UncleYoda Posted August 6, 2025 Posted August 6, 2025 1 hour ago, WRTC928 said: That kinda depends on why you're doing it. I think it's a good idea for a neighborhood watch or a prepper group. A neighborhood watch is my intent but only during emergencies - not worth trying to get people involved while they have the regular communications. But I don't know if we'll do routine check-ins even then; just monitoring at set times is the main plan. I understand it could be an indication of somebody in trouble if they fail to check-in but it could just be they're busy so I don't know if that justifies check-ins. It can be worked out at the time it's active. Quote What rule are you referring to? The unwritten one - you mean you didn't read it? (haha). Go back and read two places: repeater definition in section 95.303 and station types allowed to use 467MHz (95.1763(c)). And the FCC clarification in this topic: https://forums.mygmrs.com/topic/10063-base-station-cannot-use-repeaters/#findComment-106907 Quote
BoxCar Posted August 7, 2025 Posted August 7, 2025 1 minute ago, UncleYoda said: The unwritten one - you mean you didn't read it? (haha). Go back and read two places: repeater definition in section 95.303 and station types allowed to use 467MHz (95.1763(c)). And the FCC clarification in this topic: https://forums.mygmrs.com/topic/10063-base-station-cannot-use-repeaters/#findComment-106907 There are no base stations in GMRS. There are portable (HH), mobile, and control stations. A mobile radio run from a power supply at a home is classified as a control station as its intended use is to contact other mobile stations or control a repeater that connects to other control or mobile stations. A HH is considered as a mobile. I Quote
UncleYoda Posted August 7, 2025 Posted August 7, 2025 12 minutes ago, BoxCar said: There are no base stations in GMRS. 95.1763 (a) & (b) are enough to make it clear you're wrong. Also 95.1749. And I'm not going to respond to anymore of these BS interpretations. WRXL702 1 Quote
BoxCar Posted August 7, 2025 Posted August 7, 2025 9 hours ago, UncleYoda said: 95.1763 (a) & (b) are enough to make it clear you're wrong. Also 95.1749. And I'm not going to respond to anymore of these BS interpretations. Well, I will state that 10 years as a Part 90 frequency coordinator issuing frequency assignments to business and public safety licensees and working directly with both the Wireless and Public Safety bureaus states your interpretation is in error. Base stations are fixed sites such as E911 centers and EOCs, commercial radio and television stations and the like. Stations installed in police stations, fire stations and business offices and buildings are control stations. Quote
W3sG4c Posted August 7, 2025 Posted August 7, 2025 On 7/11/2025 at 8:29 PM, OffRoaderX said: Confunculated…… Quote
nokones Posted August 7, 2025 Posted August 7, 2025 Per Subpart A Rule 95.303, a base station is defined as: Base station. A station at a fixed location that communicates directly with mobile stations and other base stations. The FCC defines the station class by how the radio device is configured and functions and not by the type of the radio device being used. If the transmitter is connected to a fixed antenna at a fixed location and communicates with other base stations or mobile stations, it is a base station. It doesn't make a difference if a portable handheld or mobile radio device is being used if it is connected to a fixed antenna at a fixed location, it is a base station operation when it is communicating with other base or mobile stations directly and not through a repeater/mobile relay station If a base station communicates to other base stations and/or mobile stations through a repeater/mobile relay station, then the base station is controlling said repeater thus is now a control station. WSJX263 1 Quote
UncleYoda Posted August 7, 2025 Posted August 7, 2025 49 minutes ago, nokones said: Per Subpart A Rule 95.303, Well, you were doing good until you got to that last paragraph. That is stated exactly nowhere. You and all the other radio experts need to back up your control station when using a repeater interpretation with a clarification from FCC because that is all that counts. Quote
nokones Posted August 7, 2025 Posted August 7, 2025 2 hours ago, BoxCar said: Well, I will state that 10 years as a Part 90 frequency coordinator issuing frequency assignments to business and public safety licensees and working directly with both the Wireless and Public Safety bureaus states your interpretation is in error. Base stations are fixed sites such as E911 centers and EOCs, commercial radio and television stations and the like. Stations installed in police stations, fire stations and business offices and buildings are control stations. If the stations at those said fixed sites are communicating (transmitting) directly to another station, such as a mobile and base stations that is only receiving receiving that transmission, and not automatically repeating/rebroadcasting/relaying that transmission, then the transmitting radio station is a base station classed station. If people are calling it a control station, what is that transmitting station controlling when the receiving stations are just receiving? Also, when a base station transmitter and receiver that only does