10
Everything posted by JLeikhim
Effect of magnets near a transceiver
JLeikhim replied to IronArcher's question in Technical Discussion
I would not quickly discount the interaction of any large magnet and a radio transceiver. Recently I read in a trade magazine of a company that makes Class D audio amplifiers for Public Address systems. These amplifier have ferrite chokes inside to decouple the high frequency components of the amplifier. Some of their customers were screwing these amplifiers to overhead speaker boxes in close proximity of the speaker magnet. They encountered all sorts of problems. These are common rare earth permanent magnets used for all sorts of things. In a speaker, they create a strong fixed field whether powered or not. Ferrite chokes are used throughout modern radio transceivers and many are quite small. Others like used in the power amplifier are large but already operating under heavy current flow. Current flow can saturate the magnetic properties of the choke, or any iron transformer. AC and DC current in a ferrite choke or transformer, creates a magnetic force. Whether it be electrically or magnetically coupled, the ferrite choke can become saturated to the point where it no longer becomes capable of absorbing or transforming electromagnetic energy. It wont be damaged if you remove the external magnet, but it can cause a malfunction and possibly a fault. I would not place any powerful magnet on top of an electronic device. -
I think the best application is expanding coverage in a local area where the availability of high towers is limited or expanded coverage is required. If you have a commuter corridor and one repeater is insufficient, two or more can be linked. Interstate linking is more of a novelty.
You might want to use some of the features in Google Earth to draw the paths using the line feature and then viewing the elevations.
Are the workers on the farm all family? If so GMRS is fine. If you have non family members as employees, they will need own GMRS license to communicate on your repeater. Otherwise a business license is required.
Midland MXT275 FM deviation in "repeater" mode
JLeikhim replied to ljh505's topic in Equipment Reviews
Sadly; It is still narrow band +/- 2.5 kHz in the repeater modes. The FCC ID can be searched for the GRANT and the modulation will be indicated. Anything less than 16K0F3E is narrow band. -
Just weird and look at the price tag
JLeikhim replied to GuySagi's topic in Family Radio Service (FRS)
It seems a bit sketchy. It appears to be related to an indiegogo project called Power Talkie that was an FRS portable that required linking to a smartphone to communicate. A bunch of folks still waiting for those devices complaining on indiegogo. I am sticking with commercial part 95 radios. -
OK I went to the link. From the discussion, it seems the RX bandwidth might be adjustable from the "Channel spacing" setting. However there is no indication that the TX modulation increases. It would be odd that Midland would be freely releasing software to violate the FCC type acceptance of this radio. If it works, then that is great. But Caveat Emptor". https://www.facebook.com/groups/1729729127079590/
What Midland ought to do is concede that their narrow band radios are a mistake and release a new model that will properly do wide-band. Add 8 WB repeater pairs 23-30 . They could also do it through the menu and make the RP light flash when WB mode is selected. WB then could apply to all the GMRS channels, simplex or repeater. The question is, do they have a WB filter in the RX path? If it is SDR then it is math unless it is burned into a chip. Then you have that pesky modulation fidelity to be optimized for 16K0F3E. Not sure they can properly do 11K0F3E now.
New Interfering (IX) Signals - "Baby Monitors" using GMRS/FRS
JLeikhim replied to intermod's topic in General Discussion
I was managing some UHF community repeaters on the Sears Tower back in 1980's. We had interference arriving at the antenna and LNA way up on the top pylon. It had a distinctive tone with heartbeat. HP had marketed some medical telemetry on the UHF splinter channels and those were buried deep in hospitals . Those transmitters were less than 50 milliwatts. The solution was to defeat AFC.- 44 replies
- ix
- interference
(and 5 more)
Tagged with:
Are they showing up directly on the 467.xxx GMRS inputs or the 467.xxx5 FRS channels? Some repeaters having AFC will pull in an offset channel. Until we figure this out, if the owners are not compliant. Rude sounds.... Oops clean up needed in bed 13!- 44 replies
- ix
- interference
(and 5 more)
Tagged with:
Mobile radio over 15 watts causing issues with the Jeep JK
JLeikhim replied to Mikeam's question in Technical Discussion
I would love to buy a new jeep but the lack of a metal roof has put me off. -
This is awful. Keep us posted as to what you find. It is amazing what junk gets imported and sold.- 44 replies
- ix
- interference
(and 5 more)
Tagged with:
There is a very real engineering aspect to this in that narrow band radios and wide band radios are incompatible with each other. They were never to co-exist. And legally, you can't tweak a narrow band radio to work better. While "they might work", they are operating at widely different parameters. There will be over-modulation received in one case and noisy weak modulation in the reverse. If you are expecting tone or digital squelch to work, they may not work. Add a narrow band mobile and wide band repeater to the mix and the repeater often won't respond. This is a common thread by folks new to GMRS. They can't activate the repeater. While I like the design of the Midland radios, they are creating a debacle by marketing radios (to the unwary) that have implications for a repeater operator, and users, who hope to reap the entire benefit of GMRS's potential performance. GMRS main channels are 50 watts TPO, and +/- 5.0 KHz deviation. Always has been.
