I am new to GMRS. I recently purchased two Wouxun KG-905G HT radios (buytwowayradios.com), replacing the stock antennas with the Nagoya NA-771G. I reside in a suburban subdivision. For my initial test (running 5w on Ch 5), I took one radio to a 3rd floor unit in a building 0.9 miles away, per Google Maps (a bit shorter as the crow flies). I expected a clear signal at that distance, but was not the case. My TX’s were not received by the 3rd floor unit. Their TX’s were hit or miss. Some came through (with static), others did not.
The only impediment I can really think of is a line of those massive overhead electrical power lines that cut across the two locations.
Would that be enough to knock out a signal between these relatively short distance locations? Any suggestions to improve communications?
fillmoreranger
Hi…
Obviously, a disappointment starting out.
Thanks in advance.
Link to comment
Share on other sites
15 answers to this question
