We are using air dielectric hardline.
Nitrogen Is Used On An Air Dielectric Coaxial Cable To Keep The Cable Slightly Pressurized & Reduce The Chance Of Moisture Infiltration. It Is Never Required For Any Purpose Or Use On Foam Type Dielectric Hardline.
Using The Correct Tools For The Job Are Always Essential!!
WSHH887 replied to tcp2525's topic in General Discussion
I was just going to mention finding out that just because an old B&W TV was unplugged doesn't mean it can't bite. There are just places you shouldn't put a screwdriver. - Today
blastco2 reacted to a post in a topic: BTech GMRS-50PRO 50W Mobile
WSGU500 reacted to a post in a topic: BTech GMRS-50PRO 50W Mobile
The guys that installed our 7/8" and 1 1/4" Heliax purged and filled the coax with nitrogen. That has been years ago so no idea if the nitrogen is still in the coax or not.
You mean pull a vacuum....
Same here. I find I grab my RigExpert Stick Pro most of the time. A good antenna analyzer is definitely more expensive. I do find that the Stick Pro does most of what I need and I hardly use my NanoVNA anymore. There is a bit of learning curve with the NanVNA's but there are plenty of YouTube videos about how to use them.
vzqhsg started following Repeater Near Eureka WQZH452
I was looking on the map today and don't see the above repeater. If I remember correctly it was just south of Eureka. I also had a second repeater listed that had the same name, but a freq. of 462.725. Did this get taken down, storm damage? I showed on listed on Pinkham Mt., the other on Black Butte. Thanks, Dave
Make sure you pressurize and ground it
WRYZ926 reacted to a post in a topic: OK, I have this problem...
AdmiralCochrane reacted to a post in a topic: Found a hidden repeater
I picked up one of those mini Spectrum Analyzers. Interesting device, seems to work o.k.
tcp2525 reacted to a post in a topic: OK, I have this problem...
WRUE951 reacted to a post in a topic: OK, I have this problem...
I actually asked that about the Heliax cables because the center conductor was hollow. Turns out it's a weight and flexibility thing.
I had the coax assemble made by buytwowayradio and they looked like quality connectors. I got my Heliax coax assemble from theantennafarm. The only difference in the installation is I asked for shrinkwrap on the Heliax. Not sure if it was an option on the 239. Much better of a quality connector than in my younger CB days.
tcp2525 reacted to a post in a topic: Using The Correct Tools For The Job Are Always Essential!!
WSHE531 reacted to a post in a topic: BTech GMRS-50PRO 50W Mobile
WRYZ926 replied to tcp2525's topic in General Discussion
I have not used any radio tube amp but have used and repaired a few guitar/bass tube amps. The one machine shop was still using a larger surface grinder that was used tubes. So I have some experience working with them. Our club's VEC has an old 2000 watt tube amp that came out of the local AM radio station decades ago. We keep teasing him by asking when he is going to install that in his pickup truck. The amp is out the same size as a small 18 cubic inch refrigerator I remember working on the old TVs as a kid. one of my uncles owned a TV repair shop. -
all things that normal people, aka the average GMRS user that this radio is marketed to, do not care about. This radio is marketed to normal people, not radio-dorks - It seems like you may be out of touch with what normal people want.
Another gimmicky radio on the market. There is no real need for having the ability to monitor the Aviation Band, FM, etc on a two-way radio. I wonder how often people really need and listen to that stuff. I'm not sure if the Queen stated if this radio was a hetrodyne or a SOC radio. Also, there was no mentioning of real radio features such as, talk around/simplex/direct, Monitor/PL Defeat, Radio Zone/Banks. The only feature that I see being a benefit is the channel capacity. Maybe this radio will motivate Midland to increase the channel capacity of the MXT575, and hopefully they don't follow suit and add any of the foo foo gimmicky features. It's best to keep it simple.
I like my NanoVNA also. It can do a lot, including measuring insertion loss and SWR. But I bought two different RigExpert analyzers and I haven’t used the NanoVNA since. However, the difference in price was a few hundred dollars.
i think everyone should start using Waveguide
WRWP240 joined the community
I like the stealth approach, perfect for Jeeps ets.. For the price, hard to beat.. I like the Bluetooth programing, wish more radio manufacturers would do this.
Actually, the most used 'tool' i use.. Wished it worked on allegories. Hot Damn-it
If your coax is good I would cut both connectors off and install quality new ones, preferably N connectors. Professionally installed connectors are the worst for quality and reliability. Only premade cables I would use that had "Professionally installed" connectors would be Heliax or RFS hardline.
What is going on with the FCC ULS and CORES?
tcp2525 replied to 73blazer's topic in General Discussion
Works fine with the Firefox browser. -
tcp2525 replied to tcp2525's topic in General Discussion
You really don't want to get bit by the high voltage from a tube amplifier, it will wake you up. You youngsters missed the good old days of flyback transformers connected to CRT, they hold their voltage for a long time after being de energized. -
WSIA433 joined the community
@WRXB215 yes, I tried swapping the "tx" and "rx" even, all combinations. I returned them and am looking for a higher wattage HT.
lots of reading and coordinating so your repeater doesn't bleed onto another frequency or step on someone else's toes. I think it would be cool to get a few repeaters up and down the 24 corridor. obviously not linked but just to be able to turn a dial and hop onto the next repeater.
WSHY583 joined the community
Are you that guy that’s always hollering out “Breaker Breaker, Can You Give me a radio check” all the time? You need to lighten up and say something different, You sound like a broken record.
WSGW977 joined the community
Ill leave that version to the guy/gal who calls himself a queen.
