yup.. could be a chrger too. Some people with big linears use chargers for whatever reason.
The more I think about this I think maybe you’re not really talking about an inverter but rather a 15 amp switch mode power supply, 110 volts AC input and 12.9 volt dc output. Is that correct?
lburbank joined the community
personally, I don't use networked repeaters.. Although i've had plenty of opportunity as there are quite a few out there, I shy from the practice because its not legal.
Welcome. Sounds like you’re doing everything right.
SteveShannon reacted to a post in a topic: Repeater network navigation
WSJI201 changed their profile photo
PRadio reacted to a post in a topic: Dear Mr President Trump...
I have 3 of them, all work fine. I just make sure I take the battery off to charge it.
Will it lower your output power? In my experience, it often does. Will it lower it enough to matter? In my experience, no.
Hey y'all I'm about 48 hours fresh into my GMRS license so please bear with me as I likely touch the third rail. Although I plan on spending 90% of my time on simplex there's a few spots in my area where I'll be graciously utilizing my local repeater. Within my short time with a license I've discovered that several of my states largest repeaters are connected. Double edged sword because I've actually chatted up a bunch of people all over my fairly gigantic state today. It's been pretty awesome, really nice people and I could totally see myself nerding out on the network. The other side of that sword is that I've read over and over again that GMRS traffic is slow to non existent these days. Not that I was happy about that, but as I was looking to mostly try and communicate with my wife and daughter a handful of times a week with this that actually sounded kind of nice as that was a chunk of the appeal to the whole family license. It's not that either of them would mind as everyone I've heard on the radio has been nothing but polite and G rated, but then I also don't want to be ruining other people's good times with my seven year old checking in with me here and there. So tl;dr the entire state network is awesome but now I feel like using a local repeater feels a lot less local. Trying to be vague as I'm certainly not looking to put a spotlight on any particular area but just wanted to see what the thoughts were amongst the crowd here. I've been lurking for a couple months and the community seems awesome so thought I'd seek opinions. PS, I'm obviously really green in this space so please fill in the likely canyon-sized holes in my knowledge if I'm missing something. I have transmit and receive tones of my local repeater programmed but still get everyone.
SteveShannon reacted to a post in a topic: Volts
It really depends on the design. It probably will still be enough. Just hook it up and see.
A lot of power supplies have an adjustment for the output voltage that ranges up to 15%. Does your supply have an adjustment? Post the model power supply and where it came from and we may be able to help you find an adjustment screw or give you better advice on what to do. I
I bought an inverter for 110v to Dc 15 amp for my 20 watt mobile. When I plugged it in it shows 12.9 volts. Will this lower my output as the vehicle outputs 13.8 volt.
207 joined the community
Can the Anytone AT-878-UVii still be unlocked for GMRS?
WRUE951 replied to WSJL659's question in Technical Discussion
As of last April. Yes -
Wow, check out this big bruit battery from Baoefeng and the price. https://www.baofengradio.com/products/battery-5200mah-bl-5rhplus-usb?utm_source=Klaviyo&utm_medium=email
WSEI546 joined the community
BoxCar replied to marcspaz's topic in General Discussion
The FL DOT was a big user of low band VHF but found the supply for new mobile radios dried up. Their last supplier, some 10-12 years ago, was Midland. Before that I believe it was GE and Vertex, -
SteveShannon reacted to a post in a topic: 900mhz range question
SteveShannon replied to WSJL659's question in Technical Discussion
Adam, When you use the CPS for the radio there’s one place where you can set the range of the radio. What choices do you see there? That should answer your question. -
nokones replied to marcspaz's topic in General Discussion
I'm not sure what happened to the hundreds of the conventional (non-simulcast) GE Master IIs that were taken out of service several years ago in California and what make stations that replaced them a few years ago. The replacement stations may take a while until they are taken out of service because of migration to 700 MHz system. Also, there are almost a hundred Micors Simulcast and about 50-60 Quintron Simulcast stations that were taken out of service. However, these simulcast stations do not have the local CTCSS encoding modules for these stations because the CTCSS was centrally generated from the control point. Good luck in trying to obtaining the parts. These stations were not repeater stations. The mobile inbound (voted audio) traffic was rebroadcasted from the control point and the receivers used a separate antenna than the transmitter antenna with vertical separation. The stations were either 39, 42, 44, or 45 MHz transmitting stations. A lot of cavities and intermod panels had to be used -
