SteveShannon replied to JohnDeere7920's question in Technical Discussion
Honestly if you’re going to do anything that’s more permanent than peel and stick you should really just punch a hole and install a through-hole NMO mount like @gortex2 showed. -
You have probably seen this but for what it's worth, I passed this info around my contacts https://radiofreeq.wordpress.com/2013/06/29/shtf-survivalist-radio-frequency-list/
WRUW263 joined the community
WSEL330 replied to JohnDeere7920's question in Technical Discussion
If we are going that far....braze a plate down. -
SteveShannon reacted to a post in a topic: Help identifying this tone when using GMRS Repeater
That is the sound of telemetry data, while listening to it with an analog receiver. Its very common to hear on FRS/GMRS channels in rural areas where farming is mostly still family run and they don't have big budgets for automated monitoring and control systems.
SteveGibbs reacted to a post in a topic: A Repeater Code Primer:
WRTC928 reacted to an answer to a question: Mounting NMO antenna to aluminum truck cab?
LeoG started following Help identifying this tone when using GMRS Repeater
Sounds like you are trying to connect to AOL by phone.
WSEL330 reacted to a post in a topic: Newish here
It was a very strong signal and discernible from the predicted ranges of the repeater even when voice didn't work. We tested the radios with straight gmrs (not using the repeater) and the tone never showed up. The strange sound appeared with Privacy Tones On or Off. As far as the SWR, he said it was "off the charts" on the Slim Jim Antenna and when he tested his fiberglass antenna back at the farm it read "8" However, the SWR was not for UHF so those results should probably be ignored. So far he's not been able to reproduce the tone back at the farm. Same repeater, same portable battery, same coax, and slim jim Antenna. So far though, I appreciate the help.
BoxCar reacted to an answer to a question: Mounting NMO antenna to aluminum truck cab?
BoxCar reacted to a post in a topic: Newish here
RoadApple replied to JohnDeere7920's question in Technical Discussion
IDK, I have a few "POS Pandaland" antennas, and they seem ok... (at least for my purposes). At 460Mhz a 1/4 wave whip on an NMO mount is electrically very simple (no loading coils, etc.). It's not that the SWR doesn't change from the resonate apex of the tuned bell curve, it is a matter of how much it changes and if that change falls outside of a safe operating range or results in a humanly noticeable performance degradation. I'm no metallurgist, and perhaps there is much I don't understand on this topic, but at the relatively low <=50-watt power level used in GMRS, it would seem that a minor materials differences between a Pandaland vs other name brand whip antenna would have a negligible impact and be functionally imperceptible in most real-world scenarios. Anyway, that has been my experience. All I'm saying is that sometimes it is ok to give a Panda a chance!! -
jbond joined the community
That does not sound right. Was the signal of the noise strong, like it was coming from the repeater, or was it weak like it was something far away? ..and, poor SWR would have nothing to do with this noise, but what do you mean by "strange results"? What was the SWR reading? and what do you mean by "more specific meter"?
Yup, I noticed that, so I registered and trying again with a direct upload and a link from G drive. Offending audio in question linked and attached here: https://drive.google.com/file/d/1cuIFnbH_eVS-tK4AAoTZZDrSx75JxyJJ/view?usp=drive_link Between the two it should be ok. My friend did hook the antenna system up to an SWR and was getting strange results. To the point where he's ordering a more specific meter. Sep 7 at 11-37.m4a
Perhaps an iron or aluminum bearing epoxy would negate that issue. I don’t know of any commercial epoxies that contain aluminum powder, but JBWeld has iron powder in it. -
The BTech UV-5x3 is a tri-band Ham Radio that also supports the 220 MHz band and has some nice programming features over my older Baofeng UV-5Rx3. I do not know if the 5x3 supports transmission on GMRS.
Thank you Gregg and Lscott. Very helpful. The GM-15 is also currently on sale in the preferred colorway. much appreciated.
Lscott replied to JohnDeere7920's question in Technical Discussion
Depends on how much you use. The magnet mount depends on the capacitive coupling from the base to the sheet metal for the ground plane connection. Adding in a layer of glue increases the thickness and thus reducing the coupling. This could mess up the match. -
That’s great. And when I spoke about participating I certainly didn’t mean contests and things like that, but rather engaging with leadership of the ARRL at the local level and higher to help them know how best to serve us. Contests might be a lot of fun (I haven’t participated in contests either) also but I consider the work they do to inform us of legislation and intercede with our government representatives to be their most important work.
