  2. Today
  3. My Surecom will only test up to 525MHz so I can't get a power reading at 900MHz but I did test all the other frequencies. There's plenty of videos on YouTube about the RT-900 you can watch and I plan on doing one tomorrow to post to my channel. I'm also getting some properly tuned antennas for 900MHz to use because nothing I currently have is tuned for that frequency. Also, without actually getting one you can't just presume that it's junk. It's actually worked very well at 2M, 1.25M and 70cm hitting repeaters over 20 miles away with the Nagoya 320a antenna I have on it. I'd say pick one up and give it a try, what have you got to loose? At the most you've dropped $25 bucks on something that will work on several different bands and would be a good beater radio to keep in the truck or as a back up to your other radios.
  4. I was trying to reach a repeater that should have been nearby (in reference to it's mapped location) but not in sight by any means on my an older model MXT-400 (NOT programmable). I had spoken on another repeater (different frequency) that overlaps the signal of the one I was looking for and see if anyone could hear my transmission after changing frequencies. They could see my signal (Repeater busy) but could not heard any output from the repeater. I did some research on my unit and was reminded of the "Talk Around Function" allows one to talk to a group of other radios in case the repeater is temporarily out of range or no longer activated. This function allows "you to continue" using the RX/TX frequencies, PL, code to communicate with the group. That is how I understand it. I checked my Operations Manual and went thru the motions to insure this was not set for Talk Around on the frequency I was using and it wasn't. Could this function be set on another frequency and affectioning all the other frequencies? I wouldn't think so but.... Maybe I just need to reboot the whole kit & caboodle.
  5. If you can put it on a scope and frequency counter to verify that. Then the next test is output power. That I expect to suck. Trying to design a tuned power amp stage to have that kind of bandwidth is going to cost a lot more than $25. I know many people thought their D878’s could do 1.25M since they could program in the frequencies. However the real results at the antenna port just wasn’t there to make it worth the trouble.
  6. There is a 16 page thread on this subject over on the Radio Reference forum that got shut down today when someone involved with the proposal got snotty with everyone that pointed out the negatives about the proposal. I'm not saying that unused portions of the VHF low band do not have their uses. But it is not the beat all fix all solution to add it to GMRS as some think. All of us that have our amateur licenses know how fickle the 6m band can be even for local communications let alone long distance coms. I've used military FM radios on the 30-70 MHz all over the world. The VHF low band works in wide open areas with no local noise floor. But get into heavy forested areas and/or mountainous terrain and you will need some type of relay station to get out very far. And just like the 6m band, you would need a high power amplifier to get out over long distances. That isn't going to happen with hand held or mobile radios. Another issue is that law enforcement in some states still use that portion of the VHF low band as a backup system. I know Missouri still does. Again, I'm not against opening up a portion of the VHF low band outside of 6m. But we have to be realistic on how it will work and the downfalls of VHF low band.
  7. The farz was not a big difference, but it was about a 1/4 mile to less than 1/2 mile better for FM.
  8. I wasn’t challenging you specifically but the notion in general. Edited to add: Most people think of how far AM broadcasts carry compared to how far FM broadcasts carry, but the major difference between AM and FM broadcasts is frequency. AM broadcasts are Medium Wave, 650 kHz to 1640 kHz. At those frequencies the radio waves are much more likely to skip off the atmosphere. FM broadcasts are VHF and much less susceptible to skip. Also, AM is much narrower in bandwidth which makes it easier to be detected at farther distances. The difference in distance is not a function of modulation type. So, because they are using the same frequencies, AM CB and FM CB should not be greatly different in range.
  9. I wrote "may" propagate further and if it doesn't so what. What I was conveying is that with FM modulation I was able to communicate further than I could with AM modulation.
  10. Yesterday
  11. @OffRoaderX I doubt it's going to happen, too. But, I do still support it.
  12. Never gunna happen... Bookmark this comment and let's follow up in 5 years so I can say "told 'ya so!" ...
  13. OK. I got some 16mm self-tapping screws from Amazon. On the left is a 11mm screw from the KG 1000G and on the right is a 16mm screw from Amazon. Same thread pattern. self tapping screws.tif
  14. In my entire life, on any frequency, that has absolutely never been the case. From a scientific standpoint, it also doesn't make sense. The signal can travel the same distance, but you need more receive sensitivity (less noise) in order for the demodulator to extract the audio from the signal, compared to AM only needing peak amplitude above the noise floor.
