WQYC236
    30
WQYC236 last won the day on March 9 2018
WQYC236 had the most liked content!
    Castleton, Virginia
  • Interests
    Radios, metal detecting, scuba diving, aviation, self defense & survival training.
782 profile views
WQYC236's Achievements
Newbie
Newbie (1/14)
79
Reputation
  1. Welcome Pat!!
  2. One other question...do most NMO antennas have a water proof plug option for going through the car was or pulling in the garage. I'm running a 5/8 wave, 2 meter mag mount on my Outback now and it's pretty tall.
  3. Thanks to everybody for all the great information and the technical explanations of "why" the NMO makes perfect sense. When I do mine I will be picking your brains on how to approach the whole project. I know there's a lot of information here on the site already but you guys are filling in the blanks. I was especially interested to hear from the professionals out there who have the first hand field experience. Thanks!!
  4. I hear a lot discussion about the superiority of NMO over Mag Mounts. It usually ranges from very little difference to NMO being a vastly better performer. Those using mag mounts say that if the magnet is big enough and the capacitive coupling solid that there is very little difference. Those with the NMO's say that you can't get a good ground with a mag mount. My question is does anyone have any hard data showing how much improvement can be obtained by drilling a hole and solid mounting the antenna? Someone must have studied this at some point in time or performed some experiments. Thanks! Sasquatch
  5. I know this is an older post but I was just looking at the rabbit trail again and marveling at the unresponsiveness of the FCC to clear violations, with documentation. If manpower and resources are the issues, I really wonder how they prioritize what they can respond to?
  6. Try not to get too discouraged with all the technical terms. It just seems overwhelming at first, before long you'll be dropping MHz bombs like a pro. Something that helps me is to just pick a couple of technical terms and do an on line search for a simple explanation. Eventually it will begin to make sense.
  7. Excellent points from all concerned! LOL!!
  8. My family is scattered out to about 25 miles away and the three kids use my license to keep track of each other in bad weather etc. We basically set it up as an emergency back up communications system that would cover the three towns where they live. With the local repeater up about 1200 feet we can stay in touch for about 60-70 miles mobile to mobile. If the repeater goes down (as in an EMP/CME) we all have a "hill" within walking distance of each home that would still allow us to make contact once a day at a pre-set time.
  9. I think that I'm going back to two tin cans and a long string...at least I know where I stand with that communications device.
  10. This is the perfect venue for all of us to make sure we don't interfere with each other and also to determine if a new repeater is actually needed. I know of people who put up a repeater and then discover that one already exists. We have recently encountered a new repeater in our area on the exact frequency and PL code as a long time existing Red Cross and REACT repeater. Fortunately nobody seems to be using the new repeater right now but if it gets busy we are going to have big problems. I use the "Seven Corners" repeater to talk to my son on the last five miles of his trip to work in DC since the "Warrenton repeater" usually fails at about that point. Now however I can't do that because I'm too close to the unlisted repeater on the same frequency and PL!
  11. Sorry for the late reply but my other activities have kept me busy. Anytime you want to try a long range DX experiment send me a personal message and Ill see it on my cell. Sasquatch!
  12. Hello and welcome to the GMRS world and the web site. I'm in Castleton, VA about 55 miles from DC and there isn't much traffic in this area either. If I go into Culpeper or Warrenton, two small towns near me, I hear more traffic but out here it's pretty quite most of the time. I scan ch 1-7 and 15-22, plus about 8 repeaters in my area. Looks like you are a long way from everywhere down. Just for fun I could drive up to a high point on Skyline Drive, the mountain ridge about 134 miles NW of you and we could see if we could talk. Sasquatch
  13. MURS channel 4 is the weapon of choice for our local "Wally World" . It gets pretty annoying sometimes but at least they are using an unlicensed frequency.
  14. What's confusing is I used to be able to talk for at least 30 minutes with out any problems and that was with an older, lower capacity battery. The issue seemed to show up after the two Motorola's were programmed this last time. We added some frequencies, checked the power output to a dummy load, and also checked the frequency alignment. Everything looked good. I'm wondering if the CDM 1550 LS+ series has an internal adjustable set point for the low voltage alarm? Maybe that inadvertently got changed to a higher voltage number. Does that sound reasonable? I have also been considering what you are suggesting with a duel battery set up, more so for emergencies than just my convenience.
  15. It's the highest capacity battery that will fit in the vehicle, are you saying I need some special type of battery beyond a high capacity car battery? Everything is fused.
