CentralFloridaGMRS changed their profile photo
WRYZ926 reacted to a post in a topic: Process of Starting a Repeater
M5Fan joined the community
He’s full of it. The license is in only one person’s name but all immediate family members are allowed to use that call sign.
Last time I checked the US military is still using 30 MHz to 70 MHz. I know we used that section all of the time when I was in. Low band was 30-50 MHz and high was 51-70 MHz. And the 6m band is not called the magic band for nothing. 6m is either open or it’s not. And it doesn’t matter if you are using FM AM or SSB. 6m FM won’t get much farther than 2m will
I was chatting with someone on one of the local repeaters, he said that I need to update the FCC with all persons using my license but I can't figure out that on the website. With that said, does anyone know how to do this? My apologies if I was misinformed and this is all incorrect.
WRPL700 reacted to a post in a topic: Just passed my General class test on Saturday!!!!
Evolricy reacted to an answer to a question: Recs on suggested equipment to purchase
amaff reacted to a post in a topic: Off Roading
Maybe it is the CCRPs that is the problem.
WSGS489 joined the community
WSIB991 joined the community
Squirl joined the community
WRWE741 joined the community
Wouxun KG 1000G Modulation problem
SteveShannon replied to lakemen's question in Technical Discussion
Make sure your compander is turned off. It’s menu 36. -
slight delay on reception of signals
Radioguy7268 replied to WSCQ874's question in Technical Discussion
I have seen certain PL/DPL codes that cause issues with some radios. If you can see the receiver LED is active before you actually start hearing audio, try switching your radios to a different PL code on the same freq & see if the problem goes away. For most of what I saw, it was usually the lower frequency PL tones (below 80 Hz) that were the ones that caused problems. -
an issue with a woxoun? No way? They are supposed to be handing down from the gods to man There is NO way a woxoun has any issues at all. Must be totally user error.
How to create a Club for my repeater.
rdunajewski replied to WSFE961's topic in FCC Rules Discussion
@WSFE961 I fixed your forum account so it shows the premium user group. This sometimes happens if you create your forum account after you sign up for the membership, sometimes the group doesn't get applied properly (a bug in the forum software we use). -
WSHE916 joined the community
No updates that I know of. Unfortunately there is no mic gain adjustments on the KG-1000G and the mic is definitely hot. The best thing is to make sure to hold it at a slight angle when transmitting.
What is better to use DTCS or CT codes?
GrouserPad replied to Mrsig's question in Technical Discussion
G.O.R -
GrouserPad replied to WSCQ874's question in Technical Discussion
We have these problems with frs radios at work. The people using the radios don’t know how to properly key them up before they start talking. (And for the record I tried to talk them out of frs and into Murs so not to take up an frs frequency but they didn’t listen) -
Any updates to these kg1000’s sounding a bit over modulated ? Mine is getting occasional reports of it sounding “too hot” or too much mic gain or puupuupuu thhthhthh ish when talking on it. I don’t want to hold the mic 12” from my face when mobile and frankly don’t like doing it from a base either. Purchased it 5 or 6 months ago…..
I guess when I get a boring moment, I'll snap some photos of my racecar communications and post them. I've done several racecar comm installations in the past and yes on a occasion or two, installations with mobile radio setups because of the unique application requirements.
SteveShannon replied to WSCQ874's question in Technical Discussion
Is the other person using vox? Vox acts upon hearing a sound and as with everything the time it takes to key up can result in the very first sound being lost. If it’s truly a measurable delay from the time a sound is transmitted until the time it’s received, any humanly discernible delay would not be in RF reception, but delay could easily occur if any digital processing occurs, either at the transmitter or the receiver, or both. The other thing is that it’s always best to wait half a second after push PTT before speaking. -
If you are tracking your race cars on oval or typical road courses, a mobile radio is not the hot set up. You would be better off with a portable radio and an external antenna. If you were racing off-road or La Mans whereas there are miles between the driver and the crew/pit then a mobile radio would be the set up and the pit with a raised base station antenna and maybe a portable repeater at a higher elevation point. In the video, the radio was not installed in a good location. Reaching over to your side or behind you during a session on the track is not the ideal thing to do under those conditions. That would be a total distraction and may cause you to make a furtive movement in your driving. That installation was a very poor choice. The antenna mount should have been a NMO mount with either a Phantom, quarterwave, or a low profile blade antenna. The XPR mobile radio was also way overkill for several reasons. You don't need a 1,000 channels, maybe a radio with a channel capacity of not more than the total number of itinerant channels that would be licensed for would have been the smart choice. Maybe something like a Motorola CM200D or 300D or even a Kenwood would of been a better choice and a lot less money. He probably paid at least $1200 or $1300 for a radio that he didn't need. In my opinion, the video is a good example of how not to install radio communications in a racecar.
I don’t think so. You MAY from what I understand be able to totally reprogram the software firm ware to be a ham version of some other radio. it’s much easier to buy a ham radio that is already open or very easily opened to gmrs.
My GM15 radios have a slight delay on receiving the words of the other person transmitting. I often miss the first syllable of the person speaking. There is a slight, almost one second, delay in RXing. My POWER SAVE is set to OFF Is this problem inherent for these radios? My BF-F8HP does not have this problem Thanx, Neil
Is there a way to open up the gm15 for ham radio frequencies. ?? I have read that some other Baofeng radios can be unlocked for ham radio Thanks, Neil, w0yse
Fire8400 joined the community
How do you know they are not saving? Have you tried activating a repeater?
Race enduros on Dirtbikes. I keep a uv5g in my pack(rarely cell service) and leave another one sitting in my pickup bed volume up. If my buddies finish the race before me because I’m broke down or something they know the radio is there and I can let them know what’s going on. Sometimes we car pool to the races and it’s a bummer when one guy doesn’t get back in a normal time and we all wondering if they are ok.
WSIA972 joined the community
HA! I commented on that video. You can get a similar result for <$300. Well, maybe not at current prices. But that's about where I am for a single car, pit-to-car setup, with super-het radios. Those Racing Radios are *usually* business band radio. I like the stuff he builds, but for a guy always talking about how broke he is, he sure seems to like throwing it around lol For the grassroots racer, it'd be cool if someone at that level would show normies how to do it for more reasonable money IMO. That system costs more than all my radio gear combined.
Are you saving the file after editing it? You might try saving your edited files prior to uploading to the radio.
WSDV256 replied to WRPL700's topic in Amateur Radio (Ham)
Congratulations!! Sent from my iPhone using Tapatalk -
WSDV256 started following Just passed my General class test on Saturday!!!!
SteveShannon replied to WRPL700's topic in Amateur Radio (Ham)
Thanks! Another resource is HamStudy.org. That’s what I used when I started. They are free, but you’re welcome to donate if you want and they do have an app they sell for a low price for your phone or tablet. -
WRPL700 replied to WRPL700's topic in Amateur Radio (Ham)
Steve is absolutely correct about the tests. If I can pass the Tech with a 35/35 and the General with a 35/35 then anybody can do it. They have some great tools for people to use to study for the exams (hamexam.org) is what I used (which someone here suggested.... thank you!). Ham is a great hobby and I am glad I did it.