WRUE951 replied to marcspaz's topic in General Discussion
right now relatively easy and kind of cheap. I'm sure everyone will be building repeaters but if this approves current off the shelf will be just that. "off the shelf' Gone.. Like Mark says, the duplexers are giants and i remember a time whan they were thrown away as junk.. I can lithely remember Placer County tossing them after trying to give them away.. Those days are gone. Now you can't find them. -
The mystery of the MXT-400 that can ....Talk Around Feature
H8SPVMT replied to H8SPVMT's question in Technical Discussion
MIDLAND said: "When you enable the Talk Around function, it only affects the individual channel you’re on—not all channels at the same time. It uses that channel’s RX/TX frequency and its stored Privacy Tone settings, so you can chat directly if the repeater’s out of reach." And if that is the case, I don't think the problem is with my setup. I am inclined to think it is the repeater then. -
Turn off the Music (or tones) on Startup
OffRoaderX replied to steved52's question in Technical Discussion
You can't. -
marcspaz replied to marcspaz's topic in General Discussion
This is almost all there is in the amateur community. If people want it, they will spend the money and find a way. Also, I doubt any companies will tool a new radio for low-band GMRS, because most HF amateur radios already transmit on all of these frequencies. I guarantee you, if the market opens, damn near every HF amateur radio manufacturer will spend the very few dollars needed to have their engineers write new code to limit existing radios to the low-band GMRS specs. The duplexers are pretty big... about 86" tall. However, the bigger they get, the easier it is for a DIYer to make one. -
H8SPVMT reacted to an answer to a question: The mystery of the MXT-400 that can ....Talk Around Feature
WRKC935 replied to marcspaz's topic in General Discussion
From a technical and hardware standpoint. Where are the radio's going to come from? While some hams bought up the low band commercial gear for ham use, most of that has flushed through and is gone. Repeaters..... There haven't been low band repeaters built since the days of the MICOR, at least by Motorola. They had tube finals that are now obtainium. Yes, I know 3 guys are gonna pop in here and talk about the 4 they have on the shelf. So that's 12 tubes. Where are the rest of them going to come from? So then it's NEW radios. From a new source. No one on the commercial front is producing radios any more, and unless they ca see selling millions of them, none of the big commercial guys are gonna go back to that. And even if they did, you're talking about radios that will be over a grand to purchase. So then you have the chi-com stuff that will need to be filling the void. They don't currently support the platform. The dual band and single band chi-com radios that are in the pipeline are the same radio they produce as the UV-5R and other common chi-com radios. They are HIGH BAND VHF and UHF. And that appeals to a number of people. Even they aren't producing VHF -LOW transceivers. So new product for how many people? Remember that you can decorate a Christmas tree with Baofengs for less than the purchase of the tree, on sale. Everyone bought a number of them and they toss the guts in a new case, toss some better firmware at it and give it a new model number and they flock. If it's JUST a GMRS radio, and I am betting that the FCC will be watching, it's not gonna be 40 bucks for a portable and 125 for a mobile. And have you ever SEEN a duplexer for low band VHF? Let alone priced one. They are HUGE, and they carry a HUGE price tag. I don't know that the GMRS community is going to take to repeaters costing 10 grand or more with a duplexer and antenna, and 500 dollar mobiles. Oh, and Low Band antenna's.... that's not going on a 1 1/4 inch mast pipe on the end of your house either. And repeater / real base station antenna's are 40 plus feet of vertical real estate. But the bare minimum 1/4 wave is still 8 or so feet. And that's gonna be unity gain. Honestly, I see this as an idea by someone for a radio service that doesn't really know radio. -
RoadApple reacted to a post in a topic: TID H3 - H8 USERS UNITE
Radtel RT-900, more than just a Dual Band Radio.
TNFrank replied to TNFrank's topic in Equipment Reviews
LOL, thanks for pointing out that I'm an IDIOT. Do you treat EVERYONE who makes an honest mistake like this???? P.S. The Radio actually DOES work on 6M, CB-FM, 2M, 1.25M, 70cm, MURS and GMRS and I'll post another video to PROVE it to you. Love ya' Bro. -
RoadApple reacted to a post in a topic: Ham Radio 2.0 Coverage of Low-band Channels for GMRS
WRXL702 replied to TNFrank's topic in Equipment Reviews
IMO - Folks Should Do Some Real Research On A Radio, Before Putting Out A Bogus / Nonsense YouTube Vid. This Type Of Junk Does Noting But Confuse New Potential GMRS Users. Some That Just Recently Purchased A Ham License & Now Seem To Be RF Experts, Are Putting Out Vids & Disputing The Manufactures Specifications On Their Products. Really......... -
Tidradio H8 does not save DCS I codes as I and switches to N
bladeofanduril replied to WSJM270's question in Technical Discussion
I noticed this as well on a H8 Gen 3 when I programmed the tone manually on the radio.
