WRUF242 reacted to a post in a topic: Offline Use
AdmiralCochrane reacted to a post in a topic: Is GMRS what i need
AdmiralCochrane replied to WRPL700's topic in Amateur Radio (Ham)
Music is math is music. At some colleges, some music classes are accepted as required math credits. My wife's best friend got out of several math classes via that route. -
He's the star of the video!
AdmiralCochrane reacted to an answer to a question: Fatrat56
AdmiralCochrane reacted to an answer to a question: Question re: grounding for lightning protection
Lucky Sears is everywhere. Seems like it is always hard to find Homer Atkins. I have a friend who is half Chinese and half Hungarian/American. Her parents were very clever, her Chinese names are her middle names and are the same as her English language name framed around the Chinese.
GreggInFL replied to WRPL700's topic in Amateur Radio (Ham)
A friend with a doctorate in industrial psychology once told me that aptitudes for math correspond with aptitudes for music. -
Thank you!
Yes, dual monitoring on both bands, A and B.
Thank @OffRoaderX, he made the video.
Thanks for the you tube that helps a bunch!! WSEU 498 Fatrat56
WRHS218 reacted to a post in a topic: Is GMRS what i need
YouTube, look for videos from the Notarubicon channel. One specifically describes configuring a radio for a repeater.
My radio is unlocked so it will work on a repeater? Where can I find how?
IF it is not "locked", then, YES. IF it is 'locked', then, NO. So the actual answer is: It Depends TL;dr: Maybe
Mine can, but it’s an older model.
can a baofang uv 5 r be programmed to talk on a gmsr repeaters?
Fatrat56 joined the community
WRON274 joined the community
That's true, the FCC just kind of let it slide into history with zero notice... which kinda stinks for people who knew it as the de-facto operation since the `60s.
Do repeaters have to be part 95 accepted
OffRoaderX replied to Elkhunter521's question in Technical Discussion
The point is, "some people" are out there, right now, spreading lies and misinformation on the online forums, videos, etc, claiming that the FCC will actively go after you, track your location, fine, you, or even jail you for using a radio/repeater on GMRS that is not Part 95E approved. We must stop the lies. -
UV-5R and UV-18 Pro Max Dual Receive?
OffRoaderX replied to WSIC904's question in Technical Discussion
Yes. -
By "dual receive" do you mean capable of listening to two frequencies at the same time? What Baofeng calls "dual monitoring"? If so, then yes, the UV-5r can do it and according to its advertising the UV-18 can too. If we're splitting hairs, the Baofengs don't actually listen to two channels at the same time; they flip rapidly back and forth between them, but for most people's purposes, it's close enough.
WRTC928 replied to Elkhunter521's question in Technical Discussion
And why would they? They have their hands more than full trying to rein in people who are creating genuine problems. I don't know if it's ever happened, but I could imagine it being added onto the list of charges if they had to hunt someone down for being a troublemaker. As I always say, be polite and things will probably be fine...but be capable of "action" in case someone doesn't respond to politeness. -
I thought that, but I just wondered if anyone thinks they should be. -
I will agree with Randy (OffroaderX) and others. Don't put all your egg's in the GMRS basket. But I think the off road guys will agree, more is better. IS GMRS good for off roading, yes, most likely. But it can't be the only radio or method of communications in your rig. A CB radio is a great addition, and possibly a ham radio, if you have the motivation to get the license. But, repeating what others have said, A Garmin InReach is going to be king. But you need to understand the differences in what and who you are calling, and what level of 'emergency' you are in the middle of. A flat tire, if you don't have any ability to change it is a problem. If you are in a creek bed and there a flood warnings then it's an issue. If your rig has flipped, and you are stuck under it in the creek bed and there is a flash flood warning, then you need IMMEDIATE assistance. That's the InReach, forget GMRS and all the rest. The other thing to consider is are you wheeling with others. As many have said, never wheel alone. And that's really sound advice. But it's not always reasonable, or we sometimes choose to ignore it for whatever reason we can come up with. We don't know your rig, setup, or what level of extreme wheeling you are doing. Trail running on groomed trails is far different from rock bouncing in Moab. And we don't really know how remote you are running. If your trails run behind family homes that are occupied all year long, it's not the same as there being one cabin in the woods for 5 miles in any direction that while could be broken into in an extreme circumstance for shelter, would otherwise only be occupied one week a year during some hunting trip. Gauge what you are doing with what you are needing. Ultimately it's cheap insurance to have more than you need than not enough communication ability. And even then, the InReach, as far as I know, will work anywhere at any time. Something else to consider as well. And this goes against the historical thought process. T-Mobile is now partnering with StarLink to offer cell service via satellite. That might be an option worth considering as well. The phone of course should have some app on it that will pinpoint your location via satellite, like your GPS does. Again, something below the InReach. You have to understand that the InReach is like calling 911 without saying anything. They just send people to that location and they will come quickly. Inreach has some text function, but it's mostly a distress beacon. A 911 call will generate a similar response, but with more information being given to the 911 dispatcher, they can send a proper response to the actual situation. If they don't know what or who to send, everyone gets sent, and it's treated as a life and death situation.
It hadn’t been nullified at the time of the video and banter. The FCC really should have made at least an attempt to announce it.
WSBN701 joined the community
WRYZ926 replied to Elkhunter521's question in Technical Discussion
I'll have to look at our Bridgecom repeater next time I am at the repeater site. I doubt it is Part 95 certified as it is the exact same repeater that Bridgecom sells for the amateur 70cm band. The only difference is how they program them before shipping. There is a person near me that owns several GMRS repeaters along with several 2m and 70cm repeaters. He uses Motorola Quantar repeaters for all of them. -
Ant421 joined the community
I remember when you made the Ch19 video and all the banter on here leading up to it. No one has successfully countered it to this day... so It still stands as the only authoritative source! LoL The sad part was, many of us (myself included) had no idea the Line A issue was nullified, which didn't help.
Baofeng gm15pro shows long antenna included, but not shipped?
WRUE951 replied to a topic in Guest Forum
I tried -
WRUE951 replied to Elkhunter521's question in Technical Discussion
they never will.. I can tell you, every single one of my HAM buddies with GMRS repeaters, all use Kenwood's, Motorola's, Harris, Hytera radios.. (non-part 95) If the FCC ever decided to enforce this rule, it would be impossible for them to detect them. Outside of putting their eyes on them.. And that would never happenn
