NWHov Posted yesterday at 03:38 PM Report Posted yesterday at 03:38 PM I'm trying to understand the maximum power output for an FCC certified GMRS hand held. This section is pretty clear except for (a) (1) "The transmitter output power of mobile, repeater and base stations must not exceed 50 Watts." It doesn't mention the hand held maximum on the 462/467 MHz main channels. While looking at FCC GMRS certified hand held radios on Amazon, they all seem to have a maximum power output of 5 watts. Anything over 5 watts were advertised as HAM. I am assuming an FCC GMRS certified hand held must not exceed 5 watts on ANY GMRS frequency? Is this correct or is it that no one make a GMRS radio with anything higher than 5 watts? § 95.1767 GMRS transmitting power limits. This section contains transmitting power limits for GMRS stations. The maximum transmitting power depends on which channels are being used and the type of station. (a) 462/467 MHz main channels. The limits in this paragraph apply to stations transmitting on any of the 462 MHz main channels or any of the 467 MHz main channels. Each GMRS transmitter type must be capable of operating within the allowable power range. GMRS licensees are responsible for ensuring that their GMRS stations operate in compliance with these limits. (1) The transmitter output power of mobile, repeater and base stations must not exceed 50 Watts. (2) The transmitter output power of fixed stations must not exceed 15 Watts. (b) 462 MHz interstitial channels. The effective radiated power (ERP) of mobile, hand-held portable and base stations transmitting on the 462 MHz interstitial channels must not exceed 5 Watts. (c) 467 MHz interstitial channels. The effective radiated power (ERP) of hand-held portable units transmitting on the 467 MHz interstitial channels must not exceed 0.5 Watt. Each GMRS transmitter type capable of transmitting on these channels must be designed such that the ERP does not exceed 0.5 Watt. Quote
SteveShannon Posted yesterday at 03:41 PM Report Posted yesterday at 03:41 PM Just now, NWHov said: I'm trying to understand the maximum power output for an FCC certified GMRS hand held. This section is pretty clear except for (a) (1) "The transmitter output power of mobile, repeater and base stations must not exceed 50 Watts." It doesn't mention the hand held maximum on the 462/467 MHz main channels. While looking at FCC GMRS certified hand held radios on Amazon, they all seem to have a maximum power output of 5 watts. Anything over 5 watts were advertised as HAM. I am assuming an FCC GMRS certified hand held must not exceed 5 watts on ANY GMRS frequency? Is this correct or is it that no one make a GMRS radio with anything higher than 5 watts? § 95.1767 GMRS transmitting power limits. This section contains transmitting power limits for GMRS stations. The maximum transmitting power depends on which channels are being used and the type of station. (a) 462/467 MHz main channels. The limits in this paragraph apply to stations transmitting on any of the 462 MHz main channels or any of the 467 MHz main channels. Each GMRS transmitter type must be capable of operating within the allowable power range. GMRS licensees are responsible for ensuring that their GMRS stations operate in compliance with these limits. (1) The transmitter output power of mobile, repeater and base stations must not exceed 50 Watts. (2) The transmitter output power of fixed stations must not exceed 15 Watts. (b) 462 MHz interstitial channels. The effective radiated power (ERP) of mobile, hand-held portable and base stations transmitting on the 462 MHz interstitial channels must not exceed 5 Watts. (c) 467 MHz interstitial channels. The effective radiated power (ERP) of hand-held portable units transmitting on the 467 MHz interstitial channels must not exceed 0.5 Watt. Each GMRS transmitter type capable of transmitting on these channels must be designed such that the ERP does not exceed 0.5 Watt. Unless specifically called out a handheld is regulated the same as a portable or a mobile. Thus, while not practical, you could have a 50 watt handheld on some of the channels. AdmiralCochrane and marcspaz 2 Quote