one function (transmit or receives) at a time and not function as a receiver and transmitter simultaneously by one transmission at the same time at that fixed location by a dispatch facility such as a Police or Fire Station or a non-public safety entity such as a Taxi or Tow Truck Company, etc., that transmitter/receiver device is classed as a Remote Base Station because it communicates directly to either mobile or other base stations without communication through a classed repeater/mobile relay station, by that subject dispatch facility, that Dispatch Facility will be classed as a Control Point for operating that remote base station, when that dispatch facility is operating that remote station with a dispatch console by way of a media circuit type, such as a cable, wireline telco circuit, or an operational fixed classed station such as a 70 MHz, 150 MHz, 450 MHz, or Microwave systems. I retired as a person in command, with a staff of 60+ employees of the one largest statewide mobile radio systems (3,000 vehicles, 10,000 mobiles and portables, 300+ remote sites 26 Dispatch Centers, 75 operational channels) and I was on the board with one APCO Chapter and two separate Chapter Frequency Coordination and NPSPAC Committees with over 36 years of total service and 5 years as a part-time employee for a small city is essentially performing the duties. So, I think I am very aware how stations are classed since I was responsible for a variety of various types of stations. Quote
LeoG Posted August 7, 2025 Posted August 7, 2025 Arguing about nothing. Only when you get into the big stuff does it really matter other than on paper. The eff sea seas doesn't give one crap about your little 50 watt station if it's classified as a base or a fixed. Because it depends on who you are communicating with and next thing you know you are classified from a fixed station to a base station. Semantics. Quote
UncleYoda Posted August 7, 2025 Posted August 7, 2025 1 minute ago, LeoG said: Arguing about nothing. Only when you get into the big stuff does it really matter other than on paper. The eff sea seas doesn't give one crap about your little 50 watt station if it's classified as a base or a fixed. Because it depends on who you are communicating with and next thing you know you are classified from a fixed station to a base station. Semantics. Nothing to one it may be but to others not so. And I don't want to confuse you with more facts about what's nothing to you, but fixed isn't part of the equation because that type isn't in the allowed list either. Quote
BoxCar Posted August 7, 2025 Posted August 7, 2025 37 minutes ago, nokones said: If the stations at those said fixed sites are communicating (transmitting) directly to another station, such as a mobile and base stations that is only receiving receiving that transmission, and not automatically repeating/rebroadcasting/relaying that transmission, then the transmitting radio station is a base station classed station. 47 CFR 90.7 Base station. A station at a specified site authorized to communicate with mobile stations. Mobile relay station. A base station in the mobile service authorized to retransmit automatically on a mobile service frequency communications which originate on the transmitting frequency of the mobile station. Mobile repeater station. A mobile station authorized to retransmit automatically on a mobile service frequency, communications to or from hand-carried transmitters. Mobile service. A service of radiocommunication between mobile and base stations, or between mobile stations. Mobile station. A station in the mobile service intended to be used while in motion or during halts at unspecified points. This includes hand carried transmitters. And yes, GMRS is covered by this section of the rules. Home based stations are not licensed to operate from their home location only. WSJX263 1 Quote
wrci350 Posted August 7, 2025 Posted August 7, 2025 1 hour ago, BoxCar said: 47 CFR 90.7 And yes, GMRS is covered by this section of the rules. Home based stations are not licensed to operate from their home location only. I think you spelled "Part 95" wrong. Part 90 rules do NOT apply to GMRS, any more than Part 97 rules do (or vice-versa). Part 95 has its own definition section (95.303) where we find: Base station. A station at a fixed location that communicates directly with mobile stations and other base stations. Control station. A station at a fixed location that communicates with mobile stations and other control stations through repeater stations, and may also be used to control the operation of repeater stations. Mobile station. A station, intended to be used while in motion or during halts at unspecified locations, that communicates directly with base stations and other mobile stations, and with control stations and other mobile stations through repeater stations. So as defined by Part 95 (which covers GMRS), if you have a radio at home connected to a power supply and antenna on your roof and are talking simplex to either a mobile (which includes HT) radio or to another 'fixed' installation, that's considered a base station. If you are using that same radio to talk through a repeater, that's a control station. The fact that some think those definitions are "dumb", or don't make sense is not relevant, nor is what Part 90 might say since Part 90 doesn't apply to GMRS. Not sure how this relates to the horrible suffering of those who must bear the burden of hearing people use their callsigns, but whatever. WSJX263, SteveShannon, WRXL702 and 1 other 1 2 1 Quote
