. I'm sure we were blasting their FRS radios. -
We have been happy with the RC-210 that is currently controlling our 2m repeater. One of the two controllers will be getting a temperature sensor so we get warnings when the shed gets too hot or too cold. We found out that the Motorola Quantar repeaters do not like the heat. The current controller also monitors our battery backup system and announces when everything is running on battery backup.
WRUU653 replied to SteveShannon's topic in FCC Rules Discussion
Think of all the fun that could be had if someone handed out some cheap FRS radios to the patients at the nursing home… -
Exactly the way I'ding is suppose to be. BTW,, the RC-210 is a nice versatile controller. I saw a 3D case on Makers World for this board.
I don't care for any repeater doing that. We are going to use an Arcom RC-210 controller for our GMRS and 70cm repeaters. We are going to set the controller to ID every 15 minutes but ONLY when there is actually people using the repeater. I just finished assembling the RC-210 board and am waiting on the case and real time clock. Then it will be time to program it. And we will definitely have the repeater ID since it is open to the public.
We used them recently with three RVs on a road trip. Sure beats trying to set up a conference call or a group text.
Hey, how'd you know I'm in my underwear?
WRTM417 joined the community
Personally, i think the guy's id'ing every 15 mins on the hour is no different than a dog pissing on tires.
You mean "radio dorks in thier underwear in thier parents basement"
