OffRoaderX
    281
  1. Almost forgot: A lot of sad-hams like to slum on GMRS - so turn on your roger beep, then kerchunk the repeater a few times - They'll come at you like The Walking Dead...
  2. Some areas are, mostly because GMRS is intended for purpose-use. ie; when you go hiking, off-roading, etc, to talk with others in your group. Its not primarily intended for chatting with strangers.
  3. Yes, but I cant find anyone to talk to on it.
  4. are you sure you are using the correct channel "pair"? Its not just "the frequency".
  5. Yah, but still tied to the same FRN. is FRN info public? and can you see the previous license tied to the first?
  6. Too bad all the FCC website does is throw errors when trying to create a new FRN...
  7. If someone looses their FRN, and forgets their callsign, their only option is to get another license.
  8. I know multiple FRNs is fine, but wondering if there is anything for us lowly GMRS users specifically prohibiting more than one license. We know the police are allowed to do whatever they want.
  9. I cant find the answer to this myself so I yield to those that know more than I do: Does creating a new FRN and applying for an additional GMRS license violate any rules? For example, if i lost my FRN/callsign, or if i just dont like the way my callsign sounds and want a new one, would paying for a new license break any rules? And if so, please point to that rule (please, no guesses). I know that per https://www.fcc.gov/new-users-guide-getting-started-universal-licensing-system-uls multiple FRNs are permitted, but I cant find anything about multiple licenses.
  10. No. You would need to cut/trim the main (up and down) portion to get it tuned for GMRS. If you cut it too short, it could then be 'damaged', at least for use on GMRS. I would not attempt this without an SWR meter.
  11. Obviously Norton needs to relax.
  12. Question: What time is it? "Some People": The heart of a mechanical clock is the escapement mechanism, which is responsible for maintaining accurate timekeeping by allowing the clock's gears to rotate at a steady rate. The escapement mechanism typically consists of a pair of gears called the escape wheel and the verge. The escape wheel is driven by the clock's main power source, which is typically a weight or a spring, while the verge is connected to the clock's hands. As the escape wheel rotates, it drives the verge, which in turn moves the clock's hands. The escapement mechanism also includes a device called the pallet, which acts as a brake on the escape wheel, preventing it from rotating too quickly and keeping the clock's hands moving at a steady pace. In addition to the escapement mechanism, a mechanical clock also contains other components such as the mainspring, which provides the power to drive the clock, the gear train, which transmits power from the mainspring to the escapement mechanism, and the pendulum, which helps to regulate the clock's timekeeping by swinging back and forth at a constant rate.
  13. IIRC, the software started giving warnings a couple of years before the mandate - so I always set it WAY back so I dont have to click through those warnings.
  14. All you have to do is roll-back the clock on your PC to 2005 or something like that and then it will upload your Wideband settings fine. Report back if that works or not.
  15. Are you sure you're on high-power? Both my retevis and the Midland get 5-6W ..
  16. We have two repeaters that cover virtually all of Southern California and the use of roger-beeps is very strongly encouraged.. This discourages "some people" from using the repeaters making for a more pleasant repeater experience for everyone. One of the repeaters also has it's own roger-beep.
  17. The official answer is "It depends" ...
  18. ................................................. affiliate link below
  19. Someone sent me a message today that when they called the FCC to see why it wasnt working, the FCC lady said they were having "system problems" and do not know when it will be fixed - but she was able to email invoice to him so he was able to pay for his license.
  20. Sorry, Spectrum upload speeds suck!
  21. Spoiler-alert: Its not exactly the same as something you've seen before..
  22. I call BULLSHIT - just another Sad-HAM disguised as a GMRS user. YOUR radio YOUR choice - if the sad-HAM control freaks dont like it, they can change the channel.. HOWEVER - as you mentioned, if the repeater owner requests that you not use a roger-beep on his repeater, then following the wishes of the equipment owner who's equipment you are using would be the polite thing to do, IMO..
  23. My approval page is doing the same thing.. Cant approve anything.
  24. Hey @sjmahlerthanks for the dimensions.. is the case on the 97S made of plastic or metal?
  25. I had this issue with my RT97 and had to change the comport assignment to 1 or 2 using Device Manager - sounds like you tried that, but just in case you meant something else give that a try. Also - would you mind measuring the size of your 97S? I would like to see if its larger than my RT97 ..
