It’s true that a person can spoof another person’s DMR ID, but that’s probably not done frequently in amateur radio. The exact address isn’t important to me, but being able to see their country, call sign, and name is nice, just like having your logging software look up call signs automatically.
Again with the racist and stereotypical dismissiveness. A knockoff is an unauthorized copy of a “legitimate” product. This radio and the handheld 878 have unique features all of their own that were groundbreaking when first released, such as having the memory needed to store every contact in the RadioID database.
It is the same as the Anytone, with slightly different features which are probably simply enabled in firmware. This Alinco, just like the Anytone, is a high powered mobile radio with terrific features such as cross band repeat, even digital to analog (cross-mode) repeat. It’s wrong to compare this to a $15 radio. It’s ignorant to call it “just a cheap Chinese throwaway radio.”
It’s hard to beat the db20g for functionality and price and although it can’t be programmed with Chirp it can be programmed using RT Systems which is superior to Chirp except for price.
RT Systems has a cable for this radio for $30:
https://www.rtsystemsinc.com/USB-76-Programming-Cable_p_2323.html
Or Radioddity has one for $20.
https://www.radioddity.com/products/radioddity-pc005?_pos=5&_fid=b7d4551e2&_ss=c
You bet. You certainly can set the RX tone also but if it doesn’t match the repeater output tone you never will hear the repeater. Often the repeater has two different tones. If you leave the RX tone empty then you hear everything on the channel.
So it’s transmitting? The next thing to look at is the tone. If you’re picking tones by number instead of frequency you’ll soon discover that the numbers don’t match with all manufacturers. Double check the tone (or DCS) you need to transmit to the repeater and then look in the 575 manual to see how to program it. But only program it into transmit on the 575. Leave the receive tone blank. See if you can hit the repeater that way.
And have you programmed one of the handhelds to receive on the repeater input frequency (467.xxx MHz) with no RX tone? Then listen to see if there’s any signal when you PTT the Midland MXT 575.
I haven’t used one, but I would consider something like this. I use an mxta26 and like it.
https://midlandusa.com/products/mxat05vp-3-db-heavy-duty-bullbar-antenna?variant=42539707302065&campaign_id=17727845030&ad_id=&gad_source=1&gbraid=0AAAAADAFdQglRxyShGFPXLNzwa6UtbZFt&gclid=Cj0KCQjwnui_BhDlARIsAEo9GusL9Y1FOKx1quX2PSNYMUM_aiJJ6i8Iq0p8mSonjpv2M4D7XH3-gwsaAnZ2EALw_wcB
In that case your calculations would be 4.30 db too low.
An isotropic antenna is theoretical, a single infinitely small source with a gain of 0, meaning multiply the input times 1 to get the output when working with linear values.
Having a dBd gain value for an antenna is convenient but for a calculator like this you always want to take the antenna gain back to dBi so you’re not inadvertently throwing the output value off.
Maybe a better way to explain it is that the dBd value is only useful for comparing an antenna to a dipole. For purposes of calculating total gain you always need to start at 0 which is the dBi number.
Yes, you need the forum software to recognize that you are a premium member in order to create a club.
Rich will have to fix your account. I’ll report your post to catch his attention.
Does the board have reverse polarity protection?
Here’s a data sheet for that regulator: https://www.ti.com/lit/ds/symlink/lm2576.pdf
Trace the voltage coming in on the red wire all the way to pin 1 on the voltage regulator. If you don’t see voltage there the problem isn’t the regulator. In that case look for a circuit breaker or fuse that might be tripped or blow for reverse voltage.
Last week we got 8-10 inches. The highlands are still solid white, as is the continental divide about a mile east of me. Rivers went out a month ago. Two pictures to demonstrate how quickly things change.
I’m sure you have heard that 20% of the people hold 80% of the wealth or some such internet statistic. The concept is basically true that a very small number of people make much more money than the vast majority of people. That majority of people have a higher standard of living as the direct result of inexpensive goods. For instance GMRS radios. If manufacturing of GMRS radios moves “onshore” the price is bound to go up significantly. The number of people who can buy radios will decrease. That’s not beneficial to the manufacturers at all. Accessibility to cheap radios greatly increased their potential customer base.
Tariffs will result in a lower standard of living for many people. Yes, military equipment should be manufactured either in the USA or by a trusted trade partner who can be relied upon in the event of war. Unfortunately, the USA just simultaneously pissed in the cheerios of our trading partners and increased the likelihood of war.
In fact I am personally against linking repeaters for wide areas. I’ve said that numerous times. But what you and I posted are interpretations, not regulations. The regulations definitely prohibit using the telephone network and arguably prohibit using the internet or any other network for carrying GMRS communications. But I’ve never seen anything in the regulations that prohibit radio links. For someone who wants to do repeater voting schemes I could see it being done and I don’t think that the regulations prohibit it.
The repeater must be IDed if anyone other than someone using the operator’s ID uses it. The mechanism isn’t stipulated. You as the repeater operator can do it manually. The regulation doesn’t require the repeater to automatically ID in any case.
