WRUW493
Everything posted by WRUW493
WRUW493 replied to SvenMarbles's topic in General Discussion
As an RF engineer who has designed receivers for over 10 years, I can say that SINAD is not a receiver metric. SINAD (Signal In Noise and Distortion) is a measurement parameter to which receiver performance is measured. dBm (dB-milliwatt) is far and away the most common receiver sensitivity metric in the RF design world. Sure FM broadcast receivers are measured in dBf, (dB FemtoWatt) but that is not typical elsewhere. Actually, in the receiver world, Noise Figure (F) is the best metric as that speaks to the RF front end without impacts from the audio circuitry, see below. To the person who posted dBm sensitivity measurements: Surely you used some proper RF service monitor to perform this measurement. May I ask what "weighting" you used on the audio? A or C weighted? it does make a subtle difference... Hope this helps. -
Slight clarification: Agree with the 5/8 wave needing a good ground plane. And yes strictly speaking the 1/2 wave end fed does not need a ground plane at all. But....what does need a "counterpoise" frequently is the matching from 50 ohms to high impedance in order to end feed the 1/2 wave. If that matching is done with discrete components (caps and inductors) then no counterpoise is needed. If on the other hand the matching is done via a physical structure that radiates, ie: helical 1/4 wave is common and easy, then THAT needs some counterpoise to do-it's-thing. Probably does not have to be large, but should not be zero. Not sure why you would rule out roof pillars though???
Same as above, plus: keep in mind that aluminum is non-ferrous, meaning that is actually repels magnetic fields. Sure it's thin, but there might be a risk of deteriorating the magnet if left on the aluminum long term. Consider a large steel washer below the magnet to "capture" the magnetic fields, then place that combo on the aluminum foil.
I've thought of a way where a longer antenna on the talkie can be an improvement over both the OEM antenna and a 1/4 wave whip proposal. Let's think about this: Many OEM antennas are dual band, for GMRS and also VHF for RX and/or TX. This means that the OEM has to compromise somehow to get it to work on VHF in such a short physical length which inevitably introduces loss at GMRS. Further, as we know, many talkies are not long enough to come close to 1/4 wavelength at GMRS. Thus even with a 1/4 wave whip the efficiency and radiation patterns will be impaired. So how to improve on these situations?? It is true that a good conductor 1/2 wavelength whip will be efficient and have a good donut radiation pattern. That would be about 12.1 inches for GMRS (less than simple 1/2 wave due to end capacitance). But how to feed it? Since the ends of the 1/2 wave are high impedance, the bottom end needs to be fed with a high impedance source. A common and effective way to do this from a 50 ohm feed source is to use a 1/4 wave helical coil where the physical location of the end of said coil and the bottom end of the longer whip are physically located to give the proper capacitance between them so as to couple the two high impedance ends together efficiently. This is the classic pull up antenna on circa 1990 vintage cell phones. At GMRS FREQS, that coil would be maybe 1 inch long (it was 1/2 inch on the referenced 800MHz cell phones), and with nearly zero extra length for the coupling between the two sections. This would feed the 1/2 wave whip nicely. The result would be a whip about 13 inches, let's say maybe 14 inches with the SMA connector on the bottom. But to be clear: This will get you a 1/2 wave dipole radiation pattern and efficiency, nothing more, certainly not the 3dB gain advertised by some after market vendors. It's a method to recover from the lousy OEM dual band and/or short talkie body situation. But it does sacrifice VHF performance pretty severely. There is a subtle advanage where in this situation the ground currents on the body of the talkie are not as high (as the OEM case) and thus there is less loss from the hand absorption when holding the talkie. Hope this helps again
Those are quite good videos and explain UHF propagation well. Nice job KS6DAY. But...there is one flaw in the discussion of the long antennas with "gain". Longer antennas, say 5/8 wavelength etc, ONLY have gain towards the horizon when there is a large ground plane below them. Something along the lines of 1-2 wavelengths radius is required. This is much much larger than the talkie of course. Thus those long antennas will have butterfly shaped radiation patterns and radiate at higher angles more than a simple 1/4 wave whip. Stay with a good efficiency 1/4 wave whip and that's your best choice on average. My apologies to the longer whip fans, it's just not going to help with such a small ground plane. It's in the EM math, really. Hope this helps.
