Raybestos reacted to a post in a topic: Apartment Repeater setup
Haroldo reacted to an answer to a question: Dummy Antenna
Over2U reacted to a post in a topic: Spotted on the 210 Fwy
Haroldo reacted to a post in a topic: OK, I have this problem...
Kzona1976 joined the community
Our 70cm antenna is at 900 feet and we get about a 35-40 mile radius of coverage. Our GMRS antenna is at 400 feet and we get 30-35 mile radio of coverage. And both bands have same dead spots depending on the terrain and trees. Our 2m antenna is also at 900 feet and we get a 80-85 mile radius with it. I mention it to show the difference between VHF and UHF. The 2m and 70cm repeaters actually use the same set of antennas and go into a diplexer.
WSHE531 reacted to an answer to a question: Dummy Antenna
WRUE951 reacted to a post in a topic: Spotted on the 210 Fwy
Chinese Spy Baloon
its a chinese spy balloon near Pasadena
WRNU354 reacted to an answer to a question: Dummy Antenna
The Calif High Desert offers a lot of locations with good elevation and wide open valleys. One repeater here siting on a 4500 foot mountain top (El Paso) can talk Palmdale - Lone Pine about 160 miles (Repeater sitting about center point). I've heard people talking on this repeater on HT's standing at Whitney Portals on the same path. I think dry weather has a lot of benefit to talk distance as well.
Lexemtman joined the community
New Member Check-In
SteveGibbs replied to SteveGibbs's topic in South Central Tennessee GMRS's Club Forum Page
Welcome aboard, I monitor Thompson Station, Brentwood, both Franklin and Grasslands repeaters. We have not set up a formal net, but with 44 members we should be able to set up some days and times for shout outs. -
So it's, as stated above "We did some things." I guess I can live with that since it didn't brick the radio I tried it on. (And I must say that updating via the USB-C port is much more convenient than using a Kenwood programming cable.) Anyway, thanks for the info and feedback.
bojo joined the community
Complete Amazement, where is everyone ?
Davichko5650 replied to WSHU859's topic in General Discussion
I've only ever seen one other site that's close at all, and a very distant second at that. So distant that I can't even recall it's name or the URL. I'm here mostly as I'm into all facets of the radio world, but I do generally only use GMRS radios when out doing things, barely, if ever use a repeater. But interesting to see what else is going on out there and this is the best place to find that for GMRS. -
Good thing CostCo has those 35 packs - 29 for y'all and a six pack for me. -
We all value knowledge and experience here, but the way you're treating newcomers is out of line. Everyone starts somewhere, and being dismissive, impatient, or outright rude doesn't make you look more knowledgeable—it just makes this community less welcoming. If your goal is to actually help people learn and grow, then your attitude needs to reflect that. Otherwise, you're not building anything—you're just gatekeeping. You were new once too. Try to remember that.
Dimmy antennas are used to contact stations 200 miles away.
WOW, kept staring at the Ballon and then I saw a alien babys face screaming.... then the bird shit got into my eyes!
I'm good with things as is, no need to ignore.
It appears there are three different options for scan mode. Carrier, Time, and Search. Search exits out of scan when a signal is detected. It’s described in the extended manual.
You can still see how people react to him. I added him to my ignore list a while ago and it really has made my life easier.
What and miss all the fun?
Breaker Breaker, can you give me a 'radio check'.. just checking in - Roger Beep
If you think this place is low on active members just wait until you start listening to your radio
rotomoto joined the community
Yes. And searched online for a solution.
a.k.a. Load Terminator or RF Power Terminator
Have you looked over the manual? Gone into the scan settings?
Anybody can come up with scenarios where any use could be helpful. The issue is, is GMRS as specified in the regs, the right service for your usage scenario. If not, and you want FCC to make a change, then propose that. Just going rogue because it suits your purpose makes you a radio outlaw. Part of the the issue is just the precise meaning of what "illegal" means in this context. We should refer to violation rather than illegal since it is about regulations. But I think it is generally understood that illegal in the radio context means violating FCC regs. Linking over RF is not explicitly prohibited in the wording of the regs. But it is at least discouraged in the rule clarification where it explains any linking is bad. As far as I have ever heard or read, starting with ham, mixing radio services is prohibited by regulation. There are no other frequencies that I know of that can legally (haha) carry GMRS conversations. If you know of some, can you list the frequency and/or the service? Sounds a lot like "our country, love it or leave it". Leaving if you don't like how it is used would be fine IF EVERYONE WAS FOLLOWING THE RULES. Leaving because some people want to break the rules is just running away rather than fighting.
I've searched for a solution and tried several things, but cannot figure out how to to this: Radio is a DB40-G When scanning through channels and I hear someone talking, I want to stop the scan and stay on that channel even if there is a break in the transmission. But the radio resumes scanning after a few seconds when there is a break. I've tried to hit the scan button, but it defaults back to the last channel I was on before starting to scan. For instance, if I was on Channel 1 when I started scanning, and try to stop scanning to listen to channel 5, when I hit SCAN, it goes back to Channel 1. I've tried the PTT button and it pauses, but then resumes scanning. I've tried the CAN button and nothing happens And lastly, the Mode button - I don't think that did anything. Any advice on how to do this?
He is incapable of actually being helpful. He prefers to make himself look like a rhee-tard every chance he gets. This is the recommended fix:
FWIW, several years ago I ordered the Browning base loaded NMO antenna. Hole mounted it on the right rear fender of a 08 or 09 Hyundai Sonata (older and better body style). It performed very well with an Anytone Smart CB inside. I found the performance as good as any Wilson 1000 or K-40 I ever used. Unfortunately, the car was totaled with in a wreck with a dump truck. My next car was bought in a rush and I had no real estate for antennas. If I ever get another car or truck, it WILL have a CB and this is the antenna I plan to use. https://www.amazon.com/Browning-BR-140-Land-Mobile-Antenna/dp/B0043I6FJA/ref=asc_df_B0043I6FJA?mcid=55684a0f4a963b8bb4dfae26a94289f4&tag=hyprod-20&linkCode=df0&hvadid=693362547589&hvpos=&hvnetw=g&hvrand=7567373534784621621&hvpone=&hvptwo=&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=1021278&hvtargid=pla-761964227712&psc=1 Note: As with most CB antennas you WILL need to trim the whip. An SWR meter will be necessary.
He might be an old fart that needs help... Go give the gent a helping hand
