Two Repeaters, 10 miles apart, will this work?
WRTC928 replied to WRPL657's question in Technical Discussion
How the heck did I read right past that? Of course, if I read it a couple of days ago, it's entirely possible I forgot it. I'm old. That happens. -
Deregulation; here’s your opportunity to make a difference!
WRYZ926 replied to SteveShannon's topic in FCC Rules Discussion
At least the nursing home staff has not used any patients names that I have heard. -
WRYZ926 reacted to a post in a topic: Deregulation; here’s your opportunity to make a difference!
WSHK714 joined the community
Whatever electrical system you draw power from to power electrical devices you want to make sure that you are using the same earth grounding point or you very well either pick up other noises or transfer noises to the power system.
WSID480 joined the community
JohnTabor302 joined the community
fI don' t don't know my 'Jelly's' too well.. But I'll stick with Blackberry..
tcp2525 reacted to an answer to a question: Antenna grounding?
SteveShannon reacted to a post in a topic: Comet 712EFC -- no ground plane radials
SteveShannon reacted to a post in a topic: Deregulation; here’s your opportunity to make a difference!
^ Unleashed.
I've seen this in other industries, more than once. Someone invents the jet engine, but it gets rejected because it doesn't meet the propeller spec; the lightbulb doesn't meet the kerosene lamp spec, blah, blah, blah. I spent a couple decades working with a team moving our structural titanium alloy aerospace components to the medical implant field, which had been using stainless steel. I eventually concluded that FDA approval is the stamp of obsolescence.
Can confirm.. the petroleum based brands taste horrible.. But KY does not have much taste at all and it's much easier to wash out of your hair than the petroleum kinds.
We contacted one of our schools to make them aware that others could hear them on the FRS radios. They had no idea. They were giving out information like names and telephone numbers of parents during bus pickups etc. They stopped using them. You would be surprised how many don't know they're being listened to.
GreggInFL reacted to a post in a topic: GMRS security risk.
The local nursing home that is about 600 yards away from me has decided to start using FRS radios. And they picked channel 17. I bet they love it when we talk on the local repeater that uses repeater channel 17. We use both TX and RX tones on the repeater. I kept seeing my signal meter move but wasn't hearing anything. At first I thought maybe there was atmospheric ducting and we were picking up another repeater, That does happen on occasion. But then I switched to channel 17 and heard the nursing home staff. I know they are using FRS since their signal isn't very strong even as close as I am. I've been tempted to call on the radio for a clogged toilet in room 13 but have refrained from doing so for now. -
I don't have any experience with the TYT TH-9800 or the Wouxun KG0UV980P. I do have a TYT TH-7800 and TH-8600 dual band radios. Both have worked fine for me and they are easily unlocked. The Won KG-1000G Plus and KG-XS20G Plus have also served me well. I am waiting for the KG-XS20H to come back in stock since it will do 1.25m at 20 watts.
SteveShannon replied to WRTC928's topic in Equipment Reviews
KY jelly is water based, not petroleum based. -
WRYZ926 reacted to a post in a topic: Wouxun KG-UV980P impressions
WSIJ806 joined the community
You sure can.. Let us know when you get her going
HHD1 reacted to a post in a topic: When the database gives me a Input / Output tone for a local repeater, is it Tone or T-Sql?
TrikeRadio reacted to a post in a topic: Could FM CB supplant FRS?
BoxCar replied to WRPL657's question in Technical Discussion
That's why. -
WSDS949 joined the community
I did read the article, that's why I responded the way I did. There's no benefit of using anti-seize on an antenna other than making the person putting the antenna together feel good. On the other hand, if it makes you feel good, buy the 16oz. can with the fancy brush.
I can confirm that it works great for 45 seconds at a time.. Never tested it any longer than that.
if you read the article, you would see real world scenarios. KY Jelly is petroleum based and would liquify under heat. It may work as an anti-seize for a short period but would be useless over time.
WRXN721 joined the community
Too much internet and not enough real world experience. One can put K-Y Jelly on their antenna and get the same results. I reconditioned my 18 element 2-meter beam that was on the tower for 30 years with no anti-seize or K-Y and all was good. I had to replace several broken elements and feedline. Antenna is as good as new and still being used. You gotta use whatever gives you peace of mind, even if it's a sugar pill.
https://perens.com/2024/05/14/radio-antennas-and-anti-seize-compound/
UncleYoda replied to SteveShannon's topic in FCC Rules Discussion
Ham light is fine with me if they don't overdo it (or link in from distant territories). But the FRS kids and highway flagmen get on my nerves. -
WSIJ807 joined the community
No need for it. Just put the antenna together and stop overthinking the situation and enjoy 20+ years of trouble free use. Only thing you need to do with that antenna is to wrap some good quality electrical tape around the joint in the center of the radome.
I wish the FCC had an option to keep your information private, especialy in this day and age. Couple years ago i sent them a mail message asking them to consider this. They should treat your information no different than DMV does..
I wonder if we could get a repeater on the Westin...
When I first got my license, I found it a little disconcerting that your name and address is tied to it. I hadn't thought about someone trying to burgle you while traveling with the radio. But I think fears are a bit overblown. The average criminal is an opportunist. They aren't (that I've heard of) getting fancy radios to look for the off chance that a home is entirely unoccupied, has no security, and has something worth stealing. That said, it doesn't hurt to be prudent and not chat endlessly on the radio about your lovely vaca being so far from home LOL. Also, if you can find a good local private mailbox place, they are fantastic. I had one at a well-run UPS store that would even text or email when you had mail or a package (but they are privately owned so many of them suck). I really liked having the option not to give anyone my address! And no worries about your mail getting stolen or mis-delivered.
WSIJ937 joined the community
nice review, thank you. for anyone interested I would give a very similar review on the TYT 9800 in capability but power reading on mine are a bit lower but so is price. you get what you pay for.
