  2. Today
  3. WRYT630
    Pictures
  4. I've been hoping someone would put a repeater up in Charleston...kinda surprised there are none in the area
  5. Correct. The difference is the -45D has additional internal filtering for use on DMR radios. Otherwise they are basically the same.
  6. I use the HAMRS app for logging my POTA contacts. HAMRS will automatically upload my POTA logs to the POTA website an to my QRZ logbook. I log into the POTA website to spot myself along with see sign who else is working POTA. I try to work park to park as much as possible. And I will answer POTA stations when at home to help them active the parks.
  7. Hopefully someone who's done POTA activations can chime in with the software side of things. I know of pota.app which lets you spot activators (report their location and frequency so others can try to contact them) but AFAIK logging is done with whatever software you want as long as it outputs ADIF. I've used kiwisdr to listen in on activations. Sounds fun.
  8. @Northcutt114 if you're not against climbing some hills, you might also look into SOTA, Summits On The Air. I don't have a portable rig yet but I just ordered a QCX-mini today. I'm hoping to do some SOTA this fall when I go out to west Texas. It appears that there is 5 summits on the ranch where I go.
  9. Yeah, works on the Ham band. Would be a novelty. Without another compatible radio, or decoder for an SDR, good luck monitoring the digital voice traffic. Almost as good as encryption but since it’s publicly documented the FCC can’t really complain it’s a “secret code” thus illegal on the Ham band. The point to remember is the modulation used is exactly the same as the low data rate NXDN mode. The later the FCC has emission designators for that. You can’t tell the difference with a spectrum analyzer. What’s different is the CAI, common air interface a.k.a. the digital protocol used. Note the radio is restricted to just the official dPMR446 frequencies in self programming mode. The radio programming software is also locked to the same frequencies. My main objective was to do some testing to see if it will communicate with a full feature dPMR radio. I have some Icom dPMR radios. There are a few “slight” differences which might bigger that up. There are in fact two different ETSI standards, one each, for the two, dPMR446 verses dPMR. https://forums.mygmrs.com/gallery/image/500-ic-f3162dt-front-and-back-sidepng/?context=new
  10. As someone whose end goal is to RV full time in retirement, I feel like this might be my focus when I enter the world of HAM. I appreciate the insight.
  11. Any progress or further interest in this?
  12. LMR-400 is an excellent VHF/UHF cable, but has a solid center conductor and is very stiff. LMR-400 should not be unrolled/rerolled/bent/unbent very much due to damaging the dielectric. A better choice for portable with similar loss figures is LMR-400 Ultra-Flex, which has a stranded center conductor which tolerates handling much better. I use LMR-400 for my base/home installations (even HF) and LMR-400 UF for temporary/portable/mobile use like Field Day setups, etc..
  13. All of the above. POTA allow one to enjoy the outdoors while being on the air at the same time. One benefit is that those living in noisy RF environments can get away from all the noise by going to a park. Some will take a 100 watt radio and some will even take amplifiers. Others like using QRP radios (10 watts or less) to see how far away they can be heard and make contacts. I like using my 20 watt Xiegu G90 and keeping my antennas light and simple. Mostly it is a way to get out of the house and have fun.
  14. I agree with @UncleYodain that I would change the name of the thread. Assuming you are looking for GMRS repeaters, I don't think there are any. At least none that I can find. There are a good many HAM repeaters in the low country, though. If you're on facebook, maybe this group can help you?
  15. The KMC-45 and KMC-45D are not the same microphone.
  16. OK, so it's about what I thought. Do you have any insight into the "app" they use?
  17. The KMC-45 and KMC-45D are not the same microphone.
  18. Hey everyone! I know it's a little last minute, but NOVA GMRS is having a get-together this Sunday for lunch. We are going to try to beat the heat of day and meet from Noon to 3:00 PM. We are going to meet at Virginia Gateway Center, in the lot between Target and Five Guys. For those who haven't been to this location before, you can navigate to 13299 Gateway Center Dr. There is a picture below, showing where specifically, we park. Bring a chair, drinks, etc. to be comfortable. The plan is to talk radio (or whatever) and then sneak into Five Guys about 1:00 PM for a quick bit and enjoy some company. If you have never been to a get-together or if you are new to GMRS, I highly encourage you to join us and ask lots of questions. As always, this is a family friendly event. So, bring your family and friends! RSVP below or check us out on FaceBook! https://fb.me/e/5m4JpSoAs
  19. I don't have a POTA rig, but there seems to be two purposes: 1. You get to operate your mobile radio away from a permanent location so if you're into emergency or off-the-grid communication, this is gamified practice. 2. Playing with radios outside is more fun than playing with radios inside.* *weather permitting
  20. Yesterday
  21. Closest I know of is Bowman between Summerville and Orangeburg. That one requires club membership. But I suggest you change the title to "Charleston SC repeater?"