OffRoaderX Posted yesterday at 03:46 PM Report Posted yesterday at 03:46 PM 7 minutes ago, NWHov said: It doesn't mention the hand held maximum on the 462/467 MHz main channels. While looking at FCC GMRS certified hand held radios on Amazon, they all seem to have a maximum power output of 5 watts As @SteveShannon, certified & anointed H.E.R.D. mentioned, there is no limit specific to handhelds. And if you look hard you will find several 8W units, and if you really apply yourself, you might even find a 10W or two.. But it is important to understand that in most cases, on-average, usually, most of the time and in most situations, most people will not notice any difference between 4 or 5 watts and 8 or 10 watts other than noticing the battery draining much faster. AdmiralCochrane, SteveShannon and marcspaz 2 1 Quote
Lscott Posted yesterday at 03:51 PM Report Posted yesterday at 03:51 PM 2 minutes ago, SteveShannon said: Thus, while not practical, you could have a 50 watt handheld on some of the channels. Which reminds me of the people who want those "High Power" HT's claiming 10 watts plus output. I don't have a link to it but there are some FCC specifications for specific absorption limits based on frequency. Hams are "supposed" to do basic RF exposure calculations above certain power levels at various frequencies per the FCC for RF safety. WRUE951, SteveShannon and AdmiralCochrane 2 1 Quote
marcspaz Posted yesterday at 03:52 PM Report Posted yesterday at 03:52 PM Under FCC Definition, handheld radios are mobile radios. Straight from § 95.303 Definitions. Hand-held portable unit. A physically small mobile station that can be operated while being held in the operator's hand. SteveShannon and WRUE951 1 1 Quote
NWHov Posted yesterday at 04:00 PM Author Report Posted yesterday at 04:00 PM 3 minutes ago, marcspaz said: Under FCC Definition, handheld radios are mobile radios. Straight from § 95.303 Definitions. Hand-held portable unit. A physically small mobile station that can be operated while being held in the operator's hand. Copy that! What sparked my confusion was in section (b) & (c) when talking about the interstitial frequencies it specifically mention "hand-held portable" radios but in section (a) when talking about the main frequencies it didn't say "hand-held portable". marcspaz 1 Quote
SteveShannon Posted yesterday at 04:06 PM Report Posted yesterday at 04:06 PM 4 minutes ago, NWHov said: Copy that! What sparked my confusion was in section (b) & (c) when talking about the interstitial frequencies it specifically mention "hand-held portable" radios but in section (a) when talking about the main frequencies it didn't say "hand-held portable". Correct; they’re only called out separately when regulations apply to them differently. marcspaz and NWHov 2 Quote
NWHov Posted yesterday at 04:07 PM Author Report Posted yesterday at 04:07 PM 17 minutes ago, OffRoaderX said: As @SteveShannon, certified & anointed H.E.R.D. mentioned, there is no limit specific to handhelds. And if you look hard you will find several 8W units, and if you really apply yourself, you might even find a 10W or two.. But it is important to understand that in most cases, on-average, usually, most of the time and in most situations, most people will not notice any difference between 4 or 5 watts and 8 or 10 watts other than noticing the battery draining much faster. So I'm in a hilly area. Will a higher watt radio help my transmissions or is the hill going to do what hill do and block it no matter what kind of power I have? I'm referring to only the UHF GMRS frequencies. Quote
SteveShannon Posted yesterday at 04:12 PM Report Posted yesterday at 04:12 PM 5 minutes ago, NWHov said: So I'm in a hilly area. Will a higher watt radio help my transmissions or is the hill going to do what hill do and block it no matter what kind of power I have? I'm referring to only the UHF GMRS frequencies. The hill is going to do what it does. Where that additional power sometimes can help is if you’re transmitting through vegetation. Vegetation attenuates the signal so more power can make a difference. Hills block the signal and power won’t overcome that. But a high antenna can. In fact the single most effective improvement most people can make is to get their antenna up in the air. The second is to feed it with a cable that doesn’t convert the signal to heat. Power is way down in priority. AdmiralCochrane and NWHov 2 Quote
