WRUE951 Posted yesterday at 02:49 AM Report Posted yesterday at 02:49 AM So kicking back at the lake tonight and i catch a conversion with two guys on Ch 16, one pointing out where he off roads in the Kern Canyon.. I can tell they are in Helicopters and I'm assuming two different aircraft. Via the conversations they are returning to Bakersfield after doing aerial surveys somewhere in the Kern Valley.. Not that i really care about these two guys yapping but it got my curiosity going. GMRS is a ground-base communications service, does this mean you or not allowed to use GMRS radios on Aircraft. I guess i'm being lazy, i couid read the rules again,, , but last i did, i certaainly don't recall anything in the rules specifying aircract use.. Quote
OffRoaderX Posted yesterday at 02:52 AM Report Posted yesterday at 02:52 AM There is an aerial acrobatic group that practices out here every Thursday and they use GMRS (or FRS) channel 6, and I've wondered the same thing... But haven't wondered enough to bother looking it up either. WRUE951 and TrikeRadio 2 Quote
SteveShannon Posted yesterday at 03:27 AM Report Posted yesterday at 03:27 AM 95.307…Operation of Personal Radio Service stations in any location outside of those described in the following paragraphs is not authorized by this part. (B)Aboard any vessel or aircraft registered in the United States. With the permission of the captain, while the vessel or aircraft is within or over the United States or its territories, U.S. territorial waters, or upon or over international waters. So, it appears it’s allowed. WRUU653, TrikeRadio and AdmiralCochrane 3 Quote
WRUE951 Posted yesterday at 03:31 AM Author Report Posted yesterday at 03:31 AM 3 minutes ago, SteveShannon said: 95.307…Operation of Personal Radio Service stations in any location outside of those described in the following paragraphs is not authorized by this part. (B)Aboard any vessel or aircraft registered in the United States. With the permission of the captain, while the vessel or aircraft is within or over the United States or its territories, U.S. territorial waters, or upon or over international waters. So, it appears it’s allowed. There you go…. I bet these guys get some good range…. …. &n Quote
marcspaz Posted yesterday at 03:57 AM Report Posted yesterday at 03:57 AM It is perfectly legal to us GMRS radio in aircraft over the US and it's territories. I have talked to a friend of mine while in a private plane. I was mobile in Woodbridge Virginia and they were flying as far away as 47 miles from my location. WRUE951, amaff, OffRoaderX and 1 other 4 Quote
WRYZ926 Posted yesterday at 04:04 AM Report Posted yesterday at 04:04 AM 29 minutes ago, WRUE951 said: There you go…. I bet these guys get some good range…. …. &n Range will be very good in an aircraft. We have a guy that flies a lot and we can talk to him for a long ways on 2m and 70cm. The range of 70cm will be pretty much the same as GMRS. We really get good range on the repeater while he is flying. The repeater antennas are at 900-950 feet on a 1000 foot tower. We are blessed to have access to the local radio station's backup tower. AdmiralCochrane 1 Quote
WRUE951 Posted yesterday at 04:07 AM Author Report Posted yesterday at 04:07 AM 9 minutes ago, marcspaz said: It is perfectly legal to us GMRS radio in aircraft over the US and it's territories. I have talked to a friend of mine while in a private plane. I was mobile in Woodbridge Virginia and they were flying as far away as 47 miles from my location. Thats cool stuff. marcspaz 1 Quote
WRKC935 Posted yesterday at 11:10 AM Report Posted yesterday at 11:10 AM The services that would be limited by FCC rule are the services that have height limits on antenna's. CB would be a good example. A CB antenna per the rules is limited to 50 feet AGL. So you couldn't use CB radios in an aircraft. Commercial radio under Part 90 would be another since at least repeater antenna's are both power and height limited per the issued license. GMRS really has no AGL restriction. The only thing in the rules regarding height is that if a mounting structure (tower) is over 200 feet that it be registered as an obstruction and properly lit within the guidelines of the FAA regulations for it's height. Ham radio is the same way. They aren't really height limited, they just need to follow the 'hazard to navigation' regulations that the FAA has for towers exceeding 200 feet in most area's and whatever regulation is imposed in area's around airports where there are additional restrictions. Quote
