SteveShannon reacted to a post in a topic: Long, Long Ago
SteveShannon reacted to an answer to a question: WRYI628
SteveShannon reacted to a question: DB-20G now on Chirp
SteveShannon reacted to an answer to a question: Db20g CPS not working
SteveShannon reacted to an answer to a question: What would generate a Morse code ident on channel 6?
goaliechris17 joined the community
WRXB215 reacted to a post in a topic: Hilarious ad on facebook
WRXB215 replied to WSCB609's question in Technical Discussion
CW is a mode. Morse Code is the most common code use with CW. -
FYI the radio is now in Chirp
LeoG started following GMRS in a Box
I have two of the Apache cases too. The Retevis RT97 repeater setup an a few HTs. All the appropriate accessories under the repeater.
WRXB215 reacted to a question: DB-20G now on Chirp
I figured I would let everyone know, I updated Chirp tonight and saw the Radioddity DB20G is now on the supported radios list. Which Im sure means the other brands of this same radio likely work with it as well. Consider this a friendly heads up. I think we all prefer Chirp over most all oem software.
GrouserPad reacted to an answer to a question: What would generate a Morse code ident on channel 6?
FishinGary reacted to an answer to a question: WRYI628
Why not spend less money on better radios and mount one in every vehicle. I’ve got all these toys and you skimp on radios and only buy one junker???? Geeesh. Some people.
It is not available for GMRS..
it its a HAM call sign there is a process you can take to acquire the call sign through the FCC via a Vanity Request. I don't think this would be abailable undere a GMRS lic though. Someone here may know. Steve?????? Of course you would need a HAM Lic
now thats pretty impressive,, a case twice the cost of the radios
Anyone have any info about this Michigan repeater "Frida 700"
scotgiant replied to Scott1966's topic in General Discussion
We are still working on getting Frida 700 up and running this year. The project was started a few years ago but got put on hold due to some issues with the tower. The group has not decided if this will be a open repeater or not yet. We'll see! -
WSHH887 started following GMRS in a Box and WRYI628
Showing respect for someone who passed isn't weird. The world could use more like you.
https://www.amazon.com/Larsen-27-30-Loading-Coil-Black/dp/B004Z940DA
Well, that's a neater setup than mine. I'm currently using a small backpack for a DB20-G. It's got all the needfuls, (radio, HT's & charger, 110v to 12v transformer, programming cable, and mag mount) except an antenna. I'm looking into a ghost type. I do have an antenna permanently mounted on my truck. Mine isn't so much for portability but more for security. They have been hitting vehicles nightly in my area, so everything comes in at night. I'd really like to mount the radio in the truck, but I doubt it would last a week before some "individual" smashed a window and took it. My currnet mount is a very clunky cup holder mount. Your box set up looks good. And darned if Harbor Freight isn't just a few of miles away.
scotgiant changed their profile photo
Emmiren joined the community
WSCB657 joined the community
The Apache cases are hard to beat, especially when on sale and/or you are an Insider Member. I have several Apache cases. Here is one I setup for portable use with my Xiegu G90 20 watt HF radio. I've been thinking about setting another one up for my Wouxun KG-XS20G and maybe a 2m/70cm radio.
Raybestos replied to WSCB609's question in Technical Discussion
^^^^This!^^^^ Most CCJ radios have direct conversion receivers and are susceptible to bleedover, intermod, and other stuff from within and outside of the GMRS band. What you are hearing may not even be on GMRS. Several excellent suggestions on this thread about using Morse decoder apps or posting the audio on here for one of us who can copy Morse, should help ID the source. -
Radioman26 joined the community
You're a ringer - you already know what it means and how to use it.
My MX275 radio goes between my RV, boat, and occasionally my wife's car, depending on the activity. It always has been kind of a handful of stuff. Harbor Freight had a coupon that I used a week or so ago, purchasing an inexpensive Pelican case knock off. There was room in the case for the 275, its cig plug, two UV5Gs, one "RM", three rubber duck antennas, a charging base for the UV5Gs, and the stock mag mount antenna for the 275, which I don't use, but seemed like a good thing to toss in for completeness sake. I used the lower foam layer for the Baofeng charging base, cig plug, and stock external magnetic mount antenna for the 275. The MX275 instructions are underneath it all, since you need them to translate real PL tones to the codes that Midland uses. None of this is high end stuff, but it should be relatively convenient.
scotgiant joined the community
WRXK261 joined the community
WSHT980 joined the community
Yea. that's pretty weird!
