SteveShannon
    483
  1. That’s how they are here as well, but there are only a handful of us who actually have licenses. The vast majority of GMRS just buy the radios and use them miles away from populated areas. Honestly, that doesn’t bother me a bit. Maybe there shouldn’t be GMRS licensing for handheld use or lower than some wattage level.
  2. There’s a subscription service that allows you to manage all of your auto-subscriptions… See, this is why the USA is the greatest!
  3. All cables with a chip require a driver. Some versions of Windows have the drivers pre-installed, but not all. Because there were a lot of counterfeit FTDI cables, the pre-installed drivers in Windows 11 check for counterfeits which sometimes can cause problems.
  4. I don’t see the usual black banner with dollar sign that indicates you’re a premium member, but sometimes that get out of sync between the two different portions of this site. Premium Membership is $50 annually. I know Rich has added additional membership levels that don’t cost the full $50. If doing as Gil recommended above doesn’t answer your questions then consider reporting your own post to catch Rich’s attention.
  5. All regulatory agencies interpret their rules to their favor, from the ATF to the other end of the list. FCC is no different. Unlike some of the other agencies they don’t seem to enforce their interpretations very often. I have no idea how you reached such a conclusion, and it’s not worthwhile trying. I’m glad they post both the rules and the regulations . I even agree with many of their interpretations.
  6. No, the fact that it already shows the proper TX and RX frequencies indicates that you don’t need to do anything else with the offset.
  7. Maybe. Some repeaters have been linked, so it’s possible that’s what you’re hearing, but it’s also possible that you’re receiving them directly via a phenomena called tropospheric ducting, which can cause UHF signals to travel farther than normal distances.
  8. Although I am not a fan of linking, what you quoted is not the written rule. That’s the FCC interpretation of the written rules. It does reference the actual rules it interprets (95.1733 and 95.1749) however.
  9. Maybe, but I think that a good lawyer could argue against that. FCC does define “Network Connection”: Network connection. Connection of a Personal Radio Services station to the public switched network, so that operators of other stations in that service are able to make (and optionally to receive) telephone calls through the connected station.
  10. Everyone sounds drunk.
  11. How are you measuring SWR? How sensitive is the measurement device to reflected power? What kind of coax are you using? How long is that coax? What power are you testing at? Where are you measuring the SWR? All of those questions must be considered in order to understand what you’re actually measuring. But again, a low SWR doesn’t mean an antenna is good for transmitting or receiving. A good dummy load will always provide a good SWR measurement. Nor does a slightly high SWR measurement mean an antenna is bad. A high SWR antenna with no transmission line still gets the power out. What kind of antenna is it? How does it work in actual real-world tests involving transmitting and receiving? Try it.
  12. Those SWR readings are good, but SWR readings alone do not make an antenna good. Also, measuring SWR at the radio end of a lossy coax cable will always give SWR readings that are artificially low.
  13. I hope you stick around and I hope you do ask questions. Some are more difficult than this one but sometimes people just need to chill and remember that they weren’t always so perfect.
  14. Hi Dave, Gil, @wruu653, pointed out that the repeaters appear in a search if you turn on Stale and Offline repeaters. But then I found something weird, a mismatch (I think?) between map view and tabular view. If I do a tabular data repeater search to include stale and offline, both repeaters appear on the map. But if I go to map first and turn on those two switches for stale and offline, the repeaters don’t appear on the map. I have written to Rich, the site administrator, to learn what I might be doing wrong. Anyway, if you do a repeater search to include Stale and Offline repeaters, both Eureka repeaters appear in the list, allowing you to select them. If you do that they appear on the map and more importantly the owner’s call sign is available for you to contact him. You might want to contact the owner and ask him to update his data on the site.
  15. The message you’re responding to is over a year old. GP62 hasn’t been seen in about half a year.
  16. I realize this is an eight month old post, but there’s actually a thread just for this question:
  17. Did you get to the page where it sends you a six digit number or did you not even get that far?
  18. Sorry, I have no idea and I don’t know if any mygmrs members are near there.
  19. I like my NanoVNA also. It can do a lot, including measuring insertion loss and SWR. But I bought two different RigExpert analyzers and I haven’t used the NanoVNA since. However, the difference in price was a few hundred dollars.
  20. I just logged in without any issues.
  21. I can definitely believe that. But transmitting on one H3 while receiving on the other H3 doesn’t affect the final transistor(s) (the output transistor) on the receiving radio.
  22. Being within a couple feet of another should have no effect on the finals. I bet that something with the programming resulted in inhibited transmit.
  23. I have the 117 and really like it. Of course I wanted the 87 but I couldn’t justify the price difference.
  24. Welcome to the forums!
  25. Is it possible that it was something that changed due to expansion and contraction with temperature? Otherwise, have you tried connecting the old coax to an antenna analyzer to see how it looks?
