SteveShannon
    485
  1. Hi Whippy, There are lots of books, but the only one I have is the ARRL Amateur Radio Handbook. I suspect it’s more than you want. I’m not sure the what a person needs to know for GMRS would fill a book. Set the same channel, match the tones, push the button and talk. Marc Spaz on this forum has an excellent introductory video. Someone else will come up with a link. GMRS is limited to 22 receive channels and 30 transmit channels by the fcc regulations. Certified radios have those channels programmed in. Tones (CTCSS, PL, CTS are all names for the exact same thing) and digital codes (DPL, DTCSS, and DCS are all the same) are used to limit interruptions, but do not provide security. If I transmit using tone 100 Hz as my CTCSS, and someone else has their receiver tone set to something else, they won’t hear me because their receiver only allows through those that have matching tones. But if they set their tone to 100 Hz they will hear me because their receiver filters out everything except transmissions that include the 100 Hz tone. But if they don’t have a tone set on receive they have no filter and their receiver will reproduce everything. Codes work the same way. @OffRoaderX has YouTube videos under his other identity, Notarubicon that have enough information to fill several books.
  2. Welcome! Have fun!
  3. I agree with everything you’ve stated. MyGMRS lists 14 repeaters for Alaska and I bet that is still much lower than reality.
  4. It’s a very good tool, but while line of sight is great for vhf and uhf radio work, it’s not absolute. For instance, here’s how it analyzed the path between my friend’s house and my cabin. He and I can communicate via 2 meter simplex, but according to the chart we shouldn’t expect to:
  5. It’s a website called scadacore.com. The tool is RF Line of Sight. https://www.scadacore.com/tools/rf-path/rf-line-of-sight/
  6. The SWR isn’t the issue and you’ll never be able to detect an audible difference in reception between 1.3:1 and 1.0:1. When you say you can’t hear people who are really close, do you mean that the radio isn’t breaking squelch? If you turn squelch down or off can you hear them? Do you have any PL tones or DPL codes set for receive? If so, clear them out completely for the channel you’re attempting to hear. With tones/codes cleared out and squelch at minimum you should hear static. if you still cannot receive even that you might simply have a bad receiver or audio problem.
  7. If the problem is water, it is possible that it’s a weak solution with some contaminant. That would depress the freezing point. Or maybe it’s not water but some physical change, a contraction of some component along your feed line that results in a change in impedance somewhere. Do you have a dummy load you could use to isolate portions of your feed line to see where the issue is taking place?
  8. I would register a complaint with the manufacturer. They might recognize the symptom. I think you said it’s only a couple days old. Make them replace it. You’ll have more peace of mind.
  9. I haven’t got a clue what the sound is but I would open the case and listen to see if I could see or hear the source.
  10. 6 dBi is 6 dBi, but with the base antenna you usually have a larger radiator and need less inductance. Higher inductance causes steeper troughs and narrower dips in SWR (called high Q). That means that SWR might be lower across a wider range of frequencies. Also, a larger radiator is usually better than a smaller radiator, if it's tuned correctly, because it has more area to gather RF and because it sticks further up. But in actuality, you might never notice a difference. If what you have works for you, I don't think I would change it. And I agree with @GrouserPad, nice setup!
  11. Here’s a pretty good video on fairly established HF emergency frequencies. Unfortunately I didn’t hear him mention 5167 kHz.
  12. And that makes sense. It’s mentioned on my license also, iirc.
  13. This!!! I’m always surprised by how many people spend many minutes and sometimes hours researching and asking others questions that could be answered in less than a minute by trying.
  14. Almost all repeaters adhere to the +5 MHz offset, but all the regulations say is that repeaters transmit on the 462 MHz main channels and receive on the 467 MHz main channels. Thus, repeaters transmit owners are not constrained to use exactly 5 MHz. Unfortunately, certified GMRS tend to use the exact offset. So, sometimes you find a repeater that is off by 750 kHz, but sticks to the channels established by the FCC. It’s very seldom though. I’ve mostly heard of it happening near seaports where some channels are shared with maritime communications.
  15. I think it depends on population. We have lots of mountainous areas in Montana (fourth largest in area, with only a million people) with no cellular service. I suspect Nevada, Wyoming, Idaho, and even parts of eastern California, once you get away from the interstates and population centers, have significant areas with limited access. We have 158 amateur repeaters in Montana and only 8 GMRS repeaters. Alaska is much larger but according to RepeaterBook has 6 GMRS repeaters and 114 amateur repeaters. I don’t know how accurate that is but obviously neither state has sufficient coverage for emergency purposes. I don’t believe repeaterbook is as complete for GMRS repeaters as MyGMRS.com.
  16. Well, 120 miles each way or so is a little far, but I truly appreciate your offer. I might even take you up on it! Thanks!
  17. Another really good training method (I really enjoyed it) is HamStudy.org. All of the questions are presented along with lots of reference material that unwind the concepts or reasoning behind the answer. It works really well for those who want to learn the material. You can choose how you want to be presented the questions, a section at a time or randomly. You can take practice tests as often as you want. It’s all free online or for a very low price you can purchase the app and take it on your phone or tablet even when you’re offline. It tracks which questions you get wrong and goes back to them more frequently to help concentrate your studying.
  18. I’m a volunteer examiner. We’re not allowed to place conditions like that on testing. We tell people about our club, but only as information they might enjoy having.
  19. He never said that he did. He is a longtime ham (second sentence) and describes the radio’s power under 2 meters and 70 centimeters. But even if he does use it on GMRS it wouldn’t upset me.
  20. Thanks, that gives me a little confidence.
  21. I wouldn’t. It can cause a breathing background sound.
  22. Our rocket club all uses 7-6 (channel 7, tone 6) on our Garmin radios. We’re miles away from the nearest town. We basically bring our own support group. We mostly use the radios to guide people towards where we saw their rocket descend. If someone had a medical emergency (a fall or heat exhaustion) they could let us know, so in that sense it’s useful, but only because we have a group of people monitoring the shared channel. Our most likely emergency is a grass fire. For that we have used cell phones to summon help.
  23. Based on past statistics that seems like it’s probably right.