Maybe i am a wierdo... but i purchased a used anytone off ebay a few months back, and it had a calk sign programmed into it for the boot screen, i looked it up and the gentleman had passed away early this year, and he had a lot of similarities in life to myself and my wife..... i kept that call sign programmed in, in memorium of him. I never met the guy but i can tell you if i id did, we would likely have been great friends... i like to think he might be watching over me as sort of a "silent Elmer"... Like i said.... maybe i am a wierdo....
Exactly! So, for context, the first KG-Q10G I ordered had a defective GPS receiver. When I contacted BuyTwoWayRadios (not BetterSafeRadio!) they told me that they could not exchange the unit because they were sold out. They offered to send me a used unit which was given to them by Wouxun to test. I agreed. Tried the GPS - it was slow (not a real GNSS chip) and had a pretty bad design, but I did not really care. What I did not do is double-triple-check that the Channel Wizard did work properly. I got no error messages of any kind. However, much later, I did notice that for some reason, I could not hit some repeaters. So I sat down and tested it fully. I found out that others had the same problem, so I found a workaround: use the Wizard as indicated, then manually fix the frequency. I worked in IT long enough to know that code does not degrade over time, at least not by itself and for no reason. So I contacted BTWR again and asked them about it, and they told me that they never heard of any issues with the wizard and offered me to send them the radio for testing. That is when I told them that my model was already an exchange of a new for an old one. They replied "Oh that's interesting. Can you provide me that order number?" and when I did and suggested either an exchange or a rebate for my purchase of a brand new one. Why? 1) because that code error was not due to time passing, it was always there, I just spotted it too late and 2) I can still use the KG-Q10G even with a buggy wizard. Their reply was simply "there ain't nothing we can do, it is out of warranty". I had mistakenly assumed that finding out that the radio I had was a used radio sold to me for the full price, that would entice them to try a tiny bit harder. Instead it showed them the out of warranty date and they were done with that. I was naive, I admit. Now here is why I decided to ditch them: I did not demand or expect a new unit, and certainly not for free. But I did think that since they sent me a used unit to begin with (and sold me a defective unit originally) they would provide at least some kind of support. That is, after all, why BuyTwoWayRadios are advertised as "we are in Murica!! We offer Murican customer support, not that frustrating Chinese one!". LOL! You put it best (even if you confused the sellers): BTWR are "just a vendor" for a Chinese product. They offer exactly ZERO extra value. Once the Chinese warranty is done, so are these good Murican boys. That is my problem with them. That attitude. Some may like it. I don't have to! By the way, I had a similar problem with a Meshtastic device from Rokland and they immediately agreed to giving me a rebate for the purchase of new gear (by that time, mine was also out of warranty). So there are sellers out there which give you true extra value. And since I get go to BSR or another US seller (or even order from China or any other country, I have done that many times), I am happy with the outcome: I have a workaround and plenty of sellers to go to in the future. And if some "sad posters" think that a condescending tone is a substitute for expertise or if they think that BTWR does a stellar job giving us extra value, by all means, enjoy! From now on their "insightful comments" will go to my /dev/null I cannot say that this thread has been great fun, so I think that I am done, let the "sad posters" keep share their immense wisdom with anybody but me! Cheers
As I read this thread, I'm now trying to figure out which issue is causing the burr under the saddle, the product(s) or the product support? I'm a simple guy, but it seems to me that unless extra $ was paid to a reseller for some level of warranty beyond what the manufacturer offers, you cannot expect the reseller to do much of anything! Now, for the sake of trying to cultivate some future business maybe the reseller could be a little helpful and talk to you or try to walk you through the setup to rule out operator error, and that would be nice, but that is not a responsibility on their part. You certainly cannot expect a reseller to fix or replace a product for free. Then there is the product itself not being of the quality you want or expect. If product quality is the issue, then it really doesn't matter which reseller you go thru for the purchase. For me, the lesson here is that when you buy a new product, you need to take the time to put it thru its paces and identify issues within the warranty period or forever hold your piece! Almost everything will fail eventually, and I've thrown away my share of failed equipment over the years. That is just the way it is....
I am new to the group. Curious if anyone is using the RT97L yet and what are your thoughts on it? Thanks!
This is correct. Anyone can send a message through the Hams. We do it al the time. It's our #1 task with ARES.