H8SPVMT Posted August 7, 2025 Posted August 7, 2025 On 7/11/2025 at 9:29 PM, OffRoaderX said: WOW, I think your muffing got burned in the oven... Quote
WSJJ679 Posted August 7, 2025 Posted August 7, 2025 On 8/6/2025 at 11:41 AM, WRTC928 said: I disagree. GMRS -- by definition -- is for business and personal use. You don't own the airwaves, and you don't get to tell people what "personal use" they can put the service to. If someone wants to talk to someone else about their bunionectomy, they have just as much right to use GMRS as you do. Whether you like it doesn't matter. I hear stuff all the time that makes me roll my eyes, but I don't pretend I have the authority to tell people they can't use the GMRS service to say it. That's one of the reasons I have channels with CTCSS/DTCS tones on the radios I hand out to family -- so I don't have to hear that stuff. I suggest you do the same. Exactly!! Quote
HHD1 Posted September 18, 2025 Posted September 18, 2025 On 7/12/2025 at 3:07 PM, OffRoaderX said: But for those that insist on making themselves sound like retards and doing it anyway either through force of habit (2%) or because they are socially/emotionally/mentally broken (97%), and dont "get it" when everyone is laughing at them, more power to them.. What about the other 1%? Quote
Northcutt114 Posted September 18, 2025 Posted September 18, 2025 22 hours ago, HHD1 said: What about the other 1%? We have a local repeater where a good bit of the traffic is just people asking for radio checks from different locations to see if they can hit it with this equipment or that equipment. A lot of times there's an older fellow that answers them all. I swear I think he just sits at his desk and waits for it spark to life. But to the people who ask for the radio check he will usually respond with either their FCC callsign or he will say "to the station asking for a radio check..." Just the other day, I noticed that when people keyed up with their NATO phonetic callsign, he says "To the alphabet station..." I assume it's his passive aggressive wait of mocking them. It made me chuckle. amaff, SteveShannon and HHD1 1 2 Quote
WRUU653 Posted September 18, 2025 Posted September 18, 2025 1 hour ago, HHD1 said: What about the other 1%? Oh that’s Marie and she has such a lovely accent that she gets a pass. SteveShannon and HHD1 1 1 Quote
UncleYoda Posted September 18, 2025 Posted September 18, 2025 6 minutes ago, Northcutt114 said: A lot of times there's an older fellow that answers them all. That's his business, nothing wrong with it. And some of the guys who hang out on the radio are blind. Quote
LeoG Posted September 18, 2025 Posted September 18, 2025 2 hours ago, Northcutt114 said: We have a local repeater where a good bit of traffic is people asking for radio checks from different locations to see if they can hit it with this equipment or that equipment. A lot of times there's an older fellow that answers them all. I swear I think he just sits at his desk and waits for it spark to life. But to the people who ask for the radio check he will usually respond with either their FCC callsign or he will say "to the station asking for a radio check." Just the other day, I noticed that when people keyed up with their NATO phonetic callsign, he says "To the alphabet station..." I assume it's his passive aggressive wait of mocking them. It made me chuckle. The radio in my house is on all the time. Even while we sleep. I see no real reason to turn it off. If I hear a radio check it's a good chance I'll answer it. Northcutt114, WRUU653 and SteveShannon 3 Quote
WRUU653 Posted September 18, 2025 Posted September 18, 2025 1 hour ago, LeoG said: The radio in my house is on all the time. Even while we sleep. I see no real reason to turn it off. If I hear a radio check it's a good chance I'll answer it. My wife would not be happy being woken up by the radio in the night but good on you for responding to people. SteveShannon and Northcutt114 2 Quote
LeoG Posted September 18, 2025 Posted September 18, 2025 2 minutes ago, WRUU653 said: My wife would not be happy being woken up by the radio in the night but good on you for responding to people. At night the volume is pretty low. We are upstairs and the radio is downstairs. She works from home and the radio is right besides her. We have it scanning the local repeaters, my repeater is on area B and a TD-H3 scans the police frequencies. SteveShannon 1 Quote
Northcutt114 Posted September 18, 2025 Posted September 18, 2025 5 hours ago, UncleYoda said: That's his business, nothing wrong with it. And some of the guys who hang out on the radio are blind. I didn't say there was anything wrong with it. SteveShannon 1 Quote
Northcutt114 Posted September 18, 2025 Posted September 18, 2025 2 hours ago, LeoG said: The radio in my house is on all the time. Even while we sleep. I see no real reason to turn it off. If I hear a radio check it's a good chance I'll answer it. And that's certainly your prerogative. I only turn mine on in the evening after dinner. And, like you, I answer every radio check I hear. SteveShannon 1 Quote
