Midland MXT275 keeps receiving static bursts…
sycboi
I apologize ahead of time. I am not overly knowledgeable when it comes to a lot of things concerning GMRS radio. I keep reading and trying to educate myself though…
I have a Midland MXT275 hard wired into my Jeep. I have the base unit, hand mic and a Midland external speaker all set to work at the same time. Topless Jeeps going down the highway make it difficult to hear things. I run the Midland Ghost Antenna on the front right of my cowl panel at the base of the windshield. I have a pair of Midland GXT1000VP4 handhelds that I let the other Jeeps in the convoy use so we can communicate. All are set to channel 22 and CTCSS privacy code 22…
The MXT275 works great at transmitting clear messages and are received by the handhelds with no complaints of static. The handhelds are static free and have zero interference. They are working beautifully for our intended purpose…
The issue is when I am not transmitting and the MXT275 is sitting idle. Every few seconds I get an RX transmission burst of static for about a second. It keeps happening as long as the radio is turned on. It doesn’t matter if I am sitting in my driveway or 100 miles from home in the hills. It doesn’t matter if the handhelds are turned on or off. I can’t figure out if it’s a setting I have configured wrong or what…
Has anyone else encountered a similar issue?
Thank you for any assistance someone may provide!
-Michael, WRML814
9 answers to this question
It happens no matter if the engine is running or not. It happens no matter the channel. It receives a static burst every few seconds…
What I haven’t tried is turning the privacy code off. I should try that after work today, just to see…
I highly doubt the code (which is NOT private, BTW) has anything to do with it..
My first guess is that something in the Jeep is causing the noise - the only way to know for sure is to take the radio out of the jeep and try it in another vehicle or in the house (if you have a power supply) - if the same thing happens, then send it back.
When you have your handheld radios in the jeep, do they get any of the static bursts?
I just use the PCs to keep my communications clear of other peoples banter. I know they can hear us though…
Not at all. Clear as can be expected…
I am afraid this may be my only alternative. Keep trying different configurations to see what happens in each situation…
I was hoping maybe I just had something set wrong and could hit a couple buttons to correct it…
If this happens on all channel setting I would suspect what ever makes the the "squelch setting level" is bad in the unit.  Try changing the squelch setting and see how the unit reacts.  With that information call Midland and ask to sent the unit back for a checkout.
I am a newbie and just throwing this out there.  I too get pops of static in certain locations but it seems to be transmissions/burst of telecommunications stuff in different locations but unlike your situation it only happens in different areas.
In another thread, I facetiously said that a similar problem with Midlands was: "a feature and not a bug!"
But hearing these complaints over and over again, I am starting to believe in the efficacy of my own advice!
While they may have the "advantage" of being easy for Newbies to use "right out of the box;" that feature is worthless if the hardware is overpriced junk!
That being said, I much prefer discounted junk! 🤣
-Michael, WRML814
Is the radio wired directly to the battery? or through the accessories on the ignition?   i would try isolating the power from the electric on the JEEP.?
It’s actually hardwired through the fuse box on a dedicated circuit. Sounds like going straight to the battery may be the first attempt at isolating the issue…
