Paul357 reacted to an answer to a question: Question re: grounding for lightning protection
Either because you have the wrong receive code (better to use none at first) or because your transmitter radio is causing the receiver radio to go deaf, which is called “desense.”
WSHY770 is a GMRS call sign. RadioID only issues DMR IDs to services which allow DMR. DMR is not available on GMRS under normal circumstances. If you have an amateur call sign you can get a DMR ID at RadioID.
Why would the other radio not receive my transmission?
So the repeater heard your transmission and gave a call sign.
SteveShannon reacted to a post in a topic: Repeater permission
NCJeb reacted to a post in a topic: Repeater permission
Agreed. It just fit the "I'm gonna look up this person's call sign so I can send them something" thing.
Oh boy, I must really be messed up and beyond any help since I have my Amateur and GMRS licenses. I can't speak for other repeater owners. I do try to answer any and all requests in a timely manner. PS: I'm not crazy, I am perfectly insane, verified even.
Went 100ft... Still a no go. However, after transmitting on Wouxun S88G, both radios picked up Morse code tones (station ID?).
SteveShannon reacted to an answer to a question: Newbie Repeater Config Problems
Try leaving DCS empty on the receive side and make sure you keep the transmitting radio some distance away from the receiving radio.
WSGM321 joined the community
Try 100 feet and report back.
About 75 feet.
I asked this question twice on your other post and still have not received a response, so i'll ask more slowly this time: How ... farrrr.. aparttttt.. areeee.. theee... twooooo radiosssss ..whennnnn youuu are testinggggg themmm?
I’m unable to get my callsign, WSHY770, recognized on RadioID.net as well. I’ve been trying for a couple of months now. Please, any advice? I have a DM-1701 DMR radio and I know I’m missing out on a lot! HELP!
Yes, but the rules, personalities, social-abilities, and cultures of the users are vastly different between services..
How far apart are the radios when you are testing?
WRXB215 reacted to a post in a topic: Baofeng and Baofeng Tech
I removed the Rx tones from both radios (leaving the Tx tones set on both). When I PTT on the Wouxun S88G, I get a second of two of static on both radios, but the message itself is not heard. Nothing seems to happen whent talking on the Baofeng UV9G.
I'm still not getting this notification and I am using the same password I set up my account. This is definitely a browser issue for people that are getting these notifications.
You can't (should not be able to) transmit in "frequency mode" on either of those radios, so forget that idea Try removing the receive/RX tones/codes from both radios Get the radios at least 50 feet apart when testing Report back with your results
Sir, this is a GMRS forum. GMRS people and normal people don't know what a QSL is.
so it's like a mildly threatening QSL card?
JAYBADD joined the community
I have been using my radios in simplex mode for about a year now with no issues. I now have reason to use a local repeater that I have been granted access to. To verify it is working I am using two radios ( a Wouxun KGS-88G and a Baofeng UV-9G). These radios are used to talk to each other in simplex mode whenever we are out and about fishing or hiking. I have tried using channel mode (Repeater 16) on both and entering the given DCS . I have also tried Freq mode by entering 462.575 as wll as the DCS code for both Tx and Rx. The 88G seems to transmit as I see the frequency change to 467.575 when I PTT the UV9G will indicate it has an Rx signal when monitoring 467.575 via frequency mode, but I hear nothing (squelched out?). What am I doing wrong?
Copied to Technical Forum (sorry for the misplace). I have been using my radios in simplex mode for about a year now with no issues. I now have reason to use a local repeater that I have been granted access to. To verify it is working I am using two radios ( a Wouxun KGS-88G and a Baofeng UV-9G). These radios are used to talk to each other in simplex mode whenever we are out and about fishing or hiking. I have tried using channel mode (Repeater 16) on both and entering the given DCS . I have also tried Freq mode by entering 462.575 as wll as the DCS code for both Tx and Rx. The 88G seems to transmit as I see the frequency change to 467.575 when I PTT the UV9G will indicate it has an Rx signal when monitoring 467.575 via frequency mode, but I hear nothing (squelched out?). What am I doing wrong?
marcspaz reacted to a post in a topic: NOVA GMRS July Get-together
WSCU408 joined the community
WSIU458 joined the community
Then the stupid bastard should respond to their emails.
You'll learn not to take many of his posts seriously.
kidphc started following Antenna question?
Should be fine. Is the conduit on a slight grade to drain water? Sent from my SM-S901U using Tapatalk
