17
Everything posted by tweiss3
I have CS800D's in both cars, but I don't use DMR that much. Mostly I connect to the local multi-mode reflector (combines YSF, DMR & DStar), as well as the Ohio TGs (3139, 31391, 31390) and occasionally I will grab 3100 if its super late and I just need someone to talk to on the radio (like a month ago when I had to run to the pharmacy at 2AM to pick up a perscription).
Kenwood 8180 receiver sensitivity concern
tweiss3 replied to Mikeam's question in Technical Discussion
I just stumbled across this thread on RR, maybe it is related: https://forums.radioreference.com/threads/tk-780-reception-squelch-issues.421410/ -
Yea, the most overlooked thing GMRS and HAM operators forget is power levels and RF exposure. Even if you are NOT required to maintain a RF exposure calculations, you must still maintain safe distances and power levels. IMO, stay away from Anytone, I have their 878 and it has some serious desensitize issues, even after being replaced under warranty. They claim part 90, but I'd avoid them.
Make sure in your programming that you have the bandwidth set to WIDE. Otherwise I would get it's hardware (feedline/antenna) or transceiver (needs tuned up by a shop with the proper equipment). Make sure your antenna is installed correctly and you have a good ground at the antenna and transceiver. -
I was searching the ULS today, and its up in short spurts. Probably a huge system update they are working through.
It is finding my call signs, but it won't pull up the data when you click on it. I wonder if it's under maintenance. I just saw an active alert for the system: "The FCC is currently experiencing an issue with downloading authorizations using Google Chrome........ use Firefox at this time"
Are you having issues when scanning only? Or is it a problem parked on a channel as well? The Kenwoods are superior radios, but are not designed for scanning at all. He's, it does have a scan feature, but it's is slow, and not the primary use of the radio. Remember, they are professional LMR radios, and as such, the average patrol officer or EMS driver would remain parked on dispatch frequency, and likely not even have access to the scan feature. I bet the scan is just not fast enough to catch the little bit of traffic. I would still keep the Kenwood, it's a far superior radio with much better specs, including selectivity and sensitivity. -
For antenna I have a Larsen NMO150/450/758 that does well on the ham bands and excellent on GMRS. It's a commerical antenna, so it is designed for commercial frequencies, but it is acceptable for HAM use. It also has a spring on it and survives parking deck hits and car washes. As for radios, keep in mind, by law you have to have a RF exposure evaluation if you exceed 50w in VHF. For reference, at 50W you need 3.5' distance for a controlled environment (ok as long as you aren't talking more than 50%) and 7.5' in uncontrolled. The two radios would work if you tossed in a diplexer. Part 90/95 UHF and a separate VHF. You will have problems with frying each other if you use two UHF radios, you can't get enough seperation to make it work unless you use an expensive high/low pass filter or commercial diplexer, even then it's not ideal. You could also look at Kenwood commerical stuff, you can run two RF decks on one head, but it's not cheap. There are also some quality Part 90 dual band radios that will work well, though they don't follow the letter of the law. I have a CS800D in my car, though I don't use GMRS in my truck, it's dead here.
The Moto DTR radios work pretty well and are license free. Great site radios, they use frequency hopping to stay private and interference free I. The 900MHz band.
The FCC issues letter of violation to Rugged Radios
tweiss3 replied to tweiss3's topic in FCC Rules Discussion
From the pdf, its pretty hefty: -
New GMRS operator wanting to setup repeater
tweiss3 replied to paulmont15's topic in General Discussion
Please read this thread, pinned at the top of this section, first. I think it will answer many of your questions and more. https://forums.mygmrs.com/topic/1402-you-just-got-your-gmrs-license-now-you-want-your-own-repeater/ -
Rugged Radios gets hit hard, see the FCC document. https://docs.fcc.gov/public/attachments/DA-20-1395A1.pdf
The Surecom 102 comes with a plate: https://www.409shop.com/thumb/phpThumb.php?src=../uplimg/mb100556_4b6eced6b53f86636eddd2f77f010506_mainpic.img&w=350&h=350&bg=FFFFFF&fltr[]=usm|80|0.5|3 Its is attached on the antenna side: https://www.409shop.com/thumb/phpThumb.php?src=../uplimg/mb100556_5e8455bf70241d5788b5403472e8102c_addpic1.img&w=700&fltr[]=usm|80|0.5|3
You have to use the metal plate provided because inserting the meter between the antenna and HT breaks half the antenna. On an HT, the body acts as half the antenna system (ground plane).
You can tune it with a nanovna. It should be tuned in it's operational location, as simple road vibrations can cause it to fall out of calibration.
While the emission type is permitted (equipment aside) I honestly don't know if DMR text messages exceed the 1s transmission time limit. If you really want to do GMRS DMR, apply for a variance with the FCC. I know they have granted a few in CA for experimental purposes. I don't know the circumstances, but worth a shot. It does beg a different question, why? You could do a private DMR repeater in amateur radio extremely easily.
The rule is the radio must be Part95. That being said, my Anytime 878UV is a great radio that will operate on the entire UHF spectrum band and is Part90 certified if you keep it in commercial mode.
F1E & F2E would possibly permit DMR, however The above requires digital to be performed by an HT with no removable antenna, and it cannot transmit on the repeater input frequencies. This makes DMR impossible unless you are doing DMR simplex. Good luck finding part 95 equipment that can do DMR simplex. The intent was to allow some devices text on FRS HTs, which was a niche thing a little while ago.
Anyone in the N. Texas-S. Oklahoma Area?
tweiss3 replied to jerrytheyounger's topic in General Discussion
Hamstudy.org is a great resource too. Our club is still doing in person testing, socially distanced in a parking deck this month. We are going to online for weather reasons only starting next month. Either way, we continue to hold sessions. -
As line of sight, they are nearly identical. VHF sometimes experiences what is known as E skip, or propagation, where the atmosphere can take the signal and bounce it off the E layer and carry it 2+ times normal distance. Frequently this summer we had 150-200 mile contact via VHF propagation. The atmosphere never gets to a point to where the MUF (maximum usable frequency) for skip is in the UHF range.
I knew you know the rules, just had to be said. That being said, I have CS800Ds in my cars. I was looking for a 857D for my wife's car, but couldn't find one for reasonable.
I just have to point out that the 868/878 is not part 95 certified. It is part 90 certified under some programming. For GMRS it goes over the power allowances. While I have a 878 and like it, it seems to get overloaded too easily in receive, but it does a great job in transmission quality, distance and APRS is nice. I just don't want anyone misled, it's not an approved device. Also, DMR is currently not approved on GMRS.
It doesn't look like you have tons of room, but you sure did a good job of using all the room you had. I like how easy it is to hide wire antennas in plain site. Then again, a tree or two and most things hite from the general public. This is my 6m dipole: https://photos.app.goo.gl/T7sQ8Fgf3DPoxiGV9 https://photos.app.goo.gl/6CrAYg3gb5gnaNG8A Yes, it's hanging vertically, so it acts omnidirectional and isn't deaf at it's ends.
Recommendation was based on cost. His DBJ-UHF is $10 more and is still 4' in length. The dual band could also be reused for other things later. I retired mine from attic operation to field operation for field day or any other quick trip.
You are correct, a GMRS only would be about 19 inches, but the EdFong is a dual band, and is about 5' long when placed in PVC pipe, including the 12 lead area for clamping. Even at 5' it's very manageable inside and reasonable at $34+ shipping. You can always use fishing line to hang it in a window and it should work well.