OffRoaderX Posted yesterday at 04:14 PM Report Posted yesterday at 04:14 PM 6 minutes ago, NWHov said: So I'm in a hilly area. Will a higher watt radio help my transmissions No. Getting a bigger/better antenna and/or getting it higher will help more. AdmiralCochrane, marcspaz, SteveShannon and 1 other 3 1 Quote
LeoG Posted 16 hours ago Report Posted 16 hours ago Not so sure about bigger better antenna doing anything to the immutable impenetrable hill. But getting it above said hill will do the trick. Quote
amaff Posted 14 hours ago Report Posted 14 hours ago 1 hour ago, LeoG said: Not so sure about bigger better antenna doing anything to the immutable impenetrable hill. But getting it above said hill will do the trick. now if the antenna happens to be shaped like a Cat D9, it might do something to the hill... But other than that, no. GreggInFL and marcspaz 2 Quote
GreggInFL Posted 2 hours ago Report Posted 2 hours ago On 7/30/2025 at 11:38 AM, NWHov said: (2) The transmitter output power of fixed stations must not exceed 15 Watts. I'll bite. What is a "fixed station" and how does it differ from a base station? Quote
Lscott Posted 2 hours ago Report Posted 2 hours ago 4 minutes ago, GreggInFL said: I'll bite. What is a "fixed station" and how does it differ from a base station? Remember you asked. https://forums.mygmrs.com/topic/4835-fixed-station-what-does-that-mean-to-fcc/ WRYZ926, WRUU653 and amaff 3 Quote
LeoG Posted 1 hour ago Report Posted 1 hour ago A fixed station transmits and received from another fixed station. It doesn't talk to mobiles or HTs. Usually they have line of site towers so 15 watts is usually more than enough for good communication. Quote
GreggInFL Posted 1 hour ago Report Posted 1 hour ago 1 hour ago, Lscott said: Remember you asked. https://forums.mygmrs.com/topic/4835-fixed-station-what-does-that-mean-to-fcc/ Ouch. Quote
GreggInFL Posted 1 hour ago Report Posted 1 hour ago 35 minutes ago, LeoG said: A fixed station transmits and received from another fixed station. It doesn't talk to mobiles or HTs. Usually they have line of site towers so 15 watts is usually more than enough for good communication. Thanks. You just saved me several hours. Quote
SteveShannon Posted 1 hour ago Report Posted 1 hour ago 7 minutes ago, GreggInFL said: Thanks. You just saved me several hours. Also, Fixed Stations are allowed to transmit on the 467 MHz main channels which are otherwise reserved for transmitting to a repeater. Quote
GreggInFL Posted 1 hour ago Report Posted 1 hour ago And I see it's fixed station to fixed station only -- no HTs, mobiles, base stations or repeaters. Huh. Use case(s)? Quote
UncleYoda Posted 57 minutes ago Report Posted 57 minutes ago The wording from the FCC doesn't specify radio type, just "any station at a fixed location." So HT or mobile (or base of course) can be set up that way, as in external antenna on pole, chimney/roof, or tree. Quote
UncleYoda Posted 55 minutes ago Report Posted 55 minutes ago 9 minutes ago, LeoG said: Simplex? Yep, even though not explicitly stated, that would be the only option. Quote
LeoG Posted 52 minutes ago Report Posted 52 minutes ago 10 minutes ago, GreggInFL said: And I see it's fixed station to fixed station only -- no HTs, mobiles, base stations or repeaters. Huh. Use case(s)? Ever see fixed microwave stations? Same thing. One place communicating with another on a consistent basis would be my best guess. In lieu of telephone lines. Quote
SteveShannon Posted 27 minutes ago Report Posted 27 minutes ago 27 minutes ago, GreggInFL said: And I see it's fixed station to fixed station only -- no HTs, mobiles, base stations or repeaters. Huh. Use case(s)? SCADA, telemetry, dedicated (but not private) communications. And yes, because the 467 main channels are allowed for Fixed Stations, duplex is easily accomplished. One example would be to use radios for a dedicated communication system between a house and a barn. Lift a handset and use it just like a telephone. Quote
GreggInFL Posted 19 minutes ago Report Posted 19 minutes ago 33 minutes ago, LeoG said: Ever see fixed microwave stations? Same thing. One place communicating with another on a consistent basis would be my best guess. In lieu of telephone lines. I assumed that kind of setup (microwave or otherwise) was on a dedicated portion of the spectrum, outside GMRS, but I guess that does not have to be the case. Have I ever mentioned that this is a great forum? SteveShannon 1 Quote