I agree completely. It's also important to keep the electrical distance from the base of the antenna to the true ground plane as short as possible. I've seen antenna mounts where there are inches, as in 1-3 inches, from the base of the antenna to the metal body of the vehicle. Bad bad bad. Keep in mind that at GMRS freq 3 inches is 1/8 wavelength, and that's plenty to totally mess up the ground current phase compared to the radiating whip and cause the radiation pattern to go well above the horizon, read into space. In a city urban environments with lots of scattering off of buildings that might be OK, but in rural areas you definitely want as low angle radiation as you can get. Keep the base of the antenna right on the metal of the vehicle if you can. Hope this helps
I have quite a bit of experience designing antennas for handheld devices...cell phones. The "ground" / "counterpoise", call it what you wish, is hugely important. It's the bottom half of the dipole antenna. My point is that without a counterpoise the upper half (whip, stubby, ducky etc) is not going to be able to have current driven into it well and thus will not radiate well. A real 1/2 wave dipole works very well of course. The metal in the talkie can and frequently does become the counterpoise especially at GMRS FREQS where a 1/4 wave is about 6 inches and that is the height of many talkies. Those smaller talkies, you know which ones, suffer from a much shorter counterpoise and unless the manufacturer has gone to extremes to make their metal housing have extra electrical length, those talkies never will perform as a longer/taller talkie. It's basic EM. Back to the original question about a counterpoise: yes, it can help especially in the case where the talkie is not close to 1/4 wave. Hanging a 1/4 wave wire from the base of the antenna downwards has some chance of making a difference, probably a lot of difference on the smaller talkies. I would be remiss if I didn't mention those longer whip antennas. A 5/8 wave whip antenna has "gain" over a dipole, around 2dBd, but ONLY if it has a substantial ground plane below it. Something in the order of 1-2 wavelengths in radius is required. The reason is that if you look at the E and H distributions you'll find that they only add towards the horizon when the ground plane is at least that big. If it's smaller, the radiation pattern turns into a butterfly shape and the peak gain goes down actually getting lower than a 1/2 wave dipole. Thus I am not a proponent of the longer whip antennas, contrary to a long line of people who claim to get actual better performance with them. To them I challenge that they are basically doing annedocital testing where they are finding better results in only one location/position and to one remote location. If their setup were taken into a true antenna anechoic chamber it would show otherwise. The best we can do for a talkie is a 1/4 wave whip on top of a 1/4 wave talkie. This gives the best efficiency with a rather good donut shaped radiation pattern which gives the best chance of good range in a variety of use cases and scattering environments. Shorter ducky antennas suffer from efficiency loss...they have to compared to a straight 1/4 wave whip, it's in the math. Hope this helps and does not ruffle too many feathers
Smiley Antenna Slim Duck GMRS 465MHz 5/8 Wave.??
WRUW493 replied to WSAA635's topic in Equipment Reviews
Sorry for the late response. Yes, actually I have. This is a common method used on the older cell phones that had external and/or extendable antennas. In those cases there was a metal piece inside the phone that was tuned to 1/4 wave (at the lower freq band if there were multiple bands in use) that ran down the edge or side of the phone.) We would try to put it in an area where the hand was not likely to cover it (much) or come near the face when being held against the face. I have not tried it on a GMRS radio, but RF doesn't know anything about the name of the device of course, just the frequency that is being used and Maxwell's electromagnetics still works. To WSAK691 who also mentioned a 1/4 wave antenna being good: bingo. Get the total system to be a 1/2 wave dipole and you'll get a nice donut radiation pattern that on AVERAGE is going to radiate the best to the radio you are trying to talk to. If possible have both radios held vertically so as to match the polarization as much as possible. At 460MHz there is some cross polarization taking place depending on the propagation path. The good news is outdoor environments are not likely to have as much cross polarization as indoors, so you'll get best distance outdoors with co-polarized hand held orientations. It's a subtle difference, but vertical is less impacted by ground (earth) effects that horizontal is at these frequencies, and holding the radio vertical is going to minimize the ground impact. Hope this helps -
Yes, this is all true, nicely said Sshannon. I went on and on a bit, my addiction to jabbering. Glad to hear that you tend to hold the radio vertical when using it. A lot of people do not. Have a great day -
Very interesting video. Thanks WRWE456. Well, if I understand him correctly, he had the radios separated by about 3ft for this testing. Yikes, that can make a difference on weak signals (any signal strength but you notice it on weak signals) due to a couple of things: a) RF propagation path changes by a lot over 3ft in paths with lots of reflections (inside a house and/or urban environments) b) he didn't say whether he made sure that both radios were a distance away from RF noise sources such as computers, computer monitors or modern TVs. Any number of electronic devices can be spewing out RF causing receiver "defense". To his point that SOC (System On Chip as I understand it) being as good or maybe better (sensitivity) than Super Het, this could indeed be true. I looked up the one SOC chip that I could find and it's spec states -123dBm sensitivity at 12dB SINAD in 20KHz BW. This calculates to about a 3dB noise figure which is quite good. A Super Het receiver would have a hard time beating this by more than a dB, probably not any better in the real world. Also consider that the SOC technology is similar to that used in modern day cell phone chips where the RF functions are synthesized in silicone. Those work very well. No telling what SOC Wouxoun or any of the Chinese manufactures use, but it seems that it's entirely possible that they use good SOC chips. Having designed Super Het receivers in years gone by, I can say that it is possible to make an outstanding receiver in terms of sensitivity, adjacent channel, IM and blocking. But, a big but, it takes space and $$ to do so. As a GMRS radio manufacturer I'd look long and hard at the price of a good SOC compared to what it takes to make a good Super Het, and probably choose the good SOC in the end. Just IMHO.
