Understanding SWR & How Antennas Work
Hey folks... I have been seeing a lot of antenna related posts lately. Some info I have read lead me to create this post.  I want to try to help people understand design types and how antenna SWR and Gain are impacted.  I am not going to get too technical, because I don't want new people to feel lost or leave with more questions than answers.
As an FYI, while the concepts apply to all antenna types, I will be focusing on vertical antennas, such as what we use on our vehicles.
First, lets discuss basic antenna standards and why antenna length matters.  The best way to describe how basic antenna length is relevant, is by comparing an antenna to a speaker.  Pretty much everyone understands that a speaker vibrates to make noise. We also understand that small speakers do a better job at making very high frequency sounds (tweeters) and really big speakers are better for making very low frequency sounds (like a sub-woofer).  Antennas are the same way.  The lower in frequency, the bigger (or longer) the antenna.
The reason for this is because, like a speaker, antennas resonate (or vibrate) the best at one very specific frequency.  As you go higher or lower in frequency, you are moving away from the antennas resonant frequency  This becomes important for several reasons.  One is because the closer the antenna's resonate frequency is to the frequency you want to transmit on or receive on, the more range and fidelity you get.  Another reason is because the energy that gets sent to the antenna must go somewhere.  If the antenna is not at the correct length to vibrate at the desired frequency, that energy gets wasted by being "reflected" back into transmitters, as well as desensitizing receivers.
Any energy that gets reflected back into the radio is typically identified by the Standing Wave Ratio (SWR) or the ratio of transmitted (forward) energy vs. reflected (reverse) energy.  Here is why we watch SWR.  If your transmitter is putting out 50 watts, and your meter says you have an SWR of 1.7:1, that means only 45 watts of energy leaves the antenna and 5 watts goes back into the transmitter.
A high SWR not only causes power loss, but it also generates heat as well as applying reverse electrical energy to the parts.  If enough of a percentage gets reflected back into the transmitter, it breaks.  It is very well documented that with the current technology we have, the threshold is an SWR of about 3.0:1.
So, now that we understand, on a very basic level, why antennas need to be a specific length to work the best, and also have a basic understanding of what SWR is, lets discuss antenna design.
So, what's the standard?  An isotropic antenna.  This is a theoretical antenna that radiates equally in all directions with the same intensity.  Basically, a perfect sphere.  The antenna is said to have a power gain of 1 in the spherical space all around it and has an efficiency of 100%. The concept of an isotropic antenna is often used as a reference antenna for the antenna gain.
What is antenna gain?  Glad you asked!  There is a lot of science behind that... so I am not going to bore you with science.  Instead, lets talk about food! Everyone loves food and its pretty easy to understand.
So, the concept of gain is this... you only have 100% of your energy available.  There is no such thing as an antenna magically giving you more power.  You know the perfect sphere radiation pattern mentioned earlier... well in the real world, the closet we have ever come to creating that, actually looks more like a doughnut.  Imagine a perfect doughnut.
Sounds yummy right?  Well, you only have 100% of the doughnut.  What do you do if you want the doughnut to be wider, say... to fill a box better from side to side?  I mean, its a whole doughnut.  Easy... you squish it from the top and bottom.  Then the doughnut gets shorter from top to bottom, but the food has to go somewhere.  So, it spreads out wider or "gains" width in sacrifice of height.  Well the more you squeeze from the top and bottom, the wider it gets, but loses height until the doughnut is perfectly flat and the 100% of the doughnut as been spread as far as possible.
The squished doughnut thing makes sense, right?  Antennas that have "gain" do the same thing.  They squish the radio energy doughnut, forcing it to be wider to cover more distance, but at the sacrifice of signal height.  This means that while you can transmit and receive further side to side, you lose elevation.
Lets imagine you are at the bottom of a hill and your buddy is at the top.  If you don't squish the doughnut, he can hear you because the doughnut is at its full height.  But if you squish the doughnut, people further away at your level will now hear you, but your buddy who is very close at the top of the hill will not.
So, gain has a trade-off.  If you live in a hilly or mountainous area, you may want to avoid high gain antennas, so as your elevation changes, you are less likely to lose touch with someone.  Compare that to being on the water, in flat(ish) desert or talking aircraft to aircraft, you may want a very high gain antenna, because there will be no significant elevation differences.
