I usually avoid these sort of products because in my opinion Cheap Chinese Radios are usually a Low Parts Count hot mess with crappy receiver performance.
For some stupid reason this caught my eye. I am sure it will be disappointing. Should I buy one? Has anyone bought one opened it up and found the manufacturer went the extra mile in RX design, or should I let the fact that it has an FM 88-108 receiver built in confirm my misgivings?
Well here it is, probably not FCC certified . But it is kind of cool.
I am verklempt,  talk amongst yourselves...
https://www.verotelecom.com/VERO-VR-N7500-50W-Dual-Band-Mobile-Radio-With-APP-Programming-p541441.html
Doing some research, it doesn't have any FCC type acceptance, including Part 15. Shouldn't be allowed to be sold here in the US, but they can be imported solely for amateur radio use and not resold. The only Vero radio I could find certification on was the VR-6600PRO, which is only certified in China for 430-440 MHz on the UHF side. I'm sure transmit is wide open, since there's people using these on 440-450.
Given the size and feature set of that radio, I would be surprised if it weren't an AT1846S chip under the hood, like the BTech UV-25X4.
It also requires that one have a 'smart phone' they don't mind being dedicated to act as the control panel for the radio...
For $200, I'd like to at least have a basic control head, whether it's a detachable head that mounts to the radio or a handheld control head. It's a brick without a working software environment.
  • 1 month later...
I just got two of the retevis rt99's which appear to be the same thing.  About 150 each off ebay.  Pretty easy to program, pairs well.  Not sure how to gauge the performance as this is my second radio.  Other's a baofeng hand held.  I like the idea of no programming cables, etc.  I'm using them with the midland mobile 6db antennas at the moment.  Still testing and learning.
  • 3 months later...
Got it and love it...
I use a dedicated 8" tablet to control the radio and it works great.
You can use the wired mic or remove the mic all together and use a BT headset and PTT button
The app works like the walkie-talkie Zello as a stand alone walkie-talkie or to link your phone to a repeater.
Frequencies are stored in banks of 16 channels each with the choice to monitor 2 frequencies or scan all 16
The APRS function shows where other hams are on the map.
Wife had ordered one. I told her cancel that order. I couldn't find any information on how to scan a band unless the frequency was in memory. Can you do that even?
