31
Everything posted by BoxCar
Do an advanced search for city state - no call signs needed.
There are many dual band 25W mobiles available for both VHF and UHF. The Part 90 mobiles from Motorola are over-engineered for general use but are widely available. For the more casual use you are looking at, a radio designed for business use will give you excellent service. The better ones are from Vertex, Icom and Kenwood. A linear is a bag of worms turning into snakes that will come back to bite you. That's not to say there aren't good linears but those designed and FCC approved would cost you more than a used dual-band LMR mobile.
The ULS system the FCC uses for LMR license data can do searches in geographical areas. All you need to do is enter the parameters you want; ZA for the license type and state to return a list of all license holders within the state. You can drill down even further getting those in a county or even city if desired. Yes, the feature of searching the FCC database could be programmed into MyGMRs if Rich wanted to take the effort but its also just as easy to go directly to the FCC and pull the data yourself.
Use the HH as a hand-held and put a second mobile in the vehicle. It's really the best as it would allow you to contact someone in the vehicle while you were out and the person i the vehicle could reach out with a higher power radio if needed. You imply you may be doing some type of search and rescue in the event of a disaster, so quit cutting corners and do it better than cobbling a linear to a HH.
Just pick up a small mobile unit. A 25W unit should be able to use the cigarette lighter socket.
OMG Gman endorsing a radio that doesn't have bat wings!
I doubt you can change the steps. The radio is probably set to step in the standard 6.25, 12.5 and 25 kHz center channel steps used in LMR.
MURS is probably a better choice given the size of the property. Even with the limit of 2 watts there is no restriction on who may use the radio. It is possible to setup a cross-band repeater but may not be entirely permitted by FCC rules. The better option would be to obtain a coordinated frequency or pair so higher power radios can be used. Shopping for a coordinator will result in lower fees and some may also create the application and obtain the FRN for an additional fee.
International (Mexico) repeaters join "national" net?
BoxCar replied to ljh505's topic in FCC Rules Discussion
Along the Canadian border there are some sites operating for cross-border comms. It's primarily in the NE with Maine, New Hampshire and Vermont doing the bulk of it when I quit coordinating in 2015. The practice had been going on for several years but it required a treaty modification to get it officially sanctioned. The treaty change allowed for US frequencies to be installed in Canada and vice-versa on a non-interference basis. Stations in Canada operate under Canadian rules while stations in the US operate under FCC rules. I forget how wide the band is but 30 kilometers rings a bell. In some little towns along the border it's quite a mess as a responder from one country may have to cross the border in order to respond to a call in their country. -
The purpose of narrowbanding was to increase the number of available channels. Narrowbanding yielded (on paper) twice the number of channels but in reality it is a little over 40% because of adjacent channel interference.
The channel is 25 kHz wide with 20 kHz containing the transmission. That leaves 2.5 kHz as a guard band on both sides of the transmission.
The FCC issues letter of violation to Rugged Radios
BoxCar replied to tweiss3's topic in FCC Rules Discussion
What I was referring to was a breakdown of the fine by model. It is very doubtful the FCC will assess the maximum amount allowed by law. -
I'll disagree with having to be a business to use LMR. There are specific requirements for who is eligible for a frequency listed in Part 90.20, the Public Safety allocation. The requirements for 90.35, B/ILT or the Commercial portion are the same as the requirements for GMRS. The allocation of frequencies is divided between coordinators representing specific industries, but you don't need to fall into one of those industries to have a frequency assigned.
It'll be interesting to see the breakdown of the penalty. The Part 90 being on Part 95 will be telling. -
You are making generalizations you can't back up with actual measurements to claim the new WOXUN is a further example of a CCR. There are a number of Moto radios that fall in the same category of cheap Chinese radios as Moto's Schaumburg facility has been reduced to primarily office space. I don't think Moto even builds a radio in the US anymore.
New GMRS operator wanting to setup repeater
BoxCar replied to paulmont15's topic in General Discussion
Here is the official calculator for antenna/tower height. Remember, it's tower height PLUS any part of the antenna above the tower for the total height. TOWAIR Determination (fcc.gov) -
You'll need to check the specs for your radio to be certain, but you'll need close to 600W to power the GMRS radio.
If the transmitter is at the antenna along with the necessary power the the transmitter can be coupled with Bluetooth with the GMRS (or other service) transmitter sending the signal. What people are assuming is there needs to be coax involved. The transmitter is part of the antenna. Think cellular BDAs or WiFi range extender.
Gravity hasn't stopped working as of yet. Turn it upside down and then insert the wire. Works every time for me.
How to deal with malicious and criminal interference
BoxCar replied to FrancisHaws's topic in FCC Rules Discussion
If you, or one of your children, can state you heard the conversation then call the local PD and talk to someone in their vice section. They will probably come ot and interview the people that heard the conversation and then take action. They will bring in Federal assistance from the FCC and possibly the FBI. The FCC involvement is unique in that they do not require a warrant to inspect a building looking for radio equipment. -
Not directly if your intent is to provide Internet. You need a modem and that limits speed. Then you run up against the reporting requirement along with the limits of your radio's duty cycle.
Personally, I think you are way over engineered. I would look at other supplies such as some of the inexpensive Chinese ones. I'm running a 30A no name that's designed for communications work and paid less than $25 for it. If you want a good Chinese one, look to Mean Well. Their supplies are a little more than what I paid but have a great rep. My little cheapie has millivolts of ripple, so little I can't measure it accurately with my cheap Harbor Freight meter.
Download CHIRP and use it to program your radio. You'll need a programming cable but CHIRP lays all the fields out in a spreadsheet so it is an easy task. The Miklor website has both the links and instructions to make the job easier. www.miklor.com
100W at 12vDC is 5A of current and it is probably a little more than 1/3 of your transmit draw. Your batteries should recover the drawdown from 1 minute of transmit time in about 4 minutes with your panels putting out the full wattage.
If you don't need the meters, this is the model without them. https://www.toboaenergy.com/product/samlex-sec1235-switching-power-supply/?_vsrefdom=adwords&msclkid=7e73c0b058a31f4ec5f49f244919dfc7&utm_source=bing&utm_medium=cpc&utm_campaign=**LP%20Shopping%20-%20Electrical%20Switches&utm_term=4582352148614327&utm_content=woocommerce_gdf_12563%20%7C%20Samlex%2030%20Amp%20120vAC-13.8vDC%20Switching%20Power%20Supply%20%7C%20%24156.8 If you don't need the 100A capacity, you may like this: https://www.toboaenergy.com/product/samlex-bbm-1225-battery-back-up-1224v-25amp-charger/
