WSBM362 joined the community
I was gonna replace it with a external speaker and wire it straight to the wires from the internal speaker and remove the internal speaker so it would help ventilate the radio, the tiny fan can't pull cool air in if it has no vents to allow that, it has no vent holes anywhere on it. Preventive maintenance .
MyGMRS and repeater book are setup so that only the repeater owner or authorized representative are suppose to be able to add, edit, or delete repeaters from the lists. I know with how MYGMRS is setup, if you list someone else's repeater, you will be the one getting any and all requests for access. Both websites require you to acknowledge that you the repeater owner or an authorized representative when you list any repeaters. And yes we all know that anyone can scan and get the tones easily. That still doesn't make it right for someone other than the repeater owner or authorized representative to list said repeater. I know that I would nt care for anyone else listing my repeater on MYGMRS. The reason is that they would start getting all requests. Yes the repeater is open but it is still nice when people do take the time to request permission to use it. It's common courtesy.
Yes I have a 50watt dummy load. I just now downloaded new firmware, and downloaded the Tidradio CPS off their website which I created an account to use. It wrote to the radio and I updated the firmware. Still not showing any wattage on the meter. I I programmed with a baofeng kenwood cable, a mirkit brand ftdi kenwood cable still no joy. I give up.
My personal opinion is that if there is an open repeater which does not do anything to hide PL, e.g. input equals output, it should be listed regardless of the owner's desire. It is an OPEN repeater. Prohibiting anyone but owner to list OPEN repeater makes myGMRS site usability very questionable to say the least. I came here for the sole purpose to see if several really OPEN, input equals output, repeaters I can hear around me are listed on the site and they are not. I believe that there should be a way for anyone to post OPEN repeater information and give all users ability to confirm its status if they can access it.
WRTB874 changed their profile photo
Also double check to see what ohms the original speaker is and match it with the new speaker. Most are either 4 ohms or 8 ohms.
GrouserPad reacted to an answer to a question: Two TDH3’s no output wattage !
I just ordered a Retevis RA87, anyone run one?
dosw replied to SvenMarbles's topic in General Discussion
SWR is the Standing Wave Ratio, and is a function of your antenna, cabling, connectors, antenna mount, ground plane effectiveness, and environment. As power is reflected back into the radio rather than efficiently disappating it in the form of RF output, the reflection back into your radio is the standing wave. This is a bit of an oversimplification, but accurate enough to explain that if you see a higher SWR your radio is usually the last place to look, the last thing to blame. And into a dummy load -- it would be a terrible dummy load if it were reflecting power back into the radio. Their purpose is to absorb power with the proper ohm load to avoid elevated SWR that could damage the radio. Anyway, the RA87 has been very reliable for me over the past year or so. Unfortunately it fits in great with the utilitarian interior of my old Bronco, but not as well with the cushy interior of my newer F150. I'll probably go with something with a remote faceplate if I can figure out where i want to mount it, and how to route the antenna cable in this newer truck. In the old Bronco a few visible wires and a big radio under the dash just ads character. -
The wattage refers to the power the speaker can handle. What tou need is to match the size and mounting.
If a receiver has a 2 watt audio output to the original speaker and it goes bad can it be replaced with a 5 watt speaker without hurting anything in the radio itself? Thanks, WSEK643
CoffeeTime replied to SvenMarbles's topic in General Discussion
My RA87 in the truck as been great performer for months now. Many of the issues I faced early on was from me learning the radio. If things go sideways now( from me playing with features) I simply reload the code plug and all is right again. Not having a cooling fan is a good thing in my dusty truck. -
SteveShannon reacted to a post in a topic: Oh boy, a new toy for me...
CoffeeTime reacted to a post in a topic: I just ordered a Retevis RA87, anyone run one?
CoffeeTime reacted to a post in a topic: Just Funny as Hell
Did you have either an antenna or dummy load on the power meter? If not, that could "in theory" fry them...."some people" say it will, and some say it wont....