Now, from here, we could talk about the benefits of stacked phase element antennas, takeoff angles and a bunch of other stuff.  However, unless you have a more advanced understanding of antenna propagation and design, and plan on getting into some high-tech stuff, it will likely cause more confusion.  Not to mention, for what we are doing... those items are almost not relevant when it comes to helping you pick the correct antenna for your application.
So, let talk about how gain and SWR can really be confusing and how numbers can trick you into making a mistake.
Remember when we discussed antennas needing to be a specific length to resonate at the desired frequency?  Well, many high gain designs cause the antenna to properly resonate at only small segments of the frequency spectrum. Basically, what these means is (as an example) instead of being resonant and having good SWR across 100 megahertz, the antenna design may cause the antenna to only be resonant and have proper SWR at 10 small groups of frequencies inside that same 100 megahertz range.
Watch the two videos linked below for a better understanding.  In the first video, I have a Diamond NR7900A mobile antenna.  It has 3.7db gain on VHF in the 140MHz-160MHz range, and 6.4db gain on UHF in the range of about 440MHz-500MHz.
You will see that while measuring the SWR (or the antenna and cable resonance) you will see that in the VHF segment, the SWR varies somewhat quickly, but only has a single swing, from high to low and back to high inside of about 20MHz.  When I switch to UHF and test the higher gain portion of the antenna, you will see the the SWR bounce up and down a few times as I sweep about 30MHz.
This shows that the higher the gain, the more the antenna design may actually make it so the antenna is not usable on your desired frequency.  Of course this all varies by brand and model, but the principle is still universally true.
https://www.youtube.com/watch?v=Rh6w46VM_Ng
Now, in this second video, we are looking at a UHF 1/4 wave antenna.  This antenna is considered to have a gain factor of 1, and any number times 1 equals itself... so effectively, no gain.  You can see that we sweep over 50MHz and while the SWR wavers a little, the SWR is stable compared to the high gain antenna and 100% safely usable through the whole spectrum, never going over 1.4:1 from 440MHz to 470MHz.  Again, reinforcing the idea that the closer the antenna is to the desired resonant frequency and the less you squish the doughnut, the broader the usable frequency range will be, the broader the geographical coverage will be, the less risk of losing power due to poor SWR, and less risk of damaging your transmitter.
https://www.youtube.com/watch?v=P5GiPLzVzbg
So, to wrap this up, I want to discuss antenna tuning.  Some antennas may need to be cut to the proper length to resonate on the desired frequencies.  This is typically done with antennas that either have no loading coils (1/4, 5/8, 1/2, 7/8 wave length antennas for example) as well as some bottom loaded antennas.
A bottom loaded antenna is an antenna that has a whip that is not the correct physical length to be resonant on a desired frequency, but the coil of wire on the bottom makes the antenna electrically the correct length.  General speaking, for VHF and UHF, I recommend staying away from antennas with coils in them if they have been physically shortened for looks/clearance reasons.  These antenna work, but are not very good performers.
That said, there are some antennas that are "pre-tuned" at the factory to perform correctly in the indicated frequency range.  These are typically gain antennas that have a collection of coils and capacitors on the antenna to help create the phasing and properly stack the elements.  These are referred to as LC networked antennas.
If you have an antenna that has stacked phasing and/or LC networks and you can't get a good SWR... unless the manufacturer provides directions on how to properly do so, do NOT trim the antenna to try to achieve the proper resonance, as you will only damage the antenna.  The coils, capacitors and whip elements are precisely cut to work together.  If you do not get a good SWR, either you need to pick a new location to install the antenna, the antenna is not properly grounded or the antenna is damage and should be replaced.
If you do trim a stacked phasing and/or LC network antenna, in most occasions, the antenna never gets to the proper length regardless of how much you cut the whip and you end up tossing the antenna in the trash.  If you get it tuned to a target frequency, it's usable bandwidth will be so small that the antenna will not have any real value.  I have seen some people try to tune high-gain antennas, get them tuned to about 1.7:1 or even 1.9:1 and as soon as they tune 10KHz in one direction or another the SWR skyrockets.
I hope this helps with some of the antenna questions.
It seems many of you who have the experience are also HAM. Are you guys on DMR, that's an easy way to get some round table discussion in a Tac channel, being we are not all close together. I'd be interested in talking with a few of you guys.
