TNFrank reacted to a post in a topic: Repeater Off-Sets are different with HAM.
The mystery of the MXT-400 that can ....Talk Around Feature
WRXL702 replied to H8SPVMT's question in Technical Discussion
Talk Around Is Nothing More Than A Created Motorola Term For Simplex Communications. Nothing More - Nothing Less. No Magic Here...... -
WSAR627 joined the community
Sometimes I hear Morse code from repeater that I have tuned to. Is this an identifier for the repeater or does it signify something else. Thanks in advance!
nokones replied to H8SPVMT's question in Technical Discussion
Also, it is a great feature so that you do not have to use another channel position in the radio for a simplex or mobile-to-mobile with the same freq and tone settings. -
Utah VHF Society (band plan manager for Utah; utvhfs.org) lists 429 repeaters. Of those, 292 use tones, and 137 do not. There are, from what I can tell, 29 tones used by those 292 repeaters, with the most common being a simple 100.0. There doesn't seem to be any specific rhyme or reason other than obvious things like most (but not all) of the Intermountain Intertie linked repeaters using the same tone. There's no pattern other than the sometimes-used concept of "similar things should be [conveniently] similar", as in the example of the Intertie network. There's a pretty good explanation for why you might see a pattern. Humans seek patterns in random events due to apophenia, a common cognitive tendency to find meaning and order in randomness, which is rooted in an evolutionary advantage for survival. For our ancestors, a false positive in pattern recognition (seeing a predator in random leaves) was safer than a false negative (failing to see a real predator). This brain mechanism makes it easier to process information and make quick inferences, though it can lead to errors like misinterpreting data or believing in conspiracy theories. (Explanation came from AI, which is probably ironic)
WSIZ582 joined the community
SteveShannon reacted to an answer to a question: The mystery of the MXT-400 that can ....Talk Around Feature
AdmiralCochrane replied to H8SPVMT's question in Technical Discussion
I believe the main function of talk around is to determine if repeater users you hear are close enough for you to establish simplex comms instead of using the repeater. -
AdmiralCochrane reacted to an answer to a question: The mystery of the MXT-400 that can ....Talk Around Feature
AdmiralCochrane reacted to an answer to a question: Can I use an RJ45 splitter to run dual Hand Mics?
AdmiralCochrane reacted to a post in a topic: Ham Radio 2.0 Coverage of Low-band Channels for GMRS
Lscott reacted to a post in a topic: Ham Radio 2.0 Coverage of Low-band Channels for GMRS
SteveShannon reacted to a post in a topic: Ham Radio 2.0 Coverage of Low-band Channels for GMRS
marcspaz replied to marcspaz's topic in General Discussion
We should schedule a 0700 breakfast meet up at the County Hospital cafeteria! We need to wear hats with our call signs and or favorite PT t-shirt. LoL -
Davichko5650 replied to TNFrank's topic in Amateur Radio (Ham)
Might be a regional thing, like around here> A common one for many of the local 2m repeaters in the TC area of MN is 114.8. a couple exceptions but I'd say about 85-90% or more here are using 114.8. -
BoxCar replied to WSJL659's question in Technical Discussion
I would state you are clueless about TP Ethernet but that would just make the south end of a north bound donkey brilliant. I've only been around computers and computer-to-computer communications for more than 50 years. It's not connectors or cable that define networking, it's the signals present on those wires and connectors. -
Lscott replied to marcspaz's topic in General Discussion
One of the guys I talk to at the gym had his done I think at the beginning of July. I'm waiting to see if he starts back at the gym. I expected he would be out for at least 2 months for rehab. My knee rehab sucked until I got back to a regular gym work out. The exorcise bike and working on leg strength worked wonders. I think I made more progress in a few weeks than a few months at PT. -
WRTC928 replied to marcspaz's topic in General Discussion
I've had a hip joint replaced, but recovery from that wasn't actually too bad. Hopefully, I'll never need a knee replacement. -
Well, SouthEast Repeater Association (the TN coordination body) has recommended tones. 100.0 is the common, and if you are on the edge of TN middle and TN east, what you notice is on purpose......
SteveShannon replied to TNFrank's topic in Amateur Radio (Ham)
Montana has 145 ham repeaters: One 10 meter, no tones Two 6 meter, no clear pattern Eighty 2 meter, majority 100 Hz tone Two 220 MHz, no clear pattern Fifty-nine 70 cm, majority 100 Hz tone One 900 MHz, no clear pattern I don’t detect any pattern other than the vast majority of 2 meter and 70 cm use 100 Hz in this state. -
Most of the 2M repeaters in my area use 162.2 as their CTCSS, the 1.25M seem to use 156.7 and the 70cm use 100.0 for their CTCSS. I guess my 'Tisim saw a pattern in this and wondered if anyone else noticed.
WSJQ712 joined the community
Yeah, wait until your knee gives out and have it replaced. It makes the shoulder work look like a walk in the park. -
@LeoG Thank you for you input. When I used my usb-c cable to plug into the programming port, it updated the firmware without my knowledge. The Od master page looked different, like the old page with my 1st h3. And it wouldn't load properly when I tried to open the page. and as the page was grayed out. I couldn't see much. But I was able to scroll thru the page and found the kill switch button, it was off. So now the phone is useless. I'm expecting a reply from tid on how to proceed. I did mention to them that I might go with a 10 watt radio. And I have been looking at a lot of other 10 watt radios, all with chinese names I can't pronounce . Will keep this updated. If I get something other than another tid, I'll let this page know before I delete it. Thanks to all who have commented. It is greatly appreciated... Crazy WSDX855 currently in Arnold, MO south of St. Louis
WSIY892 joined the community
marcspaz replied to WSJL659's question in Technical Discussion
I have two radios that have remote Bluetooth headphone with built-in microphone. As long as I'm inside of a 35 ft bubble, both radios work really well and there's no wiring to do. I can literally just be walking around the house -
Ever wonder who runs the show? GMRUS is a volunteer-led organization, and we have a structure designed to support members at both the national and local levels. Our Leadership Structure: National Team: A team of volunteers (President, VP, Secretary, etc.) handles the overall strategic direction of the club. State & Local Coordinators: These are the boots-on-the-ground leaders who organize local meetings, on-air nets, and GOTA events in your area. As we grow, we will be looking for passionate members to step into Coordinator roles. If you're interested in helping build the GMRUS community in your town or state, please let us know!
