SteveShannon
    486
  1. Excellent! I haven’t looked at the Ham Radio Prep course. HamStudy does most of that also. I suspect they’re very similar. Best wishes as you go!!
  2. I don’t know if you’ve found it, but HamStudy made it very easy for me to actually learn the material. It’s free to use although I spent a very few dollars and bought the app for my iPhone and iPad so I could study while disconnected.
  3. Good for you! I greatly enjoy being a ham. Because you have an inquisitive mind I bet you’ll do great on the test.
  4. This is exactly right. Developing the skills needed to build various radio systems doesn’t require a person to become a ham, but it’s often easier if a person has engaged in studying the basics in preparation for the ham tests or has worked in commercial or military communications.
  5. Notarubicon separated the antennas but having the two radio boxes near each other still caused desense. He ended up solving that by placing them in separate metal compartments as I recall. They just weren’t shielded enough. Commercial Motorola radios are capable of being used clamped together because of their superior shielding, but the price difference is significant.
  6. The controller provides the necessary switching and provides level matching as well as sometimes providing the ability to identify the repeater at various intervals as required by regulations. The speaker of a radio is probably between 4-16 ohms. The microphone is a higher impedance than that. For best results the impedance should be matched.
  7. The YouTube channel Notarubicon tried it using two Wouxun KG1000 radios. These radios were built with this capability as part of the design. He has two or three videos describing what he did honestly. Randy, the social media influencer who produces and performs in the Notarubicon videos, is @OffRoaderX on this forum. It wasn’t a failure, but I don’t think he would describe it as ideal either. If using two antennas you need a lot of vertical separation or much much more horizontal separation; a duplexer really is the way to go. Even considering the loss of power through a duplexer it is worth it. Randy ended up using a dedicated repeater and duplexer. Here’s the first in his series of videos on building a repeater: If I wanted to set up a quick GMRS repeater for my family I would use the Retevis RT97S.
  8. Mobile radios can sometimes be paired to create a decent repeater. But many of them are just not shielded well enough and so the transmitter desenses the receiver.
  9. No, I have the DJ-MD5XT, which is a dual band ham radio with DMR. It’s nice. I like this Alinco radio but it’s actually a slightly re-engineered (improved) Anytone radio on the inside. I like my Yaesu radios too. My favorite GMRS radios are my Garmin Rhino and my Wouxun KG-805g, but I have no experience with the D-G46T. If it’s like other Alinco radios it will be well thought out.
  10. None of my Yaesu radios use the same pin out spacing as my one Alinco.
  11. SteveShannon
    CQ on GMRS
    What regulation limits the number of kids per frequency?
  12. Morse Mania allows you to practice “keying” on the touchscreen and some people have worked on interfaces to physical keys and keyers. Also, my Yaesu FT-DX10 radio allows me to practice without transmitting.
  13. In 1969 I was in the 8th grade. We put on a play that called for an on-stage telephone to ring. I hooked up a crank generator that the school had to an old dial phone I brought from home. It rang great!
  14. Marconi is proud of you!!!
  15. Happy Thanksgiving 🍽
  16. Also 95.377 specifically says tones or other signals: § 95.377 Tones and signals. Personal Radio Service stations that transmit voice emissions may also transmit audible or subaudible tones or other signals for the purpose of selective calling and/or receiver squelch activation. These tones and signals are ancillary to voice communications and are considered to be included within the voice emission types, e.g., A3E, F3E, and G3E. (a) Tones that are audible (having a frequency higher than 300 Hertz), must last no longer than 15 seconds at one time. (b) Tones that are subaudible (having a frequency of 300 Hertz or less), may be transmitted continuously during a communication session.
  17. Just reset your Apple password.
  18. Absolutely none of this is your fault. You asked sincere questions that belonged in the technical discussion forum. People answered. The way it’s supposed to work is that people vote up the best answer and vote down wrong answers. Then, when a person reads the question later they get the highest quality answer at the top instead of having to read through three or twelve pages hoping that one of the answers is correct. The system actually works well and helps people find peer reviewed answers quickly when people use it as intended and has worked well for years, but sometimes we end up with a couple of knuckleheads who don’t like it and end up consistently at the bottom of the pile. Or sometimes people mark down posts based on who posted rather than the quality of the answer. Personally, I like being able to sort by votes, but I wish the default was sort by date simply to avoid the whining by 709 or better yet allow each person to determine in their profile which way they wanted to see the sorting.
  19. A base station has exactly the same power as a mobile station. The only difference is that it’s possible to have a high antenna with high gain that might be pointed towards another high antenna. Except for special circumstances that’s unlikely to get you very far though because UHF radios transmit in a mostly straight line and once that line is past the horizon it is still going straight as the earth’s surface curves away from it. UHF isn’t as likely to reflect from the atmosphere as lower frequencies are; it just goes shooting off into space. There are people who live on the side of a mountain range who can transmit in a straight line to another mountain range that’s 200 miles away but that’s not a common occurrence. An amateur radio in the HF bands is much more likely to transmit multiple states away. I have reached Australia and Antarctica from Montana on 10-50 watts on the HF bands using a weak signal mode called FT8.
  20. It’s the operator’s call sign, which is usually the owner. All stations, whether handheld or repeaters, must be operated by someone with a license. The station itself isn’t licensed though. So while it’s technically correct to say that repeaters aren’t licensed, it’s not helpful. The operator is licensed and that’s whose call sign is transmitted.
  21. I like the ham radio crash course videos and I like Notarubicon videos.
  22. Just based on those two sentences I hope more db20g questions are asked in the technical discussions forum. There’s absolutely nothing special about your advice. Why would we kowtow to you?
  23. Looks like a Yaesu ftm-200 https://www.gigaparts.com/yaesu-ftm-200dr-50w-vhf-uhf-dual-band-c4fm-fm-mobile-transceiver.html?utm_term=sku-zys-ftm-200dr&P_Max_Yaesu_2&gad_source=1&gbraid=0AAAAAD_py5FGyMGQMRPOY6wX4o3y80v18&gclid=Cj0KCQiAo5u6BhDJARIsAAVoDWtzN7mrQOJmFTNxq4vO9yXxm18ZP-Vc00M7AJXZvej194mDtq9vXYkaAslFEALw_wcB
  24. Mmmm, beer...
  25. Your license is the repeater license. For GMRS there are only licenses for individuals. To add a new repeater go to the map page, click on My Repeater, then Owned Repeaters, then click on the button that says Add Repeater. But I strongly suggest you not add it until your repeater is up and running.