I'm a computer scientist and communications engineer. That last thing I want to do is more digital when I'm out of work. I have a WinLink account that I have never used. No FT8, no FLDIGI, no DMR. I love warm analog static. LoL
Besides, face to face to enjoy company... not to talk shop. Familiar subjects just helps get the convos started.
I'm a computer scientist and communications engineer. That last think I want to do is more digital when I'm out of work. I have a WinLink account that I have never used. No FT8, no FLDIGI, no DMR. I love warm analog static. LoL
Fair enough. I'm an engineer as well, spending my days in front of a CAD station. I must say, DMR does have its benefits outside of analog radio, but being that its too related to your work, it might be annoying. For me it's enough of a step sideways from my work, its a fun challenge (not really a challenge).
I agree F2F is preferred, and I don't think you and I are too far apart, however, I'm currently not traveling, for various reasons.
Yep.. I used to go to Thompson Raceway Park every year for a drag race called the Buckeye Brawl.  Takes about 5.5-6.5 hours to get there depending on traffic and weather.  Nothing like driving a 10" pro-street race car 800 miles round trip.
I know the pain. I've driven my RX7 to Poughkeepsie, NY without working cruise control for the OCC car meet (8hrs).
Back on topic  :blink:
There are a couple of techniques.  I personally tune for the center frequency of the band I plan on using.  To be sure you are centered, you check the highest frequency you will use and the lowest frequency you will use.  If the SWR is the same on both, you are good.
If the SWR on the high frequency is higher than on the low frequency, your antenna is too long.  If the SWR on the low frequency is higher than on the high frequency, your antenna is too short.
The biggest problems you will run into with GMRS antenna tuning is, unless you have an antenna analyzer, that method is tough to use since you can't tune to the center frequency.  Also, in centimeter radio, if you trim the antenna as little as 1 millimeter, you can drastically change the SWR.  So, its a slow process and easy to mess up an antenna.
I was lead to believe that I didn't have to worry about "Tuning" these new antennas and therefore purchased the 6db gain antenna for both off road and freeway driving.  The off roading is usually mountainous (east coast).  The doughnut explanation helped me see the effect and describe the different size antenna, thanks.
I didn't (don't) have a frequency in mind that I think I'll use often so I have always wanted to get the best out of all channels.  Being new to the GMRS stuff (ole CB'er) I was thinking my best buy (using) would both FRS & GMRS ensure greater useage of the radio.
So the question is, "Should I look at tuning the FRS side frequencies over the GMRS if I find I use the FRS side more?"
...and the answer is:  Don't worry about it.  If you'll notice, the old FRS frequencies are in between the old GMRS frequencies - every-other-one. [they are technically one and the same now anyway. Depending on whether or not you are licensed determines how much power you are allowed to run, and how much bandwidth.]
If anything, you should adjust for best SWR on the 462.6MHz (simplex) frequencies, but most antennas have a wide enough bandwidth to just set them for great response across the whole band, with the best peak at 465.1MHz, but still great response on 462.6 (1-7, 15-22) and 467.6 (8-14 [low-power channels], GMRS 15R-22R Repeater Inputs).
You can NOT measure antenna SWR at the bottom of the feedline, it MUST be measured at the antenna.
Huh? An SWR reading is the measurement of 'standing waves' along the transmission line. How can you get a true SWR reading with no transmission line?
You should NOT be tuning an antenna for the best SWR, but rather for optimum resonance on a specific/target frequency. Then you balance the entire load to reduce the standing waves, reduce reflected power and therefore improve forward radiated energy for maximum efficiency and maximum power output. The load includes the antenna, balun, transmission lines, your grounding system (for home/base stations), etc.
This is why you see many high end amateur radio antennas and many commercial antennas advertised SWR ratings while connected to 100' or 200' of X type of coax. Sometimes they even say a 4:1 balun or 9:1 balun, and antenna tuner are required to balance the system.
Plus, if you have a good analyzer, you should be able to read the antenna's impact on the SWR separately from the other components with ease.
Thanks marc, I really enjoyed reading your explanation; I was able to visualize it.  And I also appreciate the additional clarification points.
I'm a retired computer programmer and network guy, also pc support.  Not an engineer, more a mechanic.  More breadth and less depth, so analogies like yours are information I always remember; the finer points not so much.
WOW, I never realized that!  Thank you!
Everything I read as a newbie and several folks explained to be was, FRS/GMRS did not require adjustment for SWR and was fine, right out of the box.
I guess that isn't true.