  15. What would allow an RF signal travel further if it’s AM rather than FM?
  16. The point is to expand beyond short-range local comms, particularly for emergencies. 300w repeater systems would definitely help a lot in areas like what we are in here in the DC Metro area, the northern Mid-Atlantic and northeastern US. There was one 10m repeater that was at 100w that covered a huge amount of the area, but it's been off the air for years and GMRS isn't getting the job done for many families and EMCOMM volunteers. I support it and comfortably put it in the category of you don't have to use it if you don't want to. It certainly doesn't hurt anyone or the service to provide extra frequencies. Shoot... the biggest complaint I see/hear is that there are so few channels and the space is crowded in metro areas. Why not support it if it will reallocate unused frequencies and give users more options? (That was rhetorical, of course)
  17. Plus the fact that 46 or 49 MHz won't do any better than the 6m band currently does. I know because I have used 30-70 MHz all over the world while in the military. Most of the time we had to have some sort of relay station setup to get any kind of useful range.
  18. It makes a nicer stain.
  19. Not needed for a personal radio service intended for local ccommunications
  20. The AM signal may propagate further, but it will be noisier and not usable whereas, the FM audio will not be affected by the noise factor as AM thus you will more farz with intelligible audio.
  21. As some of you know, my friend Mike submitted a petition for rule making to the FCC to expand GMRS into some low-band frequencies. Ham Radio 2.0 covered an article about it and does a good job explaining the basics...
  22. That's why I drink Hot Cocoa.
  23. We're always looking for ways to make connecting with each other easier and more efficient. (Hell, that's kinda the nexus of radio communication, right?) On this week's Brentwood 600 check-in net, we announced two new web addresses that you can type into any browser, save in your bookmarks, or -- most importantly -- verbally give out to your friends who'd like to connect with and join this club. Either web address will take you directly to the club page. Why two addresses? Because some people remember shorthand and abbreviations better and other people recall descriptive words instead. So simply type in SCTNGMRS.com or SouthCentralTNGMRS.com into any browser to be brought back here to the club page. (capitalization are not necessary). Pretty nifty eh. Pass it along to your friends. Let's take this group to the next level.
  24. well, assuming your magnet mount used as a reference is using a different cable. I would start looking at the cable or connectors. And try moving your ghost antenna to the mag mount and check that. If you see the same poor SWR than the antenna is suspect.. Process of elimination is the game. Try reading in one set of circumstsnces than anoter as i suggested. It's not always easy to chase poor swr problems..
  25. i can't afford to give up any cafeene. The price of coffee is infringing on my radio Hobby ..
  26. Hello, I recently installed my new GMRS radio and getting high 3 to 3+ SWR readings using the Midland Ghost and the Midland 32" whip antenna in an open area. When I connect the magnet antenna that came with the radio, I have a 1.3 SWR. The NMO mount is 3/8 through hole and mounted in the center of my Tacoma roof. The radio is powered direct to battery both positive and negative. The base of the NMO mount has ground continuity with the outside threads of the PL-259 female on the radio. The mount has good continuity with the shield/outside and center conductor on the PL-259 at the end of the cable with no shorts. I do get a short between shield and center conductor when I screw on either antenna. I'm thinking maybe the coax was compromised somehow during installation and I'm facing pulling the headliner down again and installing a new mount. I'm in San Diego if anyone works on these things and would be happy to pay a professional to get it right. Any advice would be appreciated. Here's my setup: Arcadian MABVT8U: 3/8 Thru-Hole NMO Mount with 17 Ft. RG-58/U Cable MicroMobile® Ghost 3dB Gain NMO Antenna - MXTA25 MicroMobile® Whip 6dB Gain NMO Antenna - MXTA26 MXT575 MicroMobile® GMRS 50-Watt Two-Way Radio - MXT575
  27. (bluetooth) OD Master can't do a firmware update as far as I know. You need to be physically plugged in to do and update using the IAP software. The CPS software easily took off the stun/kill on mine. Not even a little struggle.
  28. So, if I can pry, @Jaay, what didn't you like about your h8? What do you like about your wouxon that the h8 failed you on? My new replaced h3 locked up on me yesterday as i had to keep it in my pocket as the belt clips suck period and I'm tired of it falling to the floor/ground with every movement. Couldn't find any help to unlock the kill lock with one unit only. So I hooked it up to my Odmaster online and it downloaded the new firmware without my acknowledgement and ruined this radio, like the firmware did to my original unit.. So now, even tho the radio is locked with s kill lock and no number for it in the manual, it is locked and with the new firmware installed, which locks the radio in transmit mode and won't stop unless you turn it off. I liked the conveniences of the small unit with both ham and gmrs. But now I am seeing more for sale and tested on youtube and they all look like they are manufactured in the same plant and just put different names on them. So, I am interested in hearing your thoughts on your h8 as that was going to be my next replacement, moving up to 10 watts as I can't reach the local repeaters where I am in missouri, south of st. louis. Have a great Thursday and thanks again for responding to my post.. Crazy WSDX855 To the others, I couldn't get od master to fully load up on the screen it was all grayed out, but it did upgrade the firmware which doesn't like older version radios. so now I am just waiting for the guys in china to get back to me today.. They do respond quickly, that I will say..
