  2. This is 100% correct. EVERY new licensee is issued the next sequential call sign for that zone. If you want a vanity call, you have to first get your license, then apply to change. What you were told is not fully correct. Yes, they stopped sequentially issuing call signs according to license grade years ago, but there have not been dedicated call signs "per license level" for many years. This means there is no such thing as an 'Advanced' or 'Novice' call sign format anymore. The current format for a new licensee, regardless of grade, is xxXxxx. There are certain call sign formats you need to be AE to apply for, but none of those are new calls and are recycled from dead people and people who failed to renew for 2 years, thus giving up their right to retain their call. Even at that, xXx, xXxx and xxXxx calls are very hard to find, in the sense that anything decent (easy to key, easy to say, cool, unique, etc.) is snapped up if/when it ever becomes available. There is also a preference system, in which you would get first dibs on your deceased father's call sign for example.
  3. Ok I see now, it was the PRIORITY SCAN function that was causing me an intermittent receive cutout every 5 seconds or so when the radio would scan in the background for priority channel activity. This scan looks for whatever channel you select for the priority channel.
  4. i would pay more attention to the ohm of the speaker making to to match that more than the power rating..
  5. Yesterday
  6. I neglected to mention that you have to check the box on the form, but yes, you're right. If you go from unlicensed to Amateur Extra though (assuming you pass the Technician and General exams at the same time), they do issue you one sequentially right out of the pool. I've heard that supposedly there are some regions where they have run out of AE format callsigns and new license grantees going from unlicensed to Amateur Extra are being issued Advanced format callsigns, but I cannot confirm.
  7. Doesn't look like you can not have a priority channel. There doesn't seem to be an off choice. Photoshopped the end of the list to the right.
  8. Great choice! Congrats!
  9. Nice choice on radio/coax/antenna. I really like those radios, only quirk is be aware if you set a background priority channel. Two of my 1000+ radios exhibited a faulty acting receive when a priority channel was set. It seemed to create a cutout every so often. Also, I've been using the latest version of Chirp to program mine and it's been working awesome. The CPS software is good to but for some reason my computer settings make the cps text awful to read so everytime i use the cps I had to fiddle with the gridfont in the settings tab to make the text look decent.
  10. I was gonna replace it with a external speaker and wire it straight to the wires from the internal speaker and remove the internal speaker so it would help ventilate the radio, the tiny fan can't pull cool air in if it has no vents to allow that, it has no vent holes anywhere on it. Preventive maintenance .
  11. MyGMRS and repeater book are setup so that only the repeater owner or authorized representative are suppose to be able to add, edit, or delete repeaters from the lists. I know with how MYGMRS is setup, if you list someone else's repeater, you will be the one getting any and all requests for access. Both websites require you to acknowledge that you the repeater owner or an authorized representative when you list any repeaters. And yes we all know that anyone can scan and get the tones easily. That still doesn't make it right for someone other than the repeater owner or authorized representative to list said repeater. I know that I would nt care for anyone else listing my repeater on MYGMRS. The reason is that they would start getting all requests. Yes the repeater is open but it is still nice when people do take the time to request permission to use it. It's common courtesy.
  12. Yes I have a 50watt dummy load. I just now downloaded new firmware, and downloaded the Tidradio CPS off their website which I created an account to use. It wrote to the radio and I updated the firmware. Still not showing any wattage on the meter. I I programmed with a baofeng kenwood cable, a mirkit brand ftdi kenwood cable still no joy. I give up.
  13. My personal opinion is that if there is an open repeater which does not do anything to hide PL, e.g. input equals output, it should be listed regardless of the owner's desire. It is an OPEN repeater. Prohibiting anyone but owner to list OPEN repeater makes myGMRS site usability very questionable to say the least. I came here for the sole purpose to see if several really OPEN, input equals output, repeaters I can hear around me are listed on the site and they are not. I believe that there should be a way for anyone to post OPEN repeater information and give all users ability to confirm its status if they can access it.
