tcp2525
Everything posted by tcp2525
Some of the Birds have a Forward/Reflected chart that can be adhered to the back for SWR. Nothing on the back of mine.
Going by memory I think Array Solutions used to make the kit, but I could be wrong. Personally, I'm sticking with my trusty old 43P with a couple slugs as it is simple and doesn't have all that electronic crap in it. Nothing more satisfying than watching the needle move a thousandth of an inch when you're aligning.
Sounds like a keeper to me. You got a great "feel good" meter that is capable of boosting your ego as well as the watts. Perfect for the 11 meter enthusiasts.
There's no such thing as a good quality RG58 cable no matter how short it is. RG400 with N connectors at a minimum.
I'm a Linux user, Manjaro, and I do all my programming via Windows 10 in a VM. Works great and no need to waste time dicking around with WINE.
I use the NMO2/70B dual band antennas on all my vehicles, including both motorcycles without issue. They just work great. That's the only antenna I will only use.
I'm betting if you select another operating mode the radio won't be part 95 compliant, at least till you put it back.
- 46 replies
- radioddity
- anytone
(and 2 more)
Tagged with:
Mr. Chung is the Minister of Commerce in the HungLo province of China. Some of the world's finest counterfeit merchandise and stolen intellectual property emanate from there. Nothing leaves there until it is approved by him. Products from there have a higher degree of quality.
- 46 replies
- radioddity
- anytone
(and 2 more)
Tagged with:
Mr. Chung made these options to pass type acceptance regulations. Same radio different labels. I really like my DB20.
- 46 replies
- radioddity
- anytone
(and 2 more)
Tagged with:
Phasing harnesses are easy to make. Plenty of info on the web that gives all the formulas that are needed. You just have to get good quality 75 ohm cable and know its velocity factor. DX Engineering has some decent RG-11 for this. I used it for several stacked antenna projects without issue.
Turn off your adblocker and refresh, If it works just add that site to your rules/filters
I wouldn't want to even think about putting a scratch on that car, even places that will never be seen. Oh, when I said "cowl" in the other post I may not have used the right term. I was referring to that black area between the hood and windshield where the wipers reside. It would be fairly close to where an AM/FM antenna would be on most cars. Whatever you do just take your time and enjoy.
Nice!!! If I HAVE to put an antenna on that car I would fabricate a bracket that would bolt to the cowl underneath the front lid on the passenger side and use an NMO mount using existing bolts that are going into metal for grounding. That might be a problem as that care is most likely composite, but you can run a ground to the bracket if needed.. The mount can be sheet metal with the proper bends that would attach to the nearest bolts. Once fabricated I would have it dipped in black vinyl and add rubber bumpers for added safety to prevent any contact with painted surfaces or areas that can be seen. Run cable the traditional way through the firewall. The best thing about doing it this way is you can unscrew the antenna when not in use and put on an black NMO cap, which would blend in and nobody would even notice. That would be my approach, but I would need to see underneath the hood to make a template. Doing it this way is you can pull everything out in less than 20-minutes and restore the car back to original. No holes, no scratches. Using the NMO mount will give you a better choice of antennas, especially black ones. A black Larsen 1/4 wave antenna won't even be seen from a distance. Just be aware of the windshield wiper operation and factor that into you measurements. Here's a black 1/4 wave NMO. https://www.amazon.com/Laird-Technologies-450-470-Quarterwave-Antenna/dp/B0079555WM/ref=pd_lpo_1?pd_rd_i=B0079555WM&psc=1
Here's what the old V71a looks like on the bike. Control head is on a custom made slide mount that electrically connects when inserted. PTT under left grip. Coiled microphone/speakers cable plug into the bike via waterproof RJ45 jack. Antenna is a Larsen NMO-2/70B Black antenna mounted on homemade and sealed half wave grounding mast with "N" connector on bottom. Antenna/mast assembly is easily removed via three set screws and the LMR240 cable is safely stored on the female "N" connector after unscrewing protective cap. All connections are waterproof. The above description is for the 2014 Goldwing Valkyrie. The red bike is a 2018 Goldwing Tour DCT. I do actively use my radios on both bikes every day when commuting or touring. The red bike has a different antenna mount so I can use it for a secondary radio or just AM/FM. That's all done with RG400 cable.
Gotta agree, the DB20 is a fantastic radio for the price. The software is horrible, but I'll live with as once programmed one will use it very infrequently afterwards. Definitely, Harry S. Chung did a great job designing this radio for such a bargain. I also use one for the base.
Damn, I'm slumming it as I use RG400 for all my interconnects. Sounds like you're using that fancy PE-P141 stuff?
Good enough for me. Send it back for a refund. Thanks for testing.
One question, do we know his SWR? I would agree with you if we can confirm his antenna is properly tuned and resonating so that the high SWR circuitry isn't clamping down. I'll bet if he put any type/quality 50 ohm dummy load behind his meter the power will jump up.
Just a thought. I suspect your radio is putting out close to 50w, it's just that you're measuring over the air instead of using a dummy load. Your meter isn't very accurate either as with all these consumer grade meters. I'm not knocking your equipment, but if you're not using a Bird 43 or equivalent into an accurate 50 ohm dummy load you can read anything but what the radio is really putting out. I suspect your radio is fairly close to spec.
