WRDJ205
    2
Everything posted by WRDJ205
  1. Since it’s been a year and I’m still dabbling in GMRS I decided to splurge on 50’ of LMR400 to connect to the J-pole on a stick that I showed previously. It arrived today and I thought it was time to do a test. This is just a relative comparison test. Checking the output of the radio I was getting about 9W as a baseline. I connected the radio to the Surecomm with just a rubber ducky antenna on the antenna side recognizing that this is not a good combination but it was consistent for the testing. Using the RG8X I measured 1.37W at the end of the cable. Next, I did the exact same test with the LMR400 and got 6.07W. I was surprised at the results so I did it again and saw the same. I realize that the LMR400 is a better cable but I did not expect to see such a large difference.
  2. The availability of those repeaters covering multiple frequency pairs is what brought this question up. I was curious why the packaged repeaters were able to cover multiple pairs when the one on BuyTwoWay had to be tuned for a specific frequency pair. It seems like it’s somewhat of a compromise but you get the convenience of a pre-packaged unit. Something to think about.
  3. Thank you for that info. That was already taken into account in my plan.
  4. That’s my plan. I was just curious about why that was necessary and if other non-turned for frequencies might work. It appears like they might but at a costs in performance. Once I get it set up I’ll do some test to see what the difference is.
  5. @SteveShannon Thanks a bunch for the link. I did try to search just like that poster and read several of the results but did not see the one you sent. I have some reading to do.
  6. I've been looking into building a briefcase repeater using a couple of HT's. It's a summer project I'm working on with my sons. It'll be used mainly for personal communication at some rural property where we don't quite get good coverage with HT's. I will probably order a tuned duplexer from BuyTwoWayRadios. The 462.725/467.725 pair is fairly open in the areas where I might be traveling and there are no repeaters near the property. I can't find a good explanation as to why the duplexers need to be tuned for a specific frequency pair. Why wouldn't a duplexer tuned for GMRS UHF bands be able to cover all pairs as long as the TX and RX radios had the proper offsets on them? As usual, thanks for your help and Happy Father's Day...
  7. Started with the GM-15Pro but using Baofeng GM-5RH more now. The programming was a little easier.
  8. We use “mobile” and “base” to differentiate.
  9. The base is custom built but very similar to the flag bases used for tailgating that can be found on Amazon. You park your vehicle on the flat part.
  10. Here’s a pic of the painters pole and the base mount I use for it.
  11. Interesting. I don’t notice that with any of the ones I have. They’re probably all a bit different. I would still recommend them for basic communication or hand out radios.
  12. Depending on how close you are to the repeaters, you might be able to use a more portable (re: not permanent) set up. I have a J-pole antenna on 24’ painters pole that I put up and take down as needed. I use ratchet straps to stabilize it on a basket ball goal when I put it in use. Then take it down when it’s not needed or in bad weather.
  13. Found that the ones I have put out about 2W. Very compact and slip in a pocket easily. Even tested with the earpieces and really no complaints. These would be the radios I hand out for people who might be intimidated with too many options. At the price I bought them I’m not worried if they get lost.
  14. I do tend to agree that this would be helpful. In my AO, I can catch the Roadkill network on 3 different repeaters and their simplex frequencies. It about the only traffic around here so I can just change the channel.
  15. I’ve had issues with cable connections lately. I’d check those first (it’s also likely the easiest to verify).
  16. Growing up with Smokey and the Bandit and CBs in every vehicle is a great memory of mine. I do think that the use of cell phones have made it much easier to communicate in some of the same ways that made CB useful (traffic jams and bear traps). There is a place for GMRS tho but it will be specific to each individual (or users). As SteveShannon mentioned, we use it to communicate with kids who don’t have phones or where phones don’t reach. Or, if the cell networks are jammed up bc everyone needs data during a hurricane (yea, that happens).
  17. WRDJ205
    Help
    Can you give more details on the radios and what you’re trying to do?
  18. I think he got a good deal for $70.
  19. I got the programming cable because I wasn't sure how easy or hard it would be to program. It wasn’t that hard to program but I couldn’t full get it to copy and paste from the chirp programmed channels I used for my other radios. So, just had to type in the tones for the repeaters and the frequencies that I wanted to monitor in other bands.
  20. Got the license after my wife gave me the radios. We use them to communicate on some rural property (hiking, riding atvs, tractors, etc.). Now at home, it’s part of our plan for communication after a disaster or emergency.
  21. Great choice. I had my eye on the 50w but it was out of stock when I wanted to order so I got the 20G. So happy with that choice. Love the fact that I run it off the cig lighter. It does everything I needed.
  22. Can you take it to the park and try it outside with less obstructions? It seems to make a big difference.
  23. Per the meter, i frequently see 8-9W. The higher number is with ta Midland ghost and the lower is with the long rubber duck.
  24. I agree. The Baofeng equivalent is the GM-15 Pro. They use the same programming software. I’ve had good service with the GM-15 Pros.
