SteveShannon
    486
  1. Yeah, some testing locations will charge a small fee. We don’t here. FCC rules limit the fee to actual costs. VEs don’t get paid for our time.
  2. FYI - upgrading your class of amateur license does not require a fee. Just new licenses, renewals, rule waivers, and vanity calls incur the $35 fee. https://www.arrl.org/news/new-fcc-application-fee-will-not-apply-to-amateur-radio-license-upgrades
  3. I use and like an app called Morse Mania on my iPhone and iPad.
  4. Yes, that is correct. In your comment you said channel 21. Channel 21 isn’t the same as RPT-21. They both receive on the same frequency but RPT-21 transmits with the needed offset. That’s what I (poorly) tried to explain when I said the following:
  5. It really wasn’t a technique that you could choose. If you post in the technical discussion forum the sort by votes is the default. Unfortunately choosing sort by date isn’t persistent once a person chooses it. I do agree with 709 that it’s a pain in the ass, but like Gil (@WRUU653) I can live with it.
  6. The 805? It uses the same cable as the Baofeng radios. You probably already have one, but if not it doesn’t hurt to get the Wouxun cable. Busy Channel Lockout can only be set from the software. Heres a video on programming it:
  7. As long as you don’t need the non conventional offset the 805 should be excellent. You can program it with up to 128 custom channels. One nice thing is that the squelch is much better out of the box than the Baofeng, but there is a way to tweak the squelch for the Baofeng. I have a GT5R also, but it’s strictly a ham radio, not GMRS.
  8. Just use that antenna. If you do choose to upgrade the MXTA26 from Midland is excellent as a mobile antenna but you will also need to get an NMO mount for it. It has a gain of about 6 dBi but don’t get too hung up on that. Midland has a 20% off sale right now. Code is REC20.
  9. So channel 21 is a simplex channel that transmits on 462.700 MHz. Channel 29 (aka RP21 or something like that) is the repeater channel that automatically transmits on the correct 467.700 MHz frequency. Try just changing to the repeater channel and setting the repeater input tone there.
  10. You’re right. @MarkInTampa nailed it yesterday. I failed to see that. I have the KG-805. It’s an excellent radio. Unfortunately I don’t believe there’s any way to program it for a non-standard split. I also have a Baofeng UV5R. Although the QC wasn’t nearly as good it works adequately. It will definitely transmit just as far. It sounds okay, and it can be programmed with the split. But I bought it before they started locking them down. I don’t know about the newer versions, but I suspect once they’re unlocked they’re fine.
  11. @Elbowmac - one thing that you can do with certified GMRS radios with dual tuners is program the primary tuner to transmit on the correct repeater input frequency and program the secondary tuner to receive only on the non-standard tuner. Oops, I see that @MarkInTampa posted that same solution yesterday. Sorry.
  12. 75 feet of UF 7 is definitely costing you some power, but are you certain you’re transmitting on a repeater channel? You’ll hear the repeater on both a simplex channel and a repeater channel, but only the repeater channel transmits on the correct frequency in the 467 MHz main channels.
  13. Trees block UHF pretty effectively.
  14. Something to be aware of is that base stations are not allowed to transmit on the 467 MHz main channels that repeaters receive. c) 467 MHz main channels. Only mobile, hand-held portable, control and fixed stations may transmit on these 8 channels. Mobile, hand-held portable and control stations may transmit on these channels only when communicating through a repeater station or making brief test transmissions in accordance with § 95.319(c). The channel center frequencies are: 467.5500, 467.5750, 467.6000, 467.6250, 467.6500, 467.6750, 467.7000, and 467.7250 MHz.
  15. I agree with Gil (@WRUU653). Please don’t start a new thread because one person cannot adapt to the up/down voting. This is the technical forum. People have the ability to very easily choose “sort by date”. Unfortunately someone went through the responses here and downvoted almost every post, including your very reasonable questions. That was petty and shows an utter lack of respect to those who honestly try to answer technical questions. Back to your original question, although the typical GMRS repeater will use exactly 5.000 MHz as the offset, the regulations do not require it. The regulations do require that transmitting to a repeater be done using one of the eight established 467 MHz main channels and that the repeater transmit on one of the 462 MHz main channels. https://www.ecfr.gov/current/title-47/section-95.1763 But choosing an offset that is different than 5.000 MHz will result in many (perhaps all) certified GMRS radios being unable to use your repeater. All certified GMRS radios that I know of uses 5.000 MHz as the offset. So that means that people will be forced to unlock ham radios or repurpose commercial radios in order to use your repeater transmit. Whether that’s a problem, only you can determine. One way to get around that is to use a radio that can be programmed using Chirp and which supports non-standard offsets or separate receiver and transmit frequencies. The cheap Baofeng UV5R radios did this easily. Many ham radios use “Automatic Repeater Shift” which assumes exactly 5.000 MHz offset for UHF frequencies. Commercial radios, found on the used market, like the ones @Lscott refers to would be absolutely excellent for this purpose. Best wishes!
