31
Everything posted by BoxCar
The 6.1 meter (20 foot) rule does not apply in this instance. If the height of the structure AND antenna is greater than 200 feet overall it needs to be registered. Several Part 90.20 entities found this out when the FCC cited them.
FRS does not require identification.
How do you like to connect your radio to your DC power supply?
BoxCar replied to fremont's question in Technical Discussion
I do electric RC aircraft so have access to connectors used for them. For my BTECH I used a pair of DEANS connectors between my 30A PS and radio which draws around 13A at transmit. The connectors are soldered to 14 gauge wires. You should be able to pick up the connectors at any hobby shop selling RC toys for around $1 per pair. The Deans are rated for burst surges of 60A for less than 3 seconds which is what an RC plane can draw at times. Power Poles are great connectors but the cost of the recommended crimper makes them a very expensive item for the average user not doing commercial work. -
Part 90 radios aren't really legal in Part 95 but the general consensus is the FCC tacitly allows it as the technical requirements are stricter than required for GMRS/FRS.
No experience with either unit but I would take the Woxun KG-UV6X over the 8X as the 6X, like the Tera TR-590 is an FCC registered Part 90 radio.
Welcome to the neighborhood.
All this BS about phonetic alphabets is funny in a tragic way. I remember many years ago before the FCC redid call signs listening to what was then (and probably still is) one of the largest networks doing roll call. One of the stations did have a brain fart on their id and announced to the net they would be forever more known a KL7BJW - Kilo Lima 7 Baldy's Junk Wagon. Needless to say, that is how the station was known from then until it went silent as Baldy''s Junk Wagon or just asking if Baldy was on the air.
Digital in GMRS - which mode is most appropriate?
BoxCar replied to intermod's topic in General Discussion
AASHTO or actually Radiosoft does both 90.20 and 90.35 in house. I used to oversee the 90.20 portion. www.radiosoft.com will let you see their price schedule for coordination and license filing. -
968's advice is valid but the higher amperage supply I recommended will be less stressed and not prone to overheating and stressing its components. I run a 30 amp supply on my radios which pull 13 A at transmit.
You'll need one that has a steady output that's 15% more than the transmit current as if both radios were transmitting at the same time. You don't need a lab grade supply, just a good switching supply meeting FCC emission specs.
I second going with commercial/public safety grade equipment. You can check your state and county property disposal units for radios. The equipment available through those outlets is a very mixed bag ranging from excellent to scrap. You may have to purchase by the lot but you can sell the excess units on flea bay.
Don't assume the coverage shown on the map display in My GMRS is accurate. It's a generalization based on assumptions such a antenna height, efficiency and generally flat terrain. Software that uses more accurate Longley-Rice propagation models are very expensive and those do include terrain modeling showing coverage holes used by hills and ridges.
If one takes a look at the FCC's description for the Citizens Band Radio Service you will note a statement that GMRS serves a similar type of service. Stating GMRS is meant primarily for communications between members of the same family as intended in the rules does not agree with the statements in other sections of the same rules. Just as CB was originally intended for communications between licensed stations much as amateur radio continues to be it is still an open system that can be used by any operator to communicate as desired. Sometimes it is better to read the rules and their wording for intent using a shovel than a scalpel. There are many areas of the rules that are to be taken exactly as written but determining intent of a particular section often has to be taken broadly and compared to other sections.
Even on the 2W channels?
- 32 replies
- kids
- neighborhood
(and 3 more)
Tagged with:
You can start getting them used to the FCC requirements by having them use a pair of FRS radios. If they forget to identify it's not an issue as they are not required to use your call sign.
- 32 replies
- kids
- neighborhood
(and 3 more)
Tagged with:
Somebody else familiar with the the microphone test done on the first gen digital computers.
Rebroadcast of NOAA Weather Radio is not considered as emergency communications except for the broadcast of watch and warning messages. These are very specific as warnings and alerts all start with a specific SAME burst. Alerts and warnings are also only in affect for a maximum of four hours or other period specified in the message. While it is fairly easy to detect the SAME burst to start he retransmission, it is not as easy to detect when the alert ends and that's the primary issue.
https://www.fcc.gov/document/wtb-confirms-amateur-radio-license-exams-may-be-held-remotely The Wireless Telecommunications Bureau released a notice today that Amater Radio License exams may be conducted remotely. This is great news for those who are stuck at home but wanting to get their Technician or General ticket.
