Jaay
Everything posted by Jaay
  1. Has Anyone noticed, that the Original poster, "Suburbazine" asking the question has never replied to any of your responses ?
  2. As a added note, concerning Anyone choosing to purchase the 935H, I noticed yesterday it apparently has the Same Problem the FIRST edition of TID H-8's with the battery discharging a Shock from the Positive battery contact, while transmitting ! While holding the 935H in my right hand touching the Battery Contact, I felt a Zap or charge while transmitting ! FYI. I'm going to Call buytwowayradios.com on Monday and tell them this occurred and see if they know about it.
  3. buytwowayradios.com in their video promoting this radio, stated that one of the Improvements over the 935G was a Much brighter display option, so it could be seen easier in bright sunlight. I can say the 935H has a VERY bright display, if you set it to max.
  4. Jaay
    GMRS security risk.
    Of course it Helps to have property in another name, not tied to you for these reasons too.
  5. It's spelled WOUXUN, but now you didn't bother to look Did you ?
  6. Buy once, cry once. RT Systems has become the standard for those who want problem free software.
  7. Exactly. Well said.
  8. GMRS and Ham Radio are BOTH Hobbies. IF you don't want to hear normal conversations on Gmrs, then turn it off.
  9. Looks fine, Run with it, if your Swr checks out.
  10. There's NOTHING wrong with that connection at all.
  11. True, and Also the Call sign of the repeater owner must be transmitted as well, either manually or with the help of a Controller.
  12. Ok, thanks for that Steve. I'll look at #51 and see if it makes any difference. My 935 H has a real obvious tail, even with the squelch up to 9.
  13. On a different note, Can you tell me if the 935G has a Mic Gain setting Or a Squelch tail setting in the menu ? I'm curious, because it's two features I wish they would have included in the 935H. Two different radios, I know but still similar.
  14. I Tried to sleep with mine, but it's just too lumpy and tries to throw me out of bed ! I woke up in the morning with the mic cord around my neck !
  15. Jaay
    GMRS security risk.
    .--/.../-.-./.-../-..../...--/...-- Whew, I almost forgot to ID !
  16. After about two weeks using my 935H, I've tried to Nitpick faults or manufacturing oversights of it and have only compiled a few so far. 1. I have not found a mic gain setting in the menu anywhere. Wouxun could have omitted the Scramble feature for a mic gain. However, on a good note is seems to have Plenty of gain as is, on all 3 bands, so not a deal breaker. 2. The power supply uses a barrel connector on the Charging cradle and a wall wart to power it, where as USB-C would have been nicer ... But on the other hand I've noticed the the wall wart supplies enough current while charging the radio, that you Can still power the radio, and even Scan while in the cradle and Still charge the battery. My Yaesu FT70 won't allow it, during charge. 3. No Zone option on the 935H, but can be be dealt with by some programming voodoo. 4. No Bluetooth programming on the fly option, but then again, Not many on the market have this option yet. Overall, I'm pretty satisfied with it so far. I purchased the premium data cable and a Second battery for it as well. buytwowayradios.com asked me to review it, so I probably will.
  17. Welcome to the insanity...
  18. Reset the radio, and try again. Mine is Flawless.
  19. Jaay
    GMRS security risk.
    Unfortunately call sign has to be given in English. But you could use Morse code as an alternative to English phone identification. I was referring to this comment... ^
  20. Jaay
    GMRS security risk.
    If a CWID is allowed to identify a Repeater, then Why wouldn't CW be allowed to identify a Call sign ?
  21. Jaay
    GMRS security risk.
    Simpler mistakes have been made over Fakebook, telling your friends you're going on Vaca and announcing it to the whole world, but those Listening as well as reading need to be kept in the DARK.
  22. Jaay
    GMRS security risk.
    Not necessarily. When you travel, do you travel Together or in separate vehicles? IF you travel out of the Area where you live, then set up a schedule or time that you will call her and keep your transmission short and to the point then Wait 10 minutes before you give your call sign. Also use LOW power when your close, and maybe use the interstitial channels instead of Repeaters. Or stay Silent until you are almost Home. IF you are Bilingual, you can give your Call sign in Another language too. There's no rule that states your Call has to given in English.
  23. The IPC-610 course and a SMD soldering station makes this child's play. The cost is the IC and the amount of time your hot air station is up.