WRNU354 reacted to a post in a topic: Oh boy, a new toy for me...
WROF841 joined the community
It will be paired with my current Comet 712EFC, so 9.8dBi gain. 60 feet of M&P Hyperflex 13 and 24 feet of Heliax 1/2" hardline past the lightning arrestor. Eventually I'll get that same antenna on my repeater. I've only had it for a year now.
Compliment it with a high gain antenna 9,10,10 db gain and good coax and that 50w will radiate over 500watts. Should cut through cover very well.
WSIB397 joined the community
WRXB215 reacted to a post in a topic: Just passed my General class test on Saturday!!!!
WRYZ926 reacted to a post in a topic: Oh boy, a new toy for me...
WRXB215 reacted to a post in a topic: Cancel a repeater request
WSGC728 started following I just ordered a Retevis RA87, anyone run one?
WSGC728 replied to SvenMarbles's topic in General Discussion
I have had good luck with my Retevis RA87. According to my SWR meter, it pulls a steady 1.0-1.1 SWR reading & anywhere between 40-45 watts of power with a Larson magnetic mount antenna. It also pulls the same SWR & wattage on a dummy load. -
WSGC728 joined the community
SteveShannon replied to GrouserPad's question in Technical Discussion
It can be a frustrating thing to not have a clear cause and effect. It certainly could simply be group of failures caused by a bad batch of components. -
I haven't had one go bad yet. Only be delivered DOA.
LeoG started following Oh boy, a new toy for me...
Picked up the KG 1000G Plus to use as my base station to complement the repeater I have at my shop. The repeater makes it fine into the house but sometimes the house has a hard time getting through the trees to the shop repeater. Going from 20 to 50 watts is only a bit more than 3dB, but it seems to work from the repeater to the house. I had already setup the CPS with my channels and only needed to read the radio and write back. The CPS doesn't cover the A,B,C,D buttons so I'll have to do those manually. Like the power button in that you don't need a long press to turn it on. People complain about the screen brightness. Not exactly screaming bright, but it's in a lighted shop and not in a dark vehicle. Since I already have a KG XS20G I'm already pretty familiar in the way it should work. Wife doesn't know yet. I'll probably install it after she goes to bed and she'll see the new radio when she gets up. LOL. Hoping it might get rid of some of the off center DMR that I have in my area. The XS20G lets it right through with the SOC receiver. Hoping the Super Het might limit or eliminate it.
Well that’s the interesting thing Steve, is I’m not exactly sure when these radios went kaput…. They worked fine for a couple weeks after my initial chirp setup. I was happy with them. Then I went in and did a few repeater adjustments…and added a few other frequencies to monitor and then I picked them up one day and noticed they wouldn’t key repeaters. So I put them on my surecom uhf meter and it shows 0.00 watts and now here I am
WSIE310 joined the community
WSGS985 joined the community
https://www.facebook.com/reel/563050153490031
Nor I.
I did test this with my Mac desktop and had the same results. I also put in a report to Rich.
WSBX730 joined the community
If I bring up one of the repeaters in list view with stale/offline enabled and click on the repeater name, it will bring up the repeater info and a map view of the repeater location for what it's worth.
Here’s what Gil @WRUU653 found: “Yeah, there is something glitching, I found if I turn on both stale and offline tabs all the repeaters disappear from the map. But if I click on a repeater that is on the map and then click on that repeaters info, then go back and select stale and offline they show up. A ridiculous work around. I had wondered if this was because of my security settings as I hadn’t seen anyone complain about it. I’m using IOS on an iPad. I’ll go put on some coffee and see if it behaves the same on my Mac desktop. I’ll let you know what I find and I guess we should let Rich know.”
They can be made to appear in the map view by going to the list view first but there’s either a bug or a poor design that causes problems if you start in map view. I’ll dig up the complaint I turned in. Also, Gil I think found a workaround. Here is my complaint to Rich, which matches what you said:
And also there is the fact that dogs are shit producers.
<sarcasm>Not really </sarcasm >