Despite what Midland Marketing would like the world to believe, by marketing non compliant radios, GMRS is wide band baby. The modulation is +/- 5.0 KHz, the channel bandwidth is 20 KHz and the channel spacing is 25 KHz. Example 462.600 and 467.600 MHz. The exception are the GMRS interstitial channels at 467 MHz which are narrow band +/- 2.5 KHz, on 12.5 KHz channel spacing. Example 467.5875 MHz when used by GMRS radios. All FRS interstitial channels 462 and 467 MHz are narrowband. Example 462.5875 and 467.5875 MHz when used with FRS radios. Wide band is what the God of FM Radio Major Edwin Armstrong intended: https://en.wikipedia.org/wiki/Edwin_Howard_Armstrong#Wide-band_FM_radio Wideband is tremendously better than narrowband: 3 dB better which translates to much greater area reliability. If you have a narrowband radio trying to use a wideband repeater or simply talking directly, the loss is greater ~ 6 dB. YOUR REPEATER SYSTEM WILL PERFORM MUCH BETTER IF ALL COMPLY WITH WIDEBAND AS INTENDED. THERE WAS NEVER AN FCC NARROW BAND MANDATE FOR GMRS NOR WILL THERE EVER BE AS FRS ALREADY OCCUPIES THE INTERSTITIALS. See the maps wide vs narrow. Green good, yellow nope. http://www.leikhim.com/page13.php FCC Rules: § 95.1773 GMRS authorized bandwidths. Each GMRS transmitter type must be designed such that the occupied bandwidth does not exceed the authorized bandwidth for the channels used. Operation of GMRS stations must also be in compliance with these requirements. (a ) Main channels. The authorized bandwidth is 20 kHz for GMRS transmitters operating on any of the 462 MHz main channels (see § 95.1763(a )) or any of the 467 MHz main channels (see § 95.1763(c )). (b ) Interstitial channels. The authorized bandwidth is 20 kHz for GMRS transmitters operating on any of the 462 MHz interstitial channels (see § 95.1763(b )and is 12.5 kHz for GMRS transmitters operating on any of the 467 MHz interstitial channels (see § 95.1763(d )). (c ) Digital data transmissions. Digital data transmissions are limited to the 462 MHz main channels and interstitial channels in the 462 MHz and 467 MHz bands. § 95.1775 GMRS modulation requirements. Each GMRS transmitter type must be designed to satisfy the modulation requirements in this section. Operation of GMRS stations must also be in compliance with these requirements. (a ) Main channels. The peak frequency deviation for emissions to be transmitted on the main channels must not exceed ± 5 kHz. (b ) 462 MHz interstitial channels. The peak frequency deviation for emissions to be transmitted on the 462 MHz interstitial channels must not exceed ± 5 kHz. (c ) 467 MHz interstitial channels. The peak frequency deviation for emissions to be transmitted on the 467 MHz interstitial channels must not exceed ± 2.5 kHz, and the highest audio frequency contributing substantially to modulation must not exceed 3.125 kHz. (d ) Overmodulation. Each GMRS transmitter type, except for a mobile station transmitter type with a transmitter power output of 2.5 W or less, must automatically prevent a higher than normal audio level from causing overmodulation. (e ) Audio filter. Each GMRS transmitter type must include audio frequency low pass filtering, unless it complies with the applicable paragraphs of § 95.1779 (without filtering). (1) The filter must be between the modulation limiter and the modulated stage of the transmitter. (2) At any frequency (f in kHz) between 3 and 20 kHz, the filter must have an attenuation of at least 60 log (f/3) dB more than the attenuation at 1 kHz. Above 20 kHz, it must have an attenuation of at least 50 dB more than the attenuation at 1 kHz.
Alan; go for it....It is best option as it will do wideband mode as GMRS permits. The Midlands and cheaper radios don't.
The RF SIDE - par deux The Repeater saga.
JLeikhim replied to wqzw301's question in Technical Discussion
I would be wary of that LNA. Assuming your duplexing and preselector is working properly to reject TX noise and carrier (TNRD) to the degree that the additional low noise is useable, i would install an attenuator after that LNA to remove excess gain before the receiver. You do have that preselector between the duplexer and LNA I assume? Have you performed a duplex sensitivity (effective sensitivit) test into dummy load and antenna? If you don't run this basic test, the repeater can be functionally deaf. -
Thanks. I thought something was odd. His website promoting all those linked repeaters while a year or so back he claimed his "legal staff" claimed linking GMRS is prohibited. At the time he was citing old rules. His so called legal staff apparently ignorant the rules had been rewritten 2 years ago.
The definitive CCR thread... why you won't really save anything.
