Guest richard.leach Posted February 16, 2022 Posted February 16, 2022 Just a heads up: I have tried a few times to register for an account here. My license is good, and the form recognizes it. But when I click the final button, it doesn't appear to accept it. Quote
gortex2 Posted February 16, 2022 Posted February 16, 2022 How long have you waited. The FCC imports weekly or daily but can't remember which. IF you jsut got the license its proabbly not here yet. Quote
wayoverthere Posted February 16, 2022 Posted February 16, 2022 Afaik, daily (unless it's changed), though there's usually a day or two delay with fcc releasing the updates, and the scripts running to import it. If it goes beyond that, it may be getting hung up on a bad bit of data (has happened before). Quote
WyoJoe Posted February 16, 2022 Posted February 16, 2022 Unless there's a problem with the data from the FCC, the website updates will normally happen in three days or less. If you try to register before the update has taken effect, I believe it gives an error that the call sign is not valid. In this case, it sounds like the OP's call sign was recognized, so there may be something else happening there. Unfortunately, I don't have any idea what would be causing the error, as I didn't have any trouble when I registered. Quote
SteveShannon Posted February 16, 2022 Posted February 16, 2022 @rdunajewski is the one person who can help diagnose this. I'm not sure whether it's best to tag him, like I just did, or to report the content, which would get his attention, but could have a negative connotation. Good luck, Richard Leach! Quote
Guest Rich Leach Posted February 17, 2022 Posted February 17, 2022 I'm going to stop trying to join. I'm afraid some AI will think I'm a bot or something. I really would appreciate someone letting me know if my requests are getting through, or if there is a problem with my computer that is causing it to fail. [hidden by moderator], WRPJ885 Quote
rdunajewski Posted February 17, 2022 Posted February 17, 2022 23 minutes ago, Guest Rich Leach said: I'm going to stop trying to join. I'm afraid some AI will think I'm a bot or something. I really would appreciate someone letting me know if my requests are getting through, or if there is a problem with my computer that is causing it to fail. richard.leach@gmail.com, WRPJ885 Hi Rich, I had no trouble creating a test account with your info. Could you please reach out to me via the Contact Us form with the following information (since the forum isn't private): - The email address you tried to use - The username you tried to use - Any error messages you may have seen https://mygmrs.com/contact Thanks! Quote
Guest Rich Leach Posted February 17, 2022 Posted February 17, 2022 I see someone is trying to get me set up. If you are reading this, the email verification link failed. I did get the email, obviously. The username said "test12345". Thanks for working it, whoever you are. Quote
rdunajewski Posted February 17, 2022 Posted February 17, 2022 9 minutes ago, Guest Rich Leach said: I see someone is trying to get me set up. If you are reading this, the email verification link failed. I did get the email, obviously. The username said "test12345". Thanks for working it, whoever you are. I created it and deleted it just to see if there was an obvious error, so by the time you went to verify the email, the test account was deleted. If you can't get through the issue I'll create an account with your callsign as the username for now. wayoverthere 1 Quote