Hi Shannon, Thanks for the really good info and testing. Real world testing is always helpful. I see that the 771 antenna is 15.5 inches long, making it about 5/8 wavelength. The radiation pattern of a 5/8 wavelength with very little ground plane (the HT) is a rather high angle of radiation, probably 45 degrees or so. I don't know what the OEM antenna was. Couple of things to consider: 1- Since antennas do not create power, they only direct more in one direction than another direction. So without performing a similar experiment with the HT is quite a few orientations it's hard to say how the 771 (or any antenna for that matter) will behave in a variety of RF environments. This is why antennas are measured in RF anechoic chambers in dozens of orientations and then averaged together for a final evaluation. I have taken real world RF propagation data from a handheld (cell phone) to base station where not only does the best RF path change direction by 10's of degrees with every fraction of a foot change in location, but also inside of buildings with multiple reflections taking place it's not uncommon for the best RF path to be a TX polarization different or even orthogonal polarization to the RX antenna. 2- It's real easy to have poor radiation efficiency on dual band antennas. Loading coils and dual band related compromises all are opportunities for loss, read RF absorption. It could be as simple as the OEM antenna has poorer efficiency than the 771. This too would show up in a test of multiple orientations in a controlled environment. These are why that in the general case one wants a mostly spherical radiation pattern (read low "gain") and high efficiency. Then one has the best chance overall of having good radiation in the direction that the repeater/other mobile appears to be from the HT's perspective. Hope this helps, and keep up the good work -
Radioditty CPS v2.06 programing SW problem
WRUW493 replied to WRUW493's question in Technical Discussion
That was on W11. I solved it by going to W10. Thanks for the reply though. ps: too bad that Radioddity does not support W11, but seems like W10 is here to stay for a while despite MS desire to kill it. -
Any way you could send me the video? Or more detail on your results? thanks.
Try this one: https://www.amazon.com/gp/product/B0855PVDWS/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 Fairly flexible and not quite as long as the OEM on my GM30, yet a really nice and efficient 1/4 wave.
I cannot comment on the quality of these radios or cost or longevity. But I did look up the specs on the one SOC chip (transceiver chip that may or may not be used in the above mentioned CCR radios) It's spec (to be believed or not) sensitivity was -123dBm in 20KHz BW for 12dB SINAD. That translates into about a 3dB noise figure. That is quite good considering there is likely very little loss between the chip and the antenna. And the adjacent channel and blocking performance spec was decent, maybe a real super-het receiver can beat it on those. So I'm wondering if anyone has any actual receiver measurements (on test equipment) that they can share in this regard?
