I'm trying out this antenna on my Jeep and when checking the SWR on it, it's 2.4 to 1 across the GMRS UHF range. Obviously you can't 'trim' this antenna so does anyone have experience with this antenna? Is that a typical SWR for these? I've also tried different antenna cables and the reading stays the same. I'm wondering if I should ask Midland for a replacement.
EDIT: I also have the Midland 6db gain antenna and the SWR is fine on that one. About 1.7 on 462.xxx and 1.4 on 467.xxx
moonpup
6 answers to this question
