Because its a topic that comes up weekly thought I'd share of picture of Midlands Jeep mount from the show last weekend. Jeep runs a MTX575. Per the folks at the show the antenna location is the best they have found on the jeep. While I still hate the Ghost antenna for the use case they explained its fine. (Use case is following others on the trail).
Yes your mileage may vary but wanted to share. Lots of folks on some of the FRS/GMRS channels out there last weekend, but mostly CH1-5 on my Midland was busy. The local GMRS repeater was useless as there are 2 old hams who use it non stop most of the day. Not just last weekend, but most weekends I'm there. Is what it is.
The Ghost is perfectly fine for what it is -- the vehicular equivalent of a rubber ducky courtesy antenna designed for short-range simplex and ease of handling.
That was ideal for my use cases, but the radio shop nearby had 3dB Tram antennas, so that's what I have instead of a Ghost.
Well, I have owned 13 Jeeps since 1976, and I am going to agree with Midland. That location givesa decent ground plane, especially if you have grounding strap on the hood to body. For what they were using the ghost for it would work just fine, for my uses I would have their taller 6 db antenna there.
That's what I figured.
On my DD Explorer, I have the 1/4 wave whip and it seems to perform quite well.  It actually doesn't extend as high as the OEM top-mount AM/FM/GPS antenna.
I have just enough room to ensure 12"-12" GP on the top with the full-length sunroof.
Even when standing outside the vehicle, the 1/4 wave outperforms my N 771G rubber duck.
On 9/10/2022 at 1:48 PM, WRUC860 said:
Question for the OP and others:
Does the "Ghost" perform better than a Laird-Tram-Midland etc 1/4 wave NMO mount?  Being only 6" tall, seems doable in your need.
Just asking.
I see the antenna now that I blew up the picture.  Thanks!
I'm actually thinking about getting an A pillar light bar for my Gladiator so i can fab up a mount for the ghost antenna on top of it where the lightbar would/ will mount. I would be able to hide the coax under the light bar mount. I have never bren too crazy about a lightbar above the windshield but i would do it to mount my antenna at or above the roofline IF itv would improve the range on my Midland. I would prob run the 28" (or so) Midland nmo antenna when traveling and change to the ghost antenna if in wheeling in an area with a lot of brush. Thoughts on this?  Would this be a waste of time?  What if i included a 7" or so disk of sheet metal at the base of the nmo mount for a ground plane?...
The light bar may generate a tremendous amount of RF from the LEDs rendering your installation worthless. This will be particularly true with the ones from offshore that are not FCC certified'