I hate to burst y'all's bubble, but the longer antenna on an HT won't help. That 771G Nagoya is a 5/8 wavelength antenna, which in order to have "gain" in the plane normal to the antenna would require a ground plane diameter of at least 1 wavelength. Obviously the radio is not that. What you really want is a simple 1/4 wavelength antenna (about 6 inches at GMRS) that has LOW LOSS, meaning it's efficient. With the GMRS HTs being also about 6 inches tall this makes for a really nice dipole antenna. A simple piece of heavy gauge copper wire would work just fine, but would not be so good mechanically. And that would not be so good for VHF, only tuned to UHF. I took a chance on this antenna and found it to be excellent since it's just a copper wire encased in flexible plastic. https://www.amazon.com/gp/product/B0855PVDWS/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 You will find that Motorola uses this concept on their HT's and for a good reason: it works the best for a handheld. The bottom line: for a handheld radio, you want radiation efficiency. Any antenna that has fancy coils to tune them is by definition low efficiency. Radiation pattern make little to no difference, and radiation pattern is the only thing you get with an antenna system longer than 1/2 wave dipole. Consider that over a propagation path you have no idea what the best path is to the other station at any point in time. Consider an urban or forest environment: reflections off of a building, car, tree is frequently the best path, and that changes literally by the foot as you walk around. Hope this helps. -
This is a great question. A little background: I worked at Motorola for over 30 years and asked this very question to some of the RF guys there. The resounding answer is to "go high baby". Well, in a case like yours where your high-gain and low height option is not really very high, then yes some extra maybe 10-20ft with a somewhat lower gain will be better. Now if you were already at 100ft with high gain and could go up another 20ft with low gain, this could be a different story. That would depend on the surrounding terrain. But in short "go high baby". As evidence of how this works, I too ran a repeater during the above mentioned time period, that being a 450MHz ham band repeater at my house. I lived on a small hill in the Chicago suburbs, maybe a 40ft above average terrain. Sounds like not much, but in the Chicago suburbs that's all you get for a hill I chose to go high baby, and put a 6dBi gain antenna as high as I could get away with, about 60ft above the hill. I was afraid to put a larger higher gain antenna at that height due to tower strength limitations. And wow, did it have great coverage for being just a home brew repeater. In the direction where the land sloped down slightly it easily had a 40 mile mobile coverage and I had people 80 miles away using it from simple base stations. Now granted this was one high performance repeater: 25 watts TX (yea, not huge I know) but the receiver was souped up by me, being an RF receiver guy, it had less than 2dB noise figure counting the duplexer loss (for those who don't get noise figure, 2dB in that case is outstanding). Hope this helps.
I agree with the responses above and add the following: Any end fed antenna (like we are certainly talking about here) is really just the top part of the actual radiating structure. The bottom part is the "ground plane", or in practice that metal stuff that the base of the antenna is connected to. If you put the antenna in the middle of the trunk lid of a sedan, or on the roof with a large metal roof, then, and only then, will you get close to the "gain" and radiation pattern that the manufacturer states. But this is rarely a practical way of mounting the antenna to the vehicle. Further, consider that any phase delay, read length of metal, between the base of the antenna and the "large" metal surface of the vehicle only serves to mess up the phase relationship between the whip and the ground, thus messing up the radiation pattern. I've seen lots of installations where people mount the antenna to the edge of the front hood of a pickup truck, but the mounting bracket is inches long between the antenna base and it's connection to the hood. This is a phase delay, see previous sentence. This is the reason that you'll see a lot of police cars with the antenna mounted via NMO in the center of the roof or trunk lid. Is the trunk lid lower to the ground than the roof? yes, does it matter? no. The improved radiation angle and direction symmetry benefit out weighs any height loss and even "blockage" by the passenger compartment. Hope this helps.
Hi all, this is one of my first posts on this forum. Please keep in mind that a longer antenna, such as advertised 5/8 wavelength, is of no added value on a handheld. The reason is that ANY antenna longer than 1/4 wavelength requires a ground plane of 2-3 wavelengths (yea, like feet) for the true advertised "gain" to be realized. The standard method of measuring mobile antenna gain in a real antenna chamber is to mount it on a 1 meter diameter metal plate. The GMRS handheld is no where near that. You are better off, usually by quite a bit, by going with a good 1/4 wave antenna. Fortunately at 462MHz that's about 6 inches, which by chance happens to be the length of many handhelds. So this combination makes for a 1/2 wave dipole type mode. This is as good as you can get in the real world on a handheld. Oh, this is the reason that I choose the larger, ie 6 inch tall, handhelds and stay away from the really small ones. In those cases the radio is just too short to resonate properly at 462MHz. I replaced the OEM dual band antenna on my GM-30 with a simple 6 inch long (single band) whip I took a chance on Amazon. It works phenomenally well, better than the OEM antenna noticeably. Not that the OEM antenna is a bad design, but it is dual band so there are compromises needed to make it work outside of GMRS. I only want the best GMRS performance I can get. Here's the link if anyone is interested: 1/4 wave GMRS antenna I know there are a lot of opinions on this topic, and some people make claims to the contrary. All I can tell you to about this is that I worked for a US cell phone manufacturer for 30 years as an antenna design engineer. We used the above philosophy utilizing the radio/phone as the bottom half of the dipole numerous times, it works, really. Enjoy.
Hello, I've installed the Radioditty CPS v2.06 software programming (for use on GM-30). But when trying to use the software it has the columns and rows all bunched together. Is there any way to adjust the display format? I tried the display resolution but that only makes it bigger or smaller, does not change the ability to read the individual cells which are bunched together. And advice appreciated. thanks.
