485
SocalGMRS has a long history of scolding newly joined people about reading the rules. Although it is a good idea to become familiar with the rules, I don’t think it’s effective to answer a first (or even 21st) question by scolding. Eventually you may decide there are some people here who should be ignored (me included) and the forum software allows you to place them (me included) onto an ignore list. Not only that but you can ignore specific aspects of another user without ignoring them completely. It was a good first question. I hope you stick around and ask many more.
The characteristics tested for are listed in the regulations, but a lot of it has to do with transmitting at the right power, no more than the correct bandwidth for the channels you’re on, and repression of harmonics (signals that poorly designed radios transmit on frequencies other than where they’re supposed to transmit). Here’s the GMRS specific language: 95.1761 GMRS transmitter certification. (a) Each GMRS transmitter (a transmitter that operates or is intended to operate in the GMRS) must be certified in accordance with this subpart and part 2 of this chapter. (b) A grant of equipment certification for the GMRS will not be issued for any GMRS transmitter type that fails to comply with the applicable rules in this subpart. (c) No GMRS transmitter will be certified for use in the GMRS if it is equipped with a frequency capability not listed in § 95.1763, unless such transmitter is also certified for use in another radio service for which the frequency is authorized and for which certification is also required. No GMRS transmitter will be certified for use in the GMRS if it is equipped with the capabilities to operate in services that do not require equipment certification, such as the Amateur Radio Service. All frequency determining circuitry (including crystals) and programming controls in each GMRS transmitter must be internal to the transmitter and must not be accessible from the exterior of the transmitter operating panel or from the exterior of the transmitter enclosure. (d) Effective December 27, 2017, the Commission will no longer issue a grant of equipment authorization for hand-held portable unit transmitter types under both this subpart (GMRS) and subpart B of this part (FRS). (e) Effective December 27, 2017, the Commission will no longer issue a grant of equipment authorization under this subpart (GMRS) for hand-held portable units if such units meet the requirements to be certified under subpart B of this part (FRS).
That’s a really good,point. A lot of people recommend LMR 400 without explaining that there’s the original LMR400, which has a thick solid center conductor that makes it inflexible. It bends easily enough but it doesn’t flex. There are also flexible equivalents such as the Ultraflex mentioned above or my favorite Messi & Paloni equivalents: Ultraflex 10 or Hyperflex 10 (10 in the name stands for 10 millimeters which is the same as the 0.400 inch diameter of the original LMR400).
It’s against the rules to transmit on GMRS frequencies using a radio that hasn’t been certified for GMRS. But unless you’re doing far worse things nobody will probably ever know or care and the FCC will not cite you.
A heavy forest and flat ground is almost the worst case for uhf. And although I’m one who over generalizes that a person will typically not notice the difference between 3 watts and 5 watts, that’s not in all instances. I could definitely see it making a difference getting through woods or other material that attenuates the signal rather than outright blocking them. If power were completely meaningless we could all get by with 100 milliwatts. I made a contact hundreds of miles away last night on ham radio. I was using 800 milliwatts on 10 meters when I did it. It was an accident and I was busy trying to figure out why my RF output was at 0.8 watts at the time. Of course conditions must have been just right and once I figured out my mistake and started operating at nearly 50 watts I was getting contacts faster than I could handle.
This is the only thing in your post that gave me heartburn. RG8x is terrible for GMRS. If you’re using more than just a very short length you’re attenuating a significant portion of your RF output in the cable before it ever gets to the antenna. Fifty feet of RG8X attenuates 62% of the signal. 50 watts out of the radio becomes 18 watts delivered to the antenna. https://kv5r.com/ham-radio/coax-loss-calculator/
Not all repeaters have squelch tail and some radios have squelch tail elimination. If the repeater beeps after it repeats a signal that’s sometimes called a courtesy beep. If the repeater did the courtesy beep before you got the new radio but makes no sound now I agree with you that you’re not activating the repeater. That can be caused by you transmitting on the wrong channel, being out of range, sending the wrong TX tone, or filtering out the signal by using the wrong RX tone. New radios always introduce new peccadillos. Try getting rid of the RX tone if you’re using one. With no tone you’ll hear everything on the channel. Then double check your channel and your TX tone. Finally, try getting closer. Try the radio that previously worked just to make sure. Good luck!