GMRS, if I remember correctly started back in the late 70'sor early 80's as a step up from the morass that was CB at the time. My father was a radio dealer operating out of a spare bedroom peddling CBs, antennas and linears along with modified ham gear on the 11 meter band. He and my mother were also in REACT and did move to GMRS because of the pollution on 27 MHz. The biggest thing for them was the ability to set up repeaters to make up for the short range All this was back when the channels were also open for business. I believe their REACT team also made the switch to the "UHF CB" channels.
What's permitted close to the Canadian Border?
BoxCar replied to Fionnbharr's topic in FCC Rules Discussion
You could also file a petition to have the restriction reviewed. It doesn't have to be a formal document, just a document on the ECFS site stating what you have said here and asking the FCC to review if the restriction is still required. -
The Ed Fong antennas include the choke which is inside the PVC pipe. It's on his web site
GMRS isn't really a plug-n-play type of service. Other than the handhelds no one markets or recommends any complete system. Take the antenna needed for a base station. Which antenna depends on at least 4 variables - size, cost, efficiency and mount. There are plenty more that I cannot fathom. My particular situation is unique as I live in a ground floor apartment facing a 300 foot high ridge on the east side and a 400 foot ridge on the south. I can't make any holes through the walls and I have an apartment on my west side so I can't access the other two directions easily. For an antenna on my mobile used in the house I have a J-pole stuck on a piece of PVC leaning against wall. Not a great install but one no dealer would look to put in. My range is probably 5 miles to the west and north wit a 25 watt unit. Now, how would you attempt to market something similar as a $500-700 kit. As you have to rely on the purchaser to do the install, what kind of performance figure would you attach to this "apartment size" kit. What would you do if the customers complained their range was less? How could you verify any complaints or would you brush them off as being a user installation problem? I live with my limitations because I had a decent idea of what I was going to get because of my environment. But then my case is different from someone in a highrise with a clear place to mount an antenna who gets 10 to 15 miles of range with the same equipment,
- 70 replies
The conceptual idea is sound in that professionals do have the knowledge to design a system for a user or even a class of user however, we all know there are no real "cookie cutter" solutions. While it would be possible to specify some equipment from a single brand that would fit the three (or is it four) classes of user; mobile, base, repeater and possibly the fourth being handheld not every manufacturer of these radios build all the parts needed for a complete installation with the exception of handhelds. Lets look at a typical home or base station setup. First you need the transceiver and a DC power supply with it as very few are AC powered. Next you would need the coaxial cable feed to the antenna and its mount with the antenna being the final piece. Here is where the most customization takes place. You need to know the distance for you coax run and how you will mount your antenna. There is some help on the mounting of an external antenna as the FCC has ruled that building owners and associations cannot deny you the right to install your antenna however they may make and enforce rules about how it is placed. The biggest issues any combo or kit recommender runs into are meeting customer expectations. While some expectations can be mitigated through different mixes of equipment, the biggest hurdle for the consumer will be the price of the kit and the performance of the equipment. Better equipment means a higher end price to the purchaser. That's why the homebrew solutions often work best. Being able to mix and match pieces provides the best path for any user. As different equipment becomes available the user can upgrade different parts of the install. A better transceiver may be able to use the DC power supply from the older unit along with the coax and antenna. The coax could be replaced with one having lower loss for the same distance or the antenna changed, each providing some improvements. There are just too many variables for a system designer to overcome.
- 70 replies
Channel mode and frequency modes are the same thing. The difference is in what is displayed. Channel mode shows the channel number while frequency mode would show the frequency for the channel. GMRS repeaters operate with frequency pairs with the pair being 5 MHz apart. A 462 MHz frequency is paired with the 467 MHz frequency, The different tones are used to to enable the receiver (input) side to open up and listen to the signal on its input frequency and then key the output or transmit side of the repeater. The tones are also referred to as privacy codes. The repeater listings often refer to the "travel tone" which is 141.3 and needs to be enabled on your transmit frequency in order to access the repeater's receiver.