nokones Posted yesterday at 11:53 AM Report Posted yesterday at 11:53 AM I'm surprised that FR/GMRS does not have any altitude and power restrictions like Part 90 does. Part 90 restricts, or at one time restricted, the altitude not above 5,280 feet AGL and 10 watts. Quote
nokones Posted yesterday at 11:56 AM Report Posted yesterday at 11:56 AM A few months ago, and on ch. 16, I heard what appeared to be aircraft communicating here in the Phoenix Area talking about should they land at Sedona or Kingman for fuel. WRUE951 1 Quote
Davichko5650 Posted yesterday at 11:57 AM Report Posted yesterday at 11:57 AM 8 hours ago, SteveShannon said: So, it appears it’s allowed. This begs the question, why bother using GMRS for aircraft to aircraft comms when you can just use the already installed VHF radios? When I've flown with my cousin in a group flights, that's how they did it. Other than the fact that other aircraft not having GMRS would then not be privy to your conversations? Quote
SteveShannon Posted yesterday at 12:12 PM Report Posted yesterday at 12:12 PM 12 minutes ago, Davichko5650 said: This begs the question, why bother using GMRS for aircraft to aircraft comms when you can just use the already installed VHF radios? When I've flown with my cousin in a group flights, that's how they did it. Other than the fact that other aircraft not having GMRS would then not be privy to your conversations? I can only speculate, but perhaps they reserve the air band radio for conversations with the tower and leave it tuned to that frequency. Chit chat on GMRS doesn’t affect that. WRUE951 1 Quote
amaff Posted yesterday at 12:51 PM Report Posted yesterday at 12:51 PM 39 minutes ago, SteveShannon said: I can only speculate, but perhaps they reserve the air band radio for conversations with the tower and leave it tuned to that frequency. Chit chat on GMRS doesn’t affect that. Likely this. Aviation stuff is wildly expensive. I can definitely see them having 1 air-band radio, using that for unicom or tower frequencies, and then using GMRS or FRS for air-to-air comms. Slightly different use case, but Civil Air Patrol planes do something similar. Air-band for their aviation work, then air to air and air to ground (for SAR / other mission work) is VHF FM on their designated frequencies. (And can be configured as airborne repeaters, which is pretty rad). SteveShannon and WRYZ926 2 Quote
WRYZ926 Posted yesterday at 01:59 PM Report Posted yesterday at 01:59 PM 1 hour ago, amaff said: Slightly different use case, but Civil Air Patrol planes do something similar. Air-band for their aviation work, then air to air and air to ground (for SAR / other mission work) is VHF FM on their designated frequencies. That's standard procedure for the military. We would always have at least one ground based forward air controller per brigade and usually had one per brigade combat team. And they used the low VHF band, 30 - 70 (88) MHz. IN the big Army units, the FAC's were always Air Force personnel. They always complained about living in the mud and muck with us ground pounders. amaff 1 Quote
WRUE951 Posted 23 hours ago Author Report Posted 23 hours ago 3 hours ago, Davichko5650 said: This begs the question, why bother using GMRS for aircraft to aircraft comms when you can just use the already installed VHF radios? When I've flown with my cousin in a group flights, that's how they did it. Other than the fact that other aircraft not having GMRS would then not be privy to your conversations? well, my first guess, most vhf aircraft communictions, espeicaly commercial, is heavily monitored and recorded... My choice to have a somewhat private conversation with someone would be the lesser of the two.. TrikeRadio 1 Quote
