  2. Randy (@OffRoaderX) did a video that might help:
  3. yes it is running dtcss and i am setup to tone in and out. I think you answered my question traffic that I am hearing since the move are very low signal strength that makes them un readable. was just wondering if repeater could filter out broken and or weak signals. thanks
  4. It certainly doesn't surprise me that there are differences. That is why I'm looking to get information now instead of later. Now I have done some reading, but haven't been able to get clear answers. I can also state that I understand that radios that are going to be used in Canada need to be IC approved. Then again this is something that each country will probably have a rule for.
  5. Today
  6. Mine does that too. Have not looked for a fix.
  7. hi all! i recently picked up at db20g and was able to program it using the radioddity cps software. one issue it's having is that every time i turn on (power up) the radio, B channel is always starts up in vfo mode, even though its programed to start up on channel/memory mode. just wondering if anyone else noticed this or has this issue? will another programing software fix this issue? Thanks!
  8. Midland calls it a ghost, others call it a 'phantom' antenna. There are ground plane kits for it, nmo mount with radials. Works nicely for wall or mast mounting. Myself if I decide to mount using the ground plane kit, I go with a 3 db stainless whip. Little more to capture signals.
  9. "Having donation options would be one thing, but there is zero chance you're convincing me that you need to collect a membership fee to cover costs, imho" And I agree. At 70+ years old. I have seen a lot and when money is involved, there is a paycheck in the background for many issues like to, "JUST COVER EXPENSES."
  10. Thank you, I haven't even talked on mine yet.
  11. The education thing could be useful. I barely passed my GMRS test and am still studying for my entry level (use of Channels 1, 2, and 3) MURS exam after failing it twice, already. But nobody's posts that I have seen here, has touched on the important stuff. Will there be hard hats? What about bright orange or green safety vests? How about GMRUS magnetic decals for the car or truck for use in disasters or sanctioned emergency drills? Will there be an emergency communications trailer? If not, count me out. If GMRUS does not offer hard hats, I may join this guy's organization. At least he has some cool, though well used, protective gear.
  12. Kinda mean spirited writing a letter to a guy who can't read?
  13. People people please, I think what we are all forgetting here is that radios goes bleep bloop... And isn't that all that truly matters?
  14. So it has been a bit since I was on here and I can say I got a good amount of responses. That said the first one was a bit hilarious. I have a feeling that marc has not looked at the antennas mentioned let alone the antennas that the Australians use for those CB Radios. With that all said I found out that the Ghost Antenna is not meant for much if it isn't grounded well. That was something I found out recently from Midland. Because of that I decided to go ahead and purchase the Highland antenna. Why? Because that antenna does not require a Ground Plane. Because of that I should technically get better performance causing me to get better range(within reason). Now for those wondering why a 3dB antenna has been chosen over other antennas, I understand my particular use. I don't necessarily need to talk to the moon, but I know that a good antenna paired with a good radio you can get an excellent range in multiple terrains allowing you to speak to others and get weather information from NOAA(if there is a tower nearby). The antenna was just ordered today and I am looking to get it installed in the next weekend. Once that happens I will test the performance and report back.
  15. Your licenses will not transfer, Nor do I believe are US GMRS radios permitted in Canada. Their GMRS is much more like our FRS. You’ll need to research what radios and bands are available. Amateur radio is different. There are agreements that allow an amateur from one country to operate in another (not all, but many)
  16. Hello all, I have a question related to the rules for Canada specifically when it comes to using mobile radios like the GMRS or others. I myself do have a license to operate a GMRS Radio in the US and I currently have a Midland MXT575 Radio in my vehicle. I also have a Garmin Tread equipped with the Group Ride that uses MURS at 5 Watts at best. In the near future(probably in about 2 years) I see myself moving up to Canada for work and I'm curious if I will be ok to keep the radios I have(even if it means getting the appropriate license) or if I will need to change the radios on the vehicle. Any information will be helpful!
  17. WRYZ926
    Volts
    Most mobile radios are designed to run at 13.8 volts. Most 12 volt vehicle charging systems are designed to charge between 13.8 and 14.2 volts on average. 12 volt power supplies are all set to 13.8 volts for a fixed output. Newer vehicles with the battery management system will see charging voltage as high as 15.2-15.4 volts at startup if the vehicle has not been ran for a while. A lower voltage of 11.5 should not affect the signal quality when compared to 13.8 volts or even 15 volts. The only thing you should notice is a difference in the output power of the radio.
  18. CTCSS, DCS, or carrier squelch are all options. None of the are based on readability, although DCS (aka DTCSS or DPL) does require some measure of readability for the digital code to be recognized. What do you mean by unreadable? Are you using something like CTCSS or DTCSS?
  19. This sums it up well; i've talked into a GMRS repeater and a 70cm ham repeater on Joaquin Ridge on the west side of the San Joaqin Valley from a hill on the east side of the valley (75ish miles) with 5 watt HTs. I've also talked into another 70cm repeater on Fremont Peak from a bit further east, around a 115 mile shot over the valley on the 50 watt mobile in my truck. In both cases, i had clear line of sight over the valley, as i was sitting around 4500-5000 ft elevation, and all of those repeaters sit around the 3000ft mark on hills/ridges.
  20. dugcyn
    Volts
    that is a lot of power output difference %. what was noticed on mine was quality of signal 11.5 volts vrs 13. I am not a circuit engineer but, bet there is an optimam somewhere in the calculations?? dont think power output wattage is key to the full picture of radio clarity and propagation. am no expert tho.
  21. is there such a thing? our repeater has moved location and seem to get a lot of traffic now that is un readable.
  22. There is a setting in the menus - i dont recall the name but you will find it in your user-manual. That setting sets the screen to show channel number, name, or frequency.. This is ASSUMING you are back in channel mode. Make sure you are in channel mode.
  23. Bingo. Does everything I need it to, does it pretty well, and cost $80. It was just a...Radio...oddity? I'd noticed. Would be nice to know what causes it to hang open tho.
  24. UHF can go a very long ways as long as there is a clear line of site. 70cm is used all the time to communicate with satellites. Of course you don't have to fight the curvature of earth when talking to satellites. A clear line of site is king when it comes to VHF and UHF. We have been having a lot of tropospheric ducting on GMRS over the last 2 weeks with the cooler than normal temperatures we have been having. I've been hearing a GMRS repeater located in Peoria, Illinois almost every day between 8:00 and 8:45 in the morning. Peoria is about 150 miles from me. I've also been hearing another repeater that is about 80-85 miles away.
  25. TNWEB
    WSJS334
    Your well equipped. Have fun.
  26. I was setting the tones for a local GMRS repeater and had to switch to DCS selection using the PF2 key. I got that done but now the LCD display doesn't show the normal GMRS channel number. Instead it shows 462.575 Also, if this is related, the top line says S W then CH- 02 G-03 How do I get the frequency off the display and go back to the GMRS number label?
