WSHT327 joined the community
Sab02r reacted to a post in a topic: KG-1000G Plus Coversation Starter - Chirp Profiles and Unlock on other Bands?
Seapup reacted to a post in a topic: Another Contesting Question
LeoG replied to OffRoaderX's topic in Equipment Reviews
Copy and paste is your friend. That was the only way I could get anything in there. Low power on the repeater is 5 watts I believe. -
Sab02r reacted to a post in a topic: Battery Backup
WRTC928 reacted to an answer to a question: “High End” antennas worse than stock?
WRTC928 replied to OffRoaderX's topic in Equipment Reviews
That's interesting. I can't enter anything into rows 9-16. I'd like to do what you did. After I posted, I realized that it could actually function like a base station. Since a base station exceeds the power limits for channels 1-14, it functions on 15-22 anyway. It won't scan, but otherwise it will function like a base station; i.e, transmit and receive on the selected frequency without having to use the repeater function. -
wayoverthere reacted to an answer to a question: “High End” antennas worse than stock?
Rde9771 joined the community
Where did you find that on the ARRL website? I used their search function and found nothing other than mentions. Thanks!
SteveShannon reacted to a post in a topic: Another Contesting Question
Okay, found this definition on the ARRL website: Actually, after everything I have read in the ARRL 10M Contest Rules pdf and learned reading other ARRL website stuff, I probably should not have responded to his CQ. I was not in the contest and so would not have submitted a log to ARRL, which they would have compared to his log. So he would have lost the QSO. So this rookie has learned a lot today. Thanks for all the input and help!!!
THE FCC PERMITS LANGUAGES BESIDES ENGLISH?
UncleYoda replied to JHENRY's topic in FCC Rules Discussion
I think some of us do know the relevant regs (ham and gmrs for me) and understand them fully to the point the wording is clear. We obviously can't know what isn't there. But that is not due to not reading or not understanding the language. Courts interpret any ambiguity in contracts against the author. Applying the same logic to regs, it's the agency responsible that has to make the regs clear, not for us to use a crystal ball. Socal may come across abrasive to sensitive folks, but he is right that not enough newbies bother to learn before bugging eveeryone one else with questions that would be answered just by studying the rules. And RTFM (reading the fine manual) for their radios. -
UsLs1 joined the community
Welcome from another newcomer! From what I've read/watched, you'll probably be really happy with those TD-H3s.
Which is exactly the how the comm went. I think perhaps (after scanning the ARRL pdf page 3 item number 4.3) looks like a "foreign" DX station is sending some kind of serial number. Perhaps he thought I was in the same boat as he. But we did exchange callsigns, I sent him a 57 and "Delaware USA" as I normally do with a DX station.
WSHW991 joined the community
That’s how I read it also.
WTF0292 joined the community
So if I have this correct Steve, OP would have responded with “call sign” then 59 and DE.
WSHX800 joined the community
Here it is, from ARRL: Good morning, The serial number is a sequential number, starting with 1 for your first contact, 2 for your second contact, and so on. In the case of the 10 Meter contest, stations located in the US, Canada, and Mexico send their state or province abbreviation, not a serial number. In the ARRL International DX contest, as a US station, you'd be sending a signal report and your state abbreviation. It's customary to just give a 59 (or 599 if CW) as a signal report and then your state. The DX stations will send a signal report and their serial number, when then goes in your log for cross checking (we check to see if you receive the number they sent you correctly by comparing the logs.) I can add that term to the glossary which is located at the end of the contest rules PDF files on the ARRL website. 73, Paul Bourque, N1SFE Contest Program Manager
Check youdtube as well, there are tons of radio specific videos out there.
Yes. I think @WSEZ864 probably nailed it but it should still be defined somewhere easy to find.
Thanks Steve. I will download the pdf and read through it. Good idea to get a definition for serial numbers added, for us newbies.
Welcome and happy GMRS ing.. Family, friends, enemies.. whatever, just have fun and enjoy..
Welcome to the forums! I hope you enjoy it.
Thank you. Good info.
Correctly? You can use it to talk to anyone who will listen & respond.
Welcome. Gmrs really is ment for friends and family/people you already know to use while doing an activity. So do you know people that you do things with such as hike bike off road parks hunting ect…….. if using Gmrs correctly you will never be a voice in the dark.
Welcome To the forum @MarkTheNewf
MarkTheNewf started following Hola
First post and relative radio noob. Have a couple of rarely used MURS HT and a Meshtastic solar node on a 30 ft tower so I fgured what the heck: GMRS. Got my license and have a couple of TD-H3 radios en route via the almighty Amazon. My searches only show *maybe* one repeater in range, so I might be a lone voice in the dark out here! Anyways, good day from out past the Brazos River!
MarkTheNewf changed their profile photo
MarkTheNewf joined the community
WRUE951 replied to JHENRY's topic in FCC Rules Discussion
Personally, i don't care what language is used.. A lot of people do for whatever reason but i find this is why the ch knob was invented. -
SteveShannon replied to JHENRY's topic in FCC Rules Discussion
Hopefully people won’t get too wrapped up in recreational use of radio, but with the official language decree I could see court orders going out against any business who discriminates against someone who is using English. -
about two years ago i was making a trip to Bass Pro with some friends i was visiting in Glendora. My brother was meeting us there, we was coming in from opposite direction. We were using a 'local' repeater to communicate then jumped over to Ch 7 when we got close enough. When we started talking, no one was on their air, we soon got jumped on by two spanish speaking individuals. Two of the guys with me from Glendora speak Spanish fluently. They were relaying what the two spanish guys were calling us gringos.. quite comical once the two spanish guys got hold of the mic. I think the guy with the local repeater even made a few comments. -
GrouserPad replied to JHENRY's topic in FCC Rules Discussion