nokones Posted 18 hours ago Report Posted 18 hours ago 7 hours ago, SteveShannon said: I can only speculate, but perhaps they reserve the air band radio for conversations with the tower and leave it tuned to that frequency. Chit chat on GMRS doesn’t affect that. There is a designated Aeronautical channel for private fixed wing aircraft for air-to-air communications. That channel is 122.750 MHz. Private Rotary Wing (Helicopters) have their own air-to-air communications channel. SteveShannon 1 Quote
WSGL775 Posted 10 hours ago Report Posted 10 hours ago 7 hours ago, nokones said: There is a designated Aeronautical channel for private fixed wing aircraft for air-to-air communications. That channel is 122.750 MHz. Private Rotary Wing (Helicopters) have their own air-to-air communications channel. So if I tune my UV-5R to 122.750 and there are helos nearby talking to each other on this frequency, I should be able to hear them? And theoretically speaking, could I talk to them? I wouldn't do this but I'm trying to understand if that's possible? Quote
OffRoaderX Posted 10 hours ago Report Posted 10 hours ago 12 minutes ago, WSGL775 said: if I tune my UV-5R to 122.750 Go ahead and tune your UV-5R to 122.750 and tell us how that works out. amaff 1 Quote
WRUE951 Posted 10 hours ago Author Report Posted 10 hours ago 8 minutes ago, OffRoaderX said: Go ahead and tune your UV-5R to 122.750 and tell us how that works out. He might have the M model. Quote
OffRoaderX Posted 9 hours ago Report Posted 9 hours ago 37 minutes ago, WRUE951 said: He might have the M model. But that's not what he said he has. Quote
TrikeRadio Posted 7 hours ago Report Posted 7 hours ago On 8/12/2025 at 8:31 PM, WRUE951 said: There you go…. I bet these guys get some good range…. …. &n I just wonder how well that cheap magmount antenna sticks to the airplane. Quote
TrikeRadio Posted 7 hours ago Report Posted 7 hours ago 15 hours ago, WRUE951 said: well, my first guess, most vhf aircraft communictions, espeicaly commercial, is heavily monitored and recorded... My choice to have a somewhat private conversation with someone would be the lesser of the two.. Uh... if you are transmitting on GMRS at the altitudes that planes fly... I would say you are not going to get a "somewhat private conversation"... every GMRS user 100 miles around is going to hear you. Quote
nokones Posted 2 hours ago Report Posted 2 hours ago 7 hours ago, WSGL775 said: So if I tune my UV-5R to 122.750 and there are helos nearby talking to each other on this frequency, I should be able to hear them? And theoretically speaking, could I talk to them? I wouldn't do this but I'm trying to understand if that's possible? You will not hear the helicopters. 122.750 MHz is designated for fixed wing aircraft, that means airplanes that have stationary wing(s). If a helicopter (rotary wing) meaning having a wing that rotates and spins around needs to communicate with an airplane then you may hear a helicopter. Aeronautical freqs are amplitude modulation freqs., so I doubt that your Barfwanger Pandaland radio will emit Amplitude Modulation since they are frequency modulation radio devices. Quote
WRYZ926 Posted 1 hour ago Report Posted 1 hour ago You can listen to the air band with a UV-5R but it won't sound very good since the radio doesn't have an AM receiver. And FM transmitters won't transmit on AM. Get a scanner if you really want to listen to air band frequencies. The stall speed for planes is around 100-115 MPH. Smaller/lighter planes have a lower stall speed compared to commercial jets. I wonder what speeds a magnet mount will hold up to. They hold fine up to 80 MPH on most vehicles. Plus the fact that most aircraft bodies are made from aluminum or other light weight materials so a magnet mount won't work. SteveShannon 1 Quote
WRUE951 Posted 53 minutes ago Author Report Posted 53 minutes ago 6 hours ago, TrikeRadio said: Uh... if you are transmitting on GMRS at the altitudes that planes fly... I would say you are not going to get a "somewhat private conversation"... every GMRS user 100 miles around is going to hear you. How many of those GMRS listeners are gong to record and log your flight path. My point is, the FAA records and retains and the less of any of that bread crumb the less headaches one might endure sometime down the road. The lesser of two evils is what im pointing out Quote