  14. Also double check to see what ohms the original speaker is and match it with the new speaker. Most are either 4 ohms or 8 ohms.
  15. SWR is the Standing Wave Ratio, and is a function of your antenna, cabling, connectors, antenna mount, ground plane effectiveness, and environment. As power is reflected back into the radio rather than efficiently disappating it in the form of RF output, the reflection back into your radio is the standing wave. This is a bit of an oversimplification, but accurate enough to explain that if you see a higher SWR your radio is usually the last place to look, the last thing to blame. And into a dummy load -- it would be a terrible dummy load if it were reflecting power back into the radio. Their purpose is to absorb power with the proper ohm load to avoid elevated SWR that could damage the radio. Anyway, the RA87 has been very reliable for me over the past year or so. Unfortunately it fits in great with the utilitarian interior of my old Bronco, but not as well with the cushy interior of my newer F150. I'll probably go with something with a remote faceplate if I can figure out where i want to mount it, and how to route the antenna cable in this newer truck. In the old Bronco a few visible wires and a big radio under the dash just ads character.
  16. The wattage refers to the power the speaker can handle. What tou need is to match the size and mounting.
  17. If a receiver has a 2 watt audio output to the original speaker and it goes bad can it be replaced with a 5 watt speaker without hurting anything in the radio itself? Thanks, WSEK643
  18. My RA87 in the truck as been great performer for months now. Many of the issues I faced early on was from me learning the radio. If things go sideways now( from me playing with features) I simply reload the code plug and all is right again. Not having a cooling fan is a good thing in my dusty truck.
  19. Did you have either an antenna or dummy load on the power meter? If not, that could "in theory" fry them...."some people" say it will, and some say it wont....
  20. It will be paired with my current Comet 712EFC, so 9.8dBi gain. 60 feet of M&P Hyperflex 13 and 24 feet of Heliax 1/2" hardline past the lightning arrestor. Eventually I'll get that same antenna on my repeater. I've only had it for a year now.
  21. Compliment it with a high gain antenna 9,10,10 db gain and good coax and that 50w will radiate over 500watts. Should cut through cover very well.
  22. I have had good luck with my Retevis RA87. According to my SWR meter, it pulls a steady 1.0-1.1 SWR reading & anywhere between 40-45 watts of power with a Larson magnetic mount antenna. It also pulls the same SWR & wattage on a dummy load.
  23. It can be a frustrating thing to not have a clear cause and effect. It certainly could simply be group of failures caused by a bad batch of components.
  24. I haven't had one go bad yet. Only be delivered DOA.
  25. Picked up the KG 1000G Plus to use as my base station to complement the repeater I have at my shop. The repeater makes it fine into the house but sometimes the house has a hard time getting through the trees to the shop repeater. Going from 20 to 50 watts is only a bit more than 3dB, but it seems to work from the repeater to the house. I had already setup the CPS with my channels and only needed to read the radio and write back. The CPS doesn't cover the A,B,C,D buttons so I'll have to do those manually. Like the power button in that you don't need a long press to turn it on. People complain about the screen brightness. Not exactly screaming bright, but it's in a lighted shop and not in a dark vehicle. Since I already have a KG XS20G I'm already pretty familiar in the way it should work. Wife doesn't know yet. I'll probably install it after she goes to bed and she'll see the new radio when she gets up. LOL. Hoping it might get rid of some of the off center DMR that I have in my area. The XS20G lets it right through with the SOC receiver. Hoping the Super Het might limit or eliminate it.
  26. Well that’s the interesting thing Steve, is I’m not exactly sure when these radios went kaput…. They worked fine for a couple weeks after my initial chirp setup. I was happy with them. Then I went in and did a few repeater adjustments…and added a few other frequencies to monitor and then I picked them up one day and noticed they wouldn’t key repeaters. So I put them on my surecom uhf meter and it shows 0.00 watts and now here I am
  27. https://www.facebook.com/reel/563050153490031
