Extreme Posted March 2, 2021 Report Posted March 2, 2021 Downloaded and "installed" the latest version of Chirp to program a BF-F8HP and get nothing but a blank when I open the application (chirpw). FILE Edit View Radio Help There is nothing to choose like Program, etc to check/set Com Port. yes the cable is connected on Com 8.No Menu, no Setup.. zero. Quote
0 MacJack Posted March 2, 2021 Report Posted March 2, 2021 My CHIRP new release on a Mac working... It is empty screen on first startup. You have you go to FILE open a config or go to Radio and download from radio after connecting radio to computer. You will see it is working. The screen only shows what you are asking the software to do. So empty screen waiting for your request. Jack Quote
0 Extreme Posted March 2, 2021 Author Report Posted March 2, 2021 Download from radio does nothing. I can open a file but no selections for Port, etc. and get no activity. Quote
0 MacJack Posted March 2, 2021 Report Posted March 2, 2021 OK that is a port issue for your USB... I'm not a current MS Windows guy, but in the pass you have to see if your USB port is active... I also notice that my new download of CHIRP has to be where near or in same directory as app and config files where the USB port setting files are. Jack Edit... I notice my updated CHIRPS goes to download and not in the directory I use for the app.Download from radio does nothing. I can open a file but no selections for Port, etc. and get no activity. AdmiralCochrane 1 Quote
0 jk06 Posted March 3, 2021 Report Posted March 3, 2021 I am unable to use chip on my Btech GMRS v1 using Mac with Big Sur OS. However, I am able to use chirp using a Baofeng red FTDI usb cable on my BR-F8HP. Not sure if anyone reading this had a layman fix for this. Quote
0 jc1240 Posted March 6, 2021 Report Posted March 6, 2021 I'm not sure if this is all-inclusive, but in general you will need to give Chirp the rights to access USB and the disk/directories where you store the code plugs. https://chirp.danplanet.com/projects/chirp/wiki/MacOS_Tips Also, have you used the cable with this radio in the past? Not all are equal and some found on sites like Amazon are fakes. This one is known to work with Baofeng: https://www.amazon.com/dp/B00HUB0ONK Quote
0 ScConstable Posted March 19, 2021 Report Posted March 19, 2021 I have a Baofeng BF 888S which I have programmed on the 400Mhz band. There is an association that uses the HYT TC 518. The default PL is 67 so I programmed that into my BF. The HYT is able to transmit to the BF, but the BF dosen't transmit to the HYT. What could be the problem? I used CHRIP to program the BF. Quote
0 wayoverthere Posted March 20, 2021 Report Posted March 20, 2021 I have a Baofeng BF 888S which I have programmed on the 400Mhz band. There is an association that uses the HYT TC 518. The default PL is 67 so I programmed that into my BF. The HYT is able to transmit to the BF, but the BF dosen't transmit to the HYT. What could be the problem? I used CHRIP to program the BF.It sounds like you may have programmed the receive tone but not the transmit tone. Quote
0 ScConstable Posted March 20, 2021 Report Posted March 20, 2021 That is a possibility but I don't know what the transmit code would be. I have the tone mode as tone, the tone sql defaults to 88.5, the DTCS code and the Rx DTCS code default to 23, the DTCS pol is NN, mode is FM and power is high. I tried to set the Tone sql to 67.0 but it reverted back to the default of 88.5. I am at a lost. So if anyone could help it would be much appreciated. The frequency that I am using on this is 464.5500. The full nomenclature for the Hytera is TC-518V OBR. Thank you. Quote
0 wayoverthere Posted March 21, 2021 Report Posted March 21, 2021 did some poking at chirp tonight on my netbook (linux), but none of the images on that one have tones set, so i'm looking at the possibilities from chirp's memory editor columns page. (great reference to keep around; https://chirp.danplanet.com/projects/chirp/wiki/MemoryEditorColumns ). from what you describe, the "tone mode" column setting will have it transmit a tone, but not expect one on receive (which means it hears everything, whether or not the incoming signal has a tone); this is why you can hear the other radio, and also why chirp isn't wanting to change the Tsql column (because it isn't actually using that setting, or either of the DCS settings). if you want to set the tone for both tx and rx, you want the tone mode set to "TSQL", and set the correct tone on the TSQL column. Now onto the tone numbers themselves...that the other radio isn't not hearing you points to your transmit tone isn't the correct one...while 67 may be the default tone for the Hytera, it may not be the PL the association is using. it sounds like you're mostly much on the right track with the settings, but getting the right tone is a critical one for the radios to get along. Quote
0 ScConstable Posted March 21, 2021 Report Posted March 21, 2021 Thank you, but I have tried every combination in Chirp but nothing worked. Now I will have to quit playing as the HYT is out of juice and I don't have a charger. But thank you for your help. wayoverthere 1 Quote
0 wayoverthere Posted March 21, 2021 Report Posted March 21, 2021 Glad to try at least. I know chirp can be a little frustrating, especially when it's trying to outthink you Quote
0 lafa10 Posted March 26, 2021 Report Posted March 26, 2021 I tried CHIRP on my Mac this evening. Totally screwy and I can't download the update now that I'm running 11.2.3 Quote
Extreme
12 answers to this question
