483
If the SWR doesn’t go back down when you remove the arrester, the problem isn’t the arrester. You either have a bad connector, cable, or antenna. Swap each piece out individually until you isolate the problem.
If you take the lightning arrester out does your SWR go back down?
Exactly what I meant by intercom.
TD-H3 transmitting but not showing up on SWR meter
SteveShannon replied to hxpx's question in Technical Discussion
Based on GrouserPad’s experience that’s not uncommon, unfortunately. There’s no reason to doubt your (or his) experience. TD H3s apparently arrive dead or die shortly after. Don’t waste time double checking yourself. Send it back, preferably for a different radio. You’re fine starting another thread but you would have been okay piggybacking on GrouserPad’s thread. Welcome to the forum! -
There’s no way for it to get too hot except while transmitting. It’s the final output transistors that require cooling.
Have you tried VHT + TX? Doesn’t it only turn on the fan while you are transmitting AND the temperature is too hot?
Just passed my General class test on Saturday!!!!
SteveShannon replied to WRPL700's topic in Amateur Radio (Ham)
I did. -
That can be changed in menu 51.
Has that recently changed? Because three years ago I was automatically assigned AI7KS after I passed the AE exam. -
Two TDH3’s no output wattage !
SteveShannon replied to GrouserPad's question in Technical Discussion
It can be a frustrating thing to not have a clear cause and effect. It certainly could simply be group of failures caused by a bad batch of components. -
Here’s what Gil @WRUU653 found: “Yeah, there is something glitching, I found if I turn on both stale and offline tabs all the repeaters disappear from the map. But if I click on a repeater that is on the map and then click on that repeaters info, then go back and select stale and offline they show up. A ridiculous work around. I had wondered if this was because of my security settings as I hadn’t seen anyone complain about it. I’m using IOS on an iPad. I’ll go put on some coffee and see if it behaves the same on my Mac desktop. I’ll let you know what I find and I guess we should let Rich know.”
They can be made to appear in the map view by going to the list view first but there’s either a bug or a poor design that causes problems if you start in map view. I’ll dig up the complaint I turned in. Also, Gil I think found a workaround. Here is my complaint to Rich, which matches what you said:
<sarcasm>Not really </sarcasm >
Unless removed they should still appear when old data is selected.
This; just ignore it.
Have you tried it the other way, writing the file that bricked the first three into the fourth to see if it bricks it as well? If it does then you know it’s that file, but at the cost of yet another radio. If it doesn’t then you know you got three bad radios from the dealer. I admire persistence. -
Exactly! The rules limit certain aspects of the use, but leave it up to us to imagine how we might benefit from it.
Although I don’t have TDH3 radios, I agree that it sounds like whatever you’re doing with Chirp is causing them to cease transmitting. I assume you looked at the column in chirp that enables transmitting and it’s set appropriately. And you say that a full factory reset does not return the radios to being able to transmit? I would recommend returning them for a refund and getting something else. -
Implies a dedicated system is not just something I made up. Saying that a Fixed Station may only communicate with other Fixed Stations is the very meaning of the word “dedicated”. Then I said “such as” because I used two relatively easy to understand examples, but using the words such as also implies that there may be other uses. The regulations do say Digital Data is limited to handhelds, but analog data and controls have no such constraint and can be passed using tones, such as DTMF. Digital data. GMRS hand-held portable units may transmit digital data containing location information, or requesting location information from one or more other GMRS or FRS units, or containing a brief text message to another specific GMRS or FRS unit.
The regulations tell us exactly what is required of a Fixed Station and what a Fixed Station may do. They just don’t provide an example of how it might be used, and that’s good, because it leaves it up to the imagination of the user. 1. A Fixed Stations may only communicate with other Fixed Stations. The regulations do not limit it to just one other Fixed Station. This implies a connection to a dedicated system, such as telemetry or part of an intercom system, where the Fixed Stations have a single purpose. 2. A Fixed Station is limited to 15 watts. This makes sense for a system of dedicated radios in fixed locations where the distances and directions never change, such as two or more points in an intercom or telemetry system. It also reduces the likelihood of interference with other stations, especially if a person uses high gain directional antennas, such as parabolic dishes or Yagi antennas. 3. Fixed Stations may transmit on both the 467 MHz and 462 MHz main channels. Although simplex isn’t prohibited, this unique carve-out in the regulations makes it possible to operate full duplex between two Fixed Stations, transmitting and receiving simultaneously, which allows for very natural speech on an intercom system and is ideal for transmitting data and controls on a telemetry or SCADA system. So, for a family business (or a business which has a grandfathered license that covers their employees) Fixed Stations could be used for a wireless intercom. A farmer could use Fixed Stations to turn irrigation systems on or off several miles away. With the exception of the ability to operate in full duplex, which is made possible by being granted access to the 467 MHz main channels, all of these examples could be done as well or better with portable, mobile, or base stations. But for a system which is dedicated to a particular purpose between two or more fixed locations, such as telemetry or an intercom, where full duplex would a distinct advantage, using Fixed Stations would be a reasonable solution.
Yeah, I can certainly understand how that would get old. I wish everyone could have a spouse as good as mine, but it just doesn’t work that way.
Programming Retevis RA87 with software
SteveShannon replied to WSEW433's topic in General Discussion
So how about telling the rest of us what the problem was so the members of the forum can learn as well? -
I have a wonderful wife and I honestly wouldn’t want to dwell on life without her beside me. When I went back to college at 32, she worked two jobs to take care of me and our kids without ever complaining. Now that she’s in a wheelchair with MS she still never complains. I know that not everyone is so fortunate but I’m delighted for @LeoG. It appears he has a good one.
You had me at “When I got my first pair of radios,” but the ending was great!
I don’t have an image file to share with you but I and others here are willing to look at your file to see if we can spot something wrong with it, but receiving more details from you would help us help you. There are a lot of smart folks here who have experience with common radio problems. Asking for an image file reduces the chances that someone will be able to help to the set of people who have RA-87 radios, whereas sharing your file opens it up to the set of people who can read.