Not all repeaters have output tones. Instead, ask if anyone can hear you.
In engineering we refer to Occam’s Razor. The simplest reason is usually right. I like the way you said it better.
What to do when you end up inside the quote block.
SteveShannon replied to SteveShannon's topic in myGMRS.com
I discovered it accidentally, but it has made my life easier. -
The technique I described above can also be used to break a single quote box into multiple boxes so that the original statements may be commented on separately. For instance, a series of statements like below: By placing the cursor inside the quotation block where you want to break, and then giving two returns, then backing up to the blank line between statements and giving three more returns, the quote block is divided: Of course the same technique can be used between the second and third statements as well: becomes: So you can reply to the statements separately. -
Hi and welcome! Sometimes it takes a few days for your call sign to be recognized by the forum software. It’s not a daily update. Don’t panic!!
Understanding the requirements for power
SteveShannon replied to dosw's question in Technical Discussion
About 14 miles as the crow flies, but I would probably have to ricochet the signals off a mountain. -
Maybe, but if I wanted to establish a dedicated wireless intercom or SCADA system between my home and my cabin, setting up two fixed stations is a good solution. I could set it up a full duplex system using the 467 MHz and 462 MHz main channels, using only 15 watts to minimize interference with Yagi antennas pointing at each other. -
There’s an entire thread about Fixed Stations, but the definition of each in the regulations is the place to start. -
Configure for split tone repeater
SteveShannon replied to voyager1700's question in Technical Discussion
The Input Tone is the tone your radio must send (your radio’s TX CTCSS) along with your voice in order to open the repeater. The Output Tone is the tone the repeater transmits. You can program it into your radio as the RX CTCSS, but it’s optional. If you don’t program an RX CTCSS in your radio it will reproduce all signals on the receiver frequency. For the repeater you show the tx frequency should be 467.550 MHz. -
According to the regulations repeaters are limited to transmit on any of the eight 462 MHz Main channels. Radios are limited to transmit to repeaters on any of the eight 467 MHz Main channels. Most radios pair the 462 MHz Main channels with the 467 MHz Main channels and that makes perfect sense. But, the rules do not require it. You can program your repeater to use any one of the 462 MHz Main channels with any one of the 467 MHz Main channels. In some coastal cities repeater owners do just that because of maritime interference.
Or FRS users (at least for 1-22).
Once upon a time there was a user called WXRP381. He answered reasonable questions with asinine and judgmental answers and quickly ended up with a bad reputation. So he changed his name to Socalgmrs. But because he was the problem instead of his username the bad reputation continued getting worse. As his reputation got worse so did his comments. I’ve pasted a screenshot that shows how he spoke to new members who asked questions. Eventually he decided to leave the forum but rather than simply leaving he had the forum owner delete his account. That is why there are hundreds of unhelpful posts that now have the username “Guest”. That was three months ago. He’s back and using his same old username but because his earlier account was deleted his history of posts didn’t follow him.
They’re considered mobile radios when not called out separately and subject to the 50 watt limit. -
Anytone and Alinco software is good because it allows exporting and importing data from CSV files but the format of one model must be matched or data will fill the wrong columns. RT Systems takes that up a notch and makes it even easier to move data from one model to another but you still need to understand the data model. Without knowing which software you’re using for your Baofeng it’s hard to advise. Chirp is free and works well. RT Systems is not free but works very well except for rare instances.
National Radio Appreciation Day ! Febuary 13th. 2025
SteveShannon replied to Jaay's topic in Amateur Radio (Ham)
Doing a little ft8 I see! I enjoy it also. -
I agree completely.
In my case I got the Radioddity db20g for both (even though I now use them exclusively on ham bands). They’re easy to use and very small and I’ve heard almost nobody complain about their quality, although a few people have had an issue where the squelch remains open.