JLeikhim replied to gman1971's question in Technical Discussion
Many years back, before these CCR became the rage, it was a common complaint of ham users of Japanese handhelds that when replacing the factory supplied "rubber duckie" antenna with a 5/8 wave dipole or a base station antenna that the receiver sensitivity would erode. This was quickly identified as being a combination of both poor RF front end selectivity and poor dynamic range and IMD . It would be interesting to subject these CCR radios as well as known good commercial grade radios to the rigorous testing of TIA603D. Lacking the complete facilities to do so, it occurred to me that a UHF TEM cell could be put to use to combine a desired signal (12dB SINAD reference) and undesired noise spectrum (rejection notched at desired) from an amplified noise diode generator to perform a Noise Power Ratio test of these various radios having integral antennas. This set up could be used to quantitatively measure radios and rank them on a dB scale of best to worst. This setup would simulate the "real world" environment of powerful emitters in and out of band of the receiver. -
Anyone a member of this organization? Do you have a repeater linked? Thoughts. Feel free to PM me or e-mail, better. Thanks
I usually avoid these sort of products because in my opinion Cheap Chinese Radios are usually a Low Parts Count hot mess with crappy receiver performance. For some stupid reason this caught my eye. I am sure it will be disappointing. Should I buy one? Has anyone bought one opened it up and found the manufacturer went the extra mile in RX design, or should I let the fact that it has an FM 88-108 receiver built in confirm my misgivings? Well here it is, probably not FCC certified . But it is kind of cool. I am verklempt, talk amongst yourselves... https://www.verotelecom.com/VERO-VR-N7500-50W-Dual-Band-Mobile-Radio-With-APP-Programming-p541441.html
OP Marc is correct ultimately that elevation is everything in this game.
Excellent demonstration. FM capture of the noise floor is pretty evident. Also when in multipath, there are significant nulls of signal strength where additional power is beneficial. TSB-88 parameters used in modeling coverage predictions account for signal strength in estimating coverage at a particular reliability and delivered audio quality thresholds. Viewed on a coverage contour, even small amounts of signal power reduction most definitely affects reliability and signal quality.
While you could do this. For example a sectorized array of antennas. However, I think the theoretical diversity gain would be better letting all antennas see the subscriber. A lot would depend on the topography being served and where portable and mobiles are expected to travel. As I said, this is an experimental idea that I have. In fact the parts are in my lab right now, looking for an appropriate site to test from. I might try three corner reflectors approximating 120 degree sectors to compare. One important thing I want to try is a fourth omni antenna in horizontal polarization. I need some funding and a rooftop!
I am going to throw out some ideas for those who are repeater operators. It is an area I am exploring. By now everybody realizes that a 5 watt portable talking through a 50 watt repeater will have its range limited to the ability of that 5 watt portable to "make" the repeater, lets say 8 miles. If that 5 watt portable is talking through the repeater with another user with a 50 watt mobile some 20 miles further distant, that is an inherent accomplishment of the technology. In the public safety arena, UHF 5 watt portables are the critical users. Users want that portable to work everywhere. Public safety seeks to design systems to 97% reliability within a jurisdiction (town/country/statewide). Reliability is the name of the game. A TIA document TSB-88 describes how such systems are designed and tested. For example, if you wish portable coverage throughout a large city or county, the use of satellite voting receivers has long been the solution. Each of these voting receivers has a reliable footprint where a 5 watt portable can be received. Lets say that a small city has three satellite receivers at various locations and where the city boundary is reached, the coverage from any single receiver is 97% reliable. However in other areas within the city, the coverage drops to 70% reliable , if the other two receivers in the system overlap those areas and are also 70% reliable or greater, then > 97.3% "Joint Probability" is attained when the voter switches between strongest signals. For the typical GMRS repeater operator, constructing such a system would require having antenna towers at various locations and a means to bring the signals back to a voter by phone line or other circuit. The towers alone would be costly to build, rent or maintain. However, the hardware, satellite receivers and Voters are readily available on the surplus market and can be pressed into use in a much different way on one site, preferably a rooftop.. All three receivers can be co located on the same tower or rooftop and be used to facilitate multiple receiver diversity reception. Diversity reception can work with two repeaters, but we will use three in this example. If your repeater had 70% reliability out at 8 miles, you could improve the reliability to 97.3% in theory by adding two more receiver antenna branches. To get maximum return, there is a need for the antennas to each receive uncorrelated signals from that distant portable. In a hilly or urban area that may easily be the case. The antennas will have to be physically separated many wavelengths from each other on the tower or rooftop to yield diversity gain. A caveat is that the additional two receivers will need bandpass / notch filters to filter out the transmitter, just as a duplexer would do for a singe receiver station.. I will provide an excel file "Joint probability example" to anyone interested. I was unable to attach it.
Can GMRS repeaters be linked to the web like Echo Link for hams?
JLeikhim replied to WRCP828's question in Technical Discussion
Forgive me if I have stirred up a dead thread! Corey; If I simply get an RTCM and connect to my repeater, configure to and with my home LAN network can I participate in the myGMRS network? Or do I need a server?