Yeah, same with the bug zapper. They end up in the collection tray on the bottom sooner or later, but they seem they just can't help themselves. After a while of spending money on CCR's many people end up buying a much higher price radio. I like to tell people looking at the CCR's, cheap Chinese radios, you get what you pay for, and often not even that.
GreggInFL replied to JohnDeere7920's question in Technical Discussion
Modern epoxies have a tensile strength of 3000+ psi. Just glue it down, if you don't mind it staying there forever. -
I'm a member as well to support their efforts on protecting all amateurs but I don't participate in 99.999% of their events as I don't like contests. I work community events such as parades and bike races/rallies.
https://www.amazon.com/dp/B0CDKMWYGR?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_14 Note display. Set menu item #41 to SYNC = ON.
I'm thinking about getting a Radioddity DB25-G GMRS Mobile Radio 25 watt.
GreggInFL replied to WSBX980's topic in Guest Forum
Agreed. I have mine set to monitor one channel only, the one I'll transmit on. It's convenient to have the other three available with the touch of a button, but monitoring four channels, and being forced to switch to transmit on the last active channel, is not appealing. -
nokones replied to JohnDeere7920's question in Technical Discussion
Done that too. Although, we didn't have enough power to turn on the street lights when we keyed, it definitely caused the picture on TV Channel 2 to wiggle a lot. -
It really amazes me that "Some People" get the same VSWRs on a cheap POS Pandaland antenna with a spread difference of almost 20 megs. Really? Wow, that is amazing that any antenna can do that. -
WRYZ926 replied to JohnDeere7920's question in Technical Discussion
@nokones that is hilarious. I would have done the same thing and messed with the guy. That is better than my friend driving through neighborhoods and scrambling everyone's TV's with his CB and linear amp when we were in high school. Since statute of limitations has passed. While at Ft Devens, we would have to test the airborne electronic warfare equipment and we would occasionally have some fun messing with the locals. -
I remember doing some radio testing on 800 Mhz in the very early 80s. I was driving up S.R. 99 in Fresno and this Cadillac with Texas plates kept hitting the brakes in front of me. Then I realized that he was doing this everytime I keyed the 800 Meg radio. I drove up along side thinking he may be a tad impaired and I noticed that he had a box on top of the dashboard and a light would light up when I keyed the radio. The box was a Fuzzbuster (radar detector) and obviously he thought he was being targeted for speeding. So, I told my partner in crime let's have some fun. With the freeway speeds being 55 MPH in those days, we let him get up to about 80 and we keyed the mic and he slowed down to 55 MPH and we kept it keyed for several miles. I bet he was getting impatient going 55 MPH. We pulled off the freeway because we needed to get some gas and that was enough fun for the day. It's a true story, I know because I was there causing all this fun. No, the caddy did not have any bull horns on the front of his car. -
Preemptive thank you for any advice/commentary/etc Newbie proud owner of an AR5RM and a Radioddity DB20-G….couldn't possibly need anything more….but I crave a GMRS capable radio with the simplicity of synchronization of the Main channel “A” Name displayed up top with the frequency of channel A displayed below in “B” It is my understanding from reading reviews that the UV5x3 has this channel synchronization utility and that the F8HP does not. Posting to confirm this. I am also attracted to deals and low cost like a moth to a flame….and the F8HPpro is currently on sale on the Bezos store front. Or, if Newbie is wrong about most of what was just typed; please suggest a similarly priced ($40-$70) option that has this nice, simple channel synchronization display ability Thankyou.
scottbeardmich joined the community
I have one, and in general it is a good radio, but if you are getting it because of being able to monitor 4 channels at a time... it is maybe less than ideal. I don't care for how it will jump to any of the four channels when it hears activity on one of them... when you want to transmit one that you currently had selected. There is not a good way to quickly and easily to switch from monitor all four channels (or three or two) and then only transmit on one without jumping to any of them that have activity. Yes, you can shut off the multi channel monitoring and use it one channel at a time (through a sequence of 4 or 5 separate button presses! . If you use it this way... only have four on the screen for easily switching to one for your four favorite channels but focus on only one at a time.. then it works great. if they would make a single button way to switch between monitor all and focus and transmit and monitor only one - which could be done fast and easy.. I would be 100% recommending it. And if you use it only to do one channel at a time... then I recommend it. That is my opinion anyway.