  16. You probably can’t, at least not if the gain is expressed in dBd rather than dBi. You might not even want one with that high of gain if you could get it. Lack of ERP is seldom the limiting factor for range. The Comet ca-712efc advertises 9 dBi, which has 6.85 dB of gain when compared to a typical dipole. https://www.dxengineering.com/parts/cma-ca-712efc
  17. For a permanently mounted antenna up in the air a properly installed lightning arrester is a good thing to have, but for a mobile antenna on a steel cookie sheet stuck out the window it’s really not necessary. Nor do you need to change to a through hole NMO connector. The magnetic base establishes a good enough ground plane with the cookie sheet without needing direct connection. And as @Socalgmrs pointed out a ground plane isn’t the same as an earth ground. Also, that metal cookie sheet is not a reflector; it should be kept horizontal and the antenna should be vertical.
  18. Hans, I hope you don’t leave. Although I didn’t agree with your initial conclusion I don’t mind discussing the issue. People should be adult enough to ignore subjects they believe have run their course. Steve
  19. I disagree. There’s really no need for us to be shy about asking questions and making reasonable requests of the FCC.
  20. The operative word there is Stations . People are not stations. If I receive a message on my GMRS station, that’s the end of the communication as far as the FCC is concerned. If I then transmit a message on my amateur radio station to another amateur radio station that’s a new message. The FCC has almost no interest in the actual message; they only regulate the airwaves (there are some kinds of messages that they prohibit but they’re prohibited from being transmitted via radio stations in the first place.) It’s absurd to think that I cannot relate information that I heard on one service (whilst following the rules) using another service for which I am licensed. But this would certainly be an easy question to ask of the FCC: “If I hear something during a GMRS communication, may I repeat it on a different service for which I am also licensed as long as the content of the message is not prohibited?”
  21. If it helps, here is the definition of one-way communications within the personal services (Part 95) One-way communications. Communications where information always flows in one pre-arranged direction through a communications channel. and here’s the definition for two-way communications: Two-way communications. Communications where information flows in both directions through a communications channel, either simultaneously (duplex operation) or alternately (simplex operation).
  22. But with GMRS you’re going out of service. Operating split with hams who have different allocations is within the same service.
  23. I disagree on two counts. First, you’re not an idiot. Second, any time you transmit without an expectation of a response that’s a one-way transmission. That’s why the regulations go into so much detail about which one-way messages are allowed: 97.111 (b) In addition to one-way transmissions specifically authorized elsewhere in this part, an amateur station may transmit the following types of one-way communications: (1) Brief transmissions necessary to make adjustments to the station; (2) Brief transmissions necessary to establishing two-way communications with other stations; (3) Telecommand; (4) Transmissions necessary to providing emergency communications; (5) Transmissions necessary to assisting persons learning, or improving proficiency in, the international Morse code; and (6) Transmissions necessary to disseminate information bulletins. (7) Transmissions of telemetry. Having a conversation with a GMRS station consists of two one way transmissions, not two way communications.
  24. @LeoG @WRKC935’s analysis above is excellent. I’m go8ng to mark if somehow so I can find it again. What’s your roofing material? What are your doors made of? You can have the walls wrapped entirely with aluminum siding, but given the regular glass window panes and possible door materials and very small wavelength of GMRS the siding might not matter as much as one might expect.
  25. Prohibited: 1733 (b) GMRS stations must not be used for one-way communications other than those listed in § 95.1731(b). Initial transmissions to establish two-way communications and data transmissions listed in § 95.1731(d) are not considered to be one-way communications for the purposes of this section. and 1731(b) says this: (b) One-way communications. The operator of a GMRS station may use that station to transmit one-way communications: (1) To call for help or transmit other emergency communications; (2) To provide warnings of hazardous road conditions to travelers; or, (3) To make brief test transmissions. But no rules prohibit relaying messages received on one service by using another service. So you and I could have a conversation on GMRS and I could then have a conversation on 2 meters with Gil @WRUU653 operating as KO6BIK and I could relay the message to him.
