46
Everything posted by WRYZ926
I get my Wouxun KG-1000 G Plus Mobil Today - Base Antenna Discussion
WRYZ926 replied to Tiercel's question in Technical Discussion
I can't answer that question since I have not used that brand. The Mcbazel Surecom SW-102 Digital VHF/UHF 125-525Mhz Antenna Power & SWR Meter is a popular choice and is $24 more than the one you linked to. GMRS and amateur radio can be addicting. I started getting everything together for my base setup before I received my technician call sign. I now have a mobile dual band radio and GMRS radio setup in the house and both setup in my vehicle now. -
@WRZM228 I would think that 12 foot of cable should be long enough for your Prius if you are using a radio under the seat with a remote head unit. I am using a magnet mount with 12 foot cable in the middle of the roof on my 2023 Ford Escape with the coax running back and in through the bottom of the hatch back opening. I ran the cable along the door sill trim and still have plenty of cable to reach under the driver's seat. -
Congrats @Tiercel on passing your test. Now the wait to get your call sign begins. It took me 12 days to get my call sign after I tested. -
The link for that Laird antenna shows it being 11" long which would be good if you are worried about clearance issues. Here is a Laird GMRS antenna that is 33" long. https://www.arcantenna.com/products/gmrs-mobile-vehicular-antenna-base-loaded-chrome-coil-rugged-no-ground-plane-required-with-spring-rbc-450-5-ns I am currently using a Tram 1174 on a magnet mount on my Ford Escape which is 13 1/2" long and it seems to be working well. https://www.buytwowayradios.com/tram-1174.html -
I agree with @Sshannon that the Comet 2x4 is not the ideal antenna for GMRS. Dual, tri, and quad band antennas are a compromise in that they work on different bands but they don't do well on all of them. My brother has a Comet 2x4 that he uses for 2m/70cm and it is a good antenna for those bands. The SWR checks out fine at 462MHZ but is high for 467MHz. You could use it for GMRS but there are better options. -
I used one of the clamps that came with my Comet CA-712 to hold the ground wire in place on the j mount and then ran it down to my ground rod. -
I know off topic a bit. But I am lucky that I live 20 minutes from Graf's Reloading Supply and I am 60 minutes or less from MidwayUSA, one Cabela's, two Bass Pro Shops, and several Academy Sports stores. This biggest problem with USPS here in Missouri is the distribution centers in St Louis and Kansas City. They just can't seem to do their jobs correctly. It is rare that I have an issue with FEDEX or UPS.
I prefer UPS too. I understand the economics behind FEDEX and UPS transferring packages to USPS for final delivery. But with anything in life, too many cooks can ruin the meal. An example for what I do when ordering stuff from MidwayUSA is to include a box of ammo or other items that must go ground shipment so that UPS is the one that handles everything from pickup to delivery. Of course I will just drive to MidwayUSA and pick things up if I need something in a hurry.
I looked up reviews for the radio and all of them seem to be older from 2016 and earlier. The AT-5888UV does seem to have good reviews even if the reviews are older.
USPS had a major mercury spill at one of the St Louis distribution centers, or so they say, at the beginning of the month. I watched some of my packages bounce between the two distribution centers for almost two weeks. I don't care for FEDEX that much either. While I have not had any packages damaged, they have drove right by my house several times without delivering my packages. The last time that happened, I insisted the driver search the truck again before driving off. Low and behold, she found my package. And sometimes it will depend on the driver too. I have had good drivers from FEDEX, UPS, and USPS along with horrible drivers from all three. One of the worse methods of shipping is when FEDEX or UPS transfers packages to USPS for final delivery.
One "Uh OH" tends to wipe out ten "Atta Boys". FEDEX and UPS generally do a good job in my area. USPS is a totally different story with the two distribution centers in St Louis.
Antenna height and length of coax hypothetical question.
WRYZ926 replied to WRZI712's question in Technical Discussion
I have to agree with @kidphc on this one. You might not notice a difference in a 30 foot or shorter run but why hamper yourself. With any antenna, height is king. Always use the best coax you can for the best performance. But height won't make up for the wrong type of coax. -
I would go with option 2 unless you can get your antenna higher. And you won't have any problems with LMR400 over a 20, 35 or even 50 foot run. -
Tri-Band Antenna for Baofeng UV-17R Pro GPS
WRYZ926 replied to back4more70's topic in Amateur Radio (Ham)
I have no experiences with the Comet or Diamond tri band antennas so I won't be much help there. I have been very happy with the Nagoya 771 and 771G antennas on my Baofeng GT-5R dual band and UV-5R GMRS HT's. I doubt that you will go wrong with either antenna. -
You did a good job on the presentation and making things easy to understand.
That can be said about a lot of different products from radios to audio amplifiers or even generators. Most manufacturers will advertise the peak power rating instead of the continuous running power rating. And I have to agree that using a meter will tell the true story. We have seen different radios be below the stated power and some above the rated power.
Here is a tri band 2m.1.25m/70cm Nagoya antenna. https://www.amazon.com/Nagoya-NA-320A-2M-1-25M-70CM-144-220-440Mhz-BTECH/dp/B01K10B9XK/ref=sr_1_1?keywords=tri%2Bband%2Bantenna&qid=1700346610&sr=8-1&th=1 -
It's always good to have both GMRS and amateur radio to use. We are getting our amateur club to install a GMRS repeater so that we have an addition method of communications for emergency situations. -
The tests aren't hard to pass. I took the technician test in October and am currently studying for my general. Here is a link showing what bands each level of license can use. http://www.arrl.org/frequency-allocations If you want to use all of the allocated HF bands then you will need a general or amateur extra license. -
I am very familiar with making and using network cables. I just tested the Wouxun KG-1000G connection cable and it is not wired the same as a standard network cable. For those interested in making a custom length cable for their Wouxun KG-100G here is the pin outs. 1 - 1 2 - 2 3 - 3 4 - 4 5 - 7 6 - 6 7 - 5 8 - 8
First welcome to the forum and to GMRS. @WRZE995 brought up some good points. You can get started on the cheap with a Baofeng hand held, from there the sky is the limit. I will say that an outside antenna on your vehicle will help any HT (hand held) have better range versus trying to use the stock antenna inside the vehicle.
@WRUZ229 That is good to know for those that own the MXT575. I asked because a lot of radios with remote head units use a different pinout for the connection cable.
Well since I started this thread asking about antennas, I should post a photo of them. Does the Midland use the standard Cat5 pinouts or did you have to swap any wires?
I am interested in the KG-Q10H and KG-Q10G so I will be watching this thread. Right now I have a Baofeng GT-5R dual band and an Explorer QRZ-1 dual band along with a couple Baofeng GMRS HT's and am looking into getting better HT's.
