amaff reacted to a post in a topic: "Illegal" radios
WRUE951 reacted to a post in a topic: "Illegal" radios
Yup,, I've got a medicine bottle full of them.. And they get used as a first choice when possible.
H8SPVMT replied to SvenMarbles's topic in General Discussion
I wore greens as well but in the Navy as a Bos'n Mate / Salvage Diver. We used nicknames instead UNLESS you were in trouble! -
None of my very expensive Hytera DMR Radios came with a programing cable.. And those cables were almost as expensive as buying this Baofeng Radio.. The DM32 uses the standard Baofeng program cable. Like i said, i had a ton of them at one time..Funny how the cheap cables tend to get lost and missplaced but that never happens with our $50 cables.. I've never misplaced any of my Hytera program cables, they have a special place unlike my Baofeng cables that are stashed at every corner
H8SPVMT reacted to a post in a topic: Over use of call sign announcements on GMRS
WhiskeyRye654 joined the community
Why would you need a PA for? In most communities it is illegal to use a PA in a vehicle if you are not Public Safety.
There was quite a bit of silly nonsense stuff going on early yesterday morning on Shaw Butte, and both Towers repeaters. I think I might have heard something on the 650 channel. It appeared to be simplex traffic since the repeaters are still down and signal level of this nonsense appeared to be at the same signal level at location I was in.
I can't imagine it being very useful. I don't think even most CBs include it anymore.
Once you receive your DM-32 please try this exercise and report back: You are having a QSO on the Worldwide (91) chat group. The other station suggests freeing up WW so that others can use it and asks you to continue the QSO on his local chat group: the Catawba Valley DMR 31678. Will the DM-32 allow you to immediately switch over to and communicate on 31678 without having to program that Talk Group into the radio either ny hand or computer?
A shame that a radio as complicated as DMR does not come with its programming cable included. I suspect that, similar to the Baofeng DM-5R and DM-1701, the chip is already in the radio and the USB cable is just a passthru that does not include a chip.
WRUV311 joined the community
WSHZ217 joined the community
Just curious, but why don't GMRS mobile units have a PA option like some CB radios do?
Just wanted to say thank you to those who got us going in my gmrs. Thank you for resetting and it’s worked perfect since! Thank you!
What radios do people use for MURS?
Lscott replied to Lscott's topic in Multi-Use Radio Service (MURS)
That's about it. -
Lscott reacted to a post in a topic: "Illegal" radios
SteveShannon reacted to a post in a topic: New to GMRS
SteveShannon reacted to a post in a topic: Welcome!
At least the battery is included.
SteveShannon reacted to a post in a topic: "Illegal" radios
Anyone can report interference or non-compliance. The FCC seldom (never?) does anything about GMRS. I have no idea if many reports are made about GMRS. I know virtually no actions have been taken against GMRS users. I have no idea why a ham would be disgruntled about GMRS. I participate in amateur radio and we simply don’t often discuss GMRS often. Probably about 20% of us hold both licenses. There certainly are “sad hams” but most hams are not them. In fact many of the people who complain most vehemently about GMRS users breaking the rules aren’t even hams. I’ve seen many more radio professionals complain about noncompliance in GMRS than I have hams.
LeoG started following Wouxun KG-1000G faceplate screws
M2 self tapping for plastic.
This is just my opinion and by no means intended to be legal advice, but I have to agree with Randy and others with the same type of response. It seems that unless someone is committing some wild infraction, they aren't getting FCC attention. There are way too few enforcement agents and way too many people with radios for anything else. I used to think it mattered, but time and inaction have unequivocally proven otherwise. I have an XTL5000 that has the ability to run wideband digital encryption on UHF at 115 watts. From a technology standpoint, it exceeds every single minimum requirement established for type approval. If I where to program it to transmit 20w of output, only able to access the upper channels for high power simplex and repeater operation, narrow-band analog voice only, adhere to all of the other configuration requirements (including not transmitting on non-GMRS frequencies) and the FCC enforcement team knew I did it... I highly doubt anyone is going to care. Shoot... unless I were to get on the internet and start bragging about it, there isn't even any way for anyone to know. Signal interception sure isn't going the tell anyone anything. The bottom line is, I would never advocate or condone intentionally violating the rules... but damn dude... the FCC has way more important things to worry about then if you are using an iCom, Kenwood, Motorola, Yaesu, Harris, Baeofeng, TIDRadio, or any other radio. Ensure you don't cause harmful interference by using a quality radio and not acting like a Richard Cranium and im pretty confident if you roll the dice, you won't go to prison or get a $14,000 fine.
No. These are not standard metric machine screw sizes. Under magnification the screw threads look like sheet metal screws or wood screws with the screw pitch much larger than machine screw sizes.
Unfortunately, all the non-member good repeaters are down in Phoenix area, don't know for sure why but I think I know.....Ug peeps always ruin a good thing.
WRHS218 replied to SvenMarbles's topic in General Discussion
I worked in a rendering plant when I was much, much, younger. -
Brown. My socks are brown. -
i had a couple and just found them after the fact. This is how you collect program cables.
I hate it when you have to orfder the cable separate.