We're incredibly excited to introduce the cornerstone of our public service mission: the GMRS On The Air (GOTA) Program! What is GOTA? Think of it as being the "Helpful Neighbor on the Trail." GOTA is a volunteer initiative where our members provide communication assistance and promote safety in public recreational areas like state parks, hiking trails, and OHV areas—places where cell service is often unreliable. A GOTA operator's role is to: Act as a friendly, visible point of contact. Provide information like trail conditions or directions. Monitor for safety issues. Relay critical information to authorities (like Park Rangers) in an emergency. This is NOT a security patrol. It's about community service and helping others enjoy the outdoors safely. The GOTA program is a fantastic way to practice your radio skills while making a real difference. We'll be offering specific GOTA Operator Training to get you prepared. Ask any questions you have below!
So, what do we actually do? GMRUS is all about hands-on learning and community fun. Here’s a look at the activities and programs we're building: Regular Get-Togethers: Monthly Meetings: A mix of in-person and virtual meetings to hang out, discuss club news, and learn from guest speakers. Weekly On-Air Net: A designated time each week to jump on the radio, test your gear, practice your skills, and chat with fellow members. Training & Education: We offer training for all skill levels! GMRS Licensing Workshops: We'll walk you through the FCC application process. Beginner's Bootcamp: Learn basic radio programming and on-air etiquette. Advanced Workshops: Dive deeper into topics like mobile stations, repeaters, and GMRS-based APRS. Net Control Training: Learn how to run an on-air net like a pro. Community & Social Events: Group Activities: We'll organize group campouts, trail rides, kayaking trips, and family picnics where we can put our radios to good use. Community Service: We'll provide volunteer communication support for local charity events. Stay tuned to the forums for announcements about upcoming events!
Make it easy for people to understand the membership structure and how to sign up. Topic Title: How to Join GMRUS & Membership Info Post Content: Ready to become a part of the GMRUS community? Here’s how our membership works. We've kept it simple and affordable. Membership Levels: Individual Membership: $10/year for one licensed GMRS operator. Family Membership: $15/year for one GMRS license holder and their immediate family at the same address. Associate Membership (Non-licensed): Free! If you're just curious about GMRS/FRS and want to learn, this is for you. You'll have access to all our resources except those that require a license (like transmitting on GMRS frequencies). Why Join? Your membership dues are the primary source of funding for the club and help cover costs like website hosting, event supplies, and future projects like a club repeater! (The Website and association is still being worked on, and much of this is still up for discussion/change until we post the website going active)
Hello and welcome to the official forum for the General Mobile Radio Users Society (GMRUS)! We are a new community-focused organization dedicated to the promotion, education, and responsible use of GMRS and FRS radio. Who are we for? If you're an individual, a family, or a small business looking for a simple and effective way to communicate without the deep dive into HAM radio, you've found the right place. We are built for the everyday user who enjoys GMRS for: Family events and coordination Camping, overlanding, and hiking Small business operations Emergency preparedness And so much more! Our Mission is Simple: To create a supportive and educational community for GMRS users of all skill levels. We want to empower you with the knowledge to use your radios effectively and confidently for recreation, work, and safety. We believe there's a seat at the GMRUS table for everyone. We're excited to have you here and look forward to chatting on the forums and on the air!
SteveShannon replied to WSJL659's question in Technical Discussion
WRYS709 replied to WSJL659's question in Technical Discussion
This thread is exactly the reason I recommend never using “Technical Discussion:” Now it is a popularity contest rather than an intelligent chronological discussion of the issues! -
H8SPVMT replied to H8SPVMT's question in Technical Discussion
As it was explained to me, "Talk Around" is to be used when the repeater temporarily unavailable or has dropped out for "whatever reason." Using Talk Around on the MXT400 continues to use the simplex channel and any tone set, the repeater would have output on so, your group can continue to communicate but, without the use of repeater. In essence, the radio just drops the input signal to the repeater when you select Talk Around. This way the group does not have to swap channels or tones in absence of the repeater. So, to use the "Talk Around function" everyone in the group as to be, or get, into that mode in order to communicate. It's not like the leader of a pack in the woods is the only one to switch. All has to switch. My question for Midland also was, How do you get everyone to switch into a talk Around Mode" Past the word to the closest behind you. "Once, everyone goes into "Talk Around" mode you can stay in it or if the repeater come back, swap modes again to use the repeater. -
WRUU653 replied to marcspaz's topic in General Discussion
I'll chime in on this too (thus turning it into an official ham rag chew, lol). I also went through this about seven years ago, full tear of the shoulder and a full and a partial for the wrist. The wrist still gives me the most grief. Physical therapy is key. It can be difficult but stick with it. Being carefull with it is a good call, I have found there are limits to what I can put the shoulder through and pushed it hard once last year and was sure I had F'd it up again, though it went back to it's new normal after a couple of weeks. I guess I'm not in my 20's anymore. Wishing you a good recovery. 73's
