  2. Today
  3. But only in low light where its ability to send RF in even the dimmest of atmospheric conditions is better than a non dim light spec’d one when operating in late evening or at night.
  4. There is more to this story than you read I am sure. This also happens way more than you think but dont go to this level. I apploud this county for pushing this and the FCC doing something. Too many folks think its fine to do what they do just like this site.
  5. I have noticed that even though I have this "individual" ignored, if he's quoted his inane comments still show up. Then I just have to turn on my filter and ignore him.
  6. Next time you are in Texas, set up a repeater at Hughes Apache Ranch please.
  7. 55 years ago I was voted class clown and sometimes I regress. I could understand wanting to set up a “base station” using a better antenna and higher powered radio in order to get more range. That’s much easier to do than a repeater and would give you the same range. What do you hope to achieve by having a repeater in your apartment? Are you planning to provide the repeater for others to use?
  8. Got the voltage regulator on today it's back to normal voltage, now I can get radio back in tomorrow if it doesn't rain. Thanks again, WSEK634
  9. He was actually new twice here. He quit once, had his name purged, and then slunk back in. That’s why there are all those idiotic posts attributed to “Guest” in the non-guest forums.
  10. I have lived in apartments before. They were always small enough that I could reach from one end of the apartment to the other without a repeater. I could even reach from inside the apartment to the dumpster outside when my wife took the trash out.
  11. Our 70cm antenna is at 900 feet and we get about a 35-40 mile radius of coverage. Our GMRS antenna is at 400 feet and we get 30-35 mile radio of coverage. And both bands have same dead spots depending on the terrain and trees. Our 2m antenna is also at 900 feet and we get a 80-85 mile radius with it. I mention it to show the difference between VHF and UHF. The 2m and 70cm repeaters actually use the same set of antennas and go into a diplexer.
  12. Chinese Spy Baloon
  13. its a chinese spy balloon near Pasadena
  14. Yesterday
  15. The Calif High Desert offers a lot of locations with good elevation and wide open valleys. One repeater here siting on a 4500 foot mountain top (El Paso) can talk Palmdale - Lone Pine about 160 miles (Repeater sitting about center point). I've heard people talking on this repeater on HT's standing at Whitney Portals on the same path. I think dry weather has a lot of benefit to talk distance as well.
  16. Welcome aboard, I monitor Thompson Station, Brentwood, both Franklin and Grasslands repeaters. We have not set up a formal net, but with 44 members we should be able to set up some days and times for shout outs.
  17. So it's, as stated above "We did some things." I guess I can live with that since it didn't brick the radio I tried it on. (And I must say that updating via the USB-C port is much more convenient than using a Kenwood programming cable.) Anyway, thanks for the info and feedback.
  18. I've only ever seen one other site that's close at all, and a very distant second at that. So distant that I can't even recall it's name or the URL. I'm here mostly as I'm into all facets of the radio world, but I do generally only use GMRS radios when out doing things, barely, if ever use a repeater. But interesting to see what else is going on out there and this is the best place to find that for GMRS.
  19. Good thing CostCo has those 35 packs - 29 for y'all and a six pack for me.
  20. We all value knowledge and experience here, but the way you're treating newcomers is out of line. Everyone starts somewhere, and being dismissive, impatient, or outright rude doesn't make you look more knowledgeable—it just makes this community less welcoming. If your goal is to actually help people learn and grow, then your attitude needs to reflect that. Otherwise, you're not building anything—you're just gatekeeping. You were new once too. Try to remember that.
  21. Dimmy antennas are used to contact stations 200 miles away.
  22. WOW, kept staring at the Ballon and then I saw a alien babys face screaming.... then the bird shit got into my eyes!
  23. I'm good with things as is, no need to ignore.
  24. It appears there are three different options for scan mode. Carrier, Time, and Search. Search exits out of scan when a signal is detected. It’s described in the extended manual.
  25. You can still see how people react to him. I added him to my ignore list a while ago and it really has made my life easier.
  26. What and miss all the fun?
  27. Breaker Breaker, can you give me a 'radio check'.. just checking in - Roger Beep
