Anyone know any information about the "LA Echo 1 System" repeater on 725 in Los Angeles?
It used to be populated by a "crazies" repeater, which was being jammed, the last time I checked.
Now the frequency is clear and this recorded announcement with the time comes on frequently.
I don't see any listing here for it and a Morse Code ID just came on, so I'll pay attention to it next time.
I thought I heard "WWCC0000,C" but no valid GMRS call has all zeros, does it (nor 4 digits either)?
Sounds like they synchronized the clock.
Is that Radioddity gs-5b a new release?
Looks like an interesting HT: bluetooth programming, pc and Smartphone, too.
Yes, I noticed the time is now correct too...
Picked up the GS-5b on amazon on a flash deal as a SHTF HT back in December- the bluetooth connect to a smart phone is quick and easy to make an adjustment to the radio programming away from a computer. I also picked up a set of signal sticks for my three radios- for a good cause too!
19 hours ago, MichaelLAX said:
There's crazies in Salt Lake City, too?
Not sure if you are asking me.  I lived in SoCal in the early 90s and used to go to the TRW swap-meet and breakfast with the 435ers...  It was cheap entertainment... lol
OK, Thank you!
The LA Echo 1 System Time ID is now 45 seconds ahead of real time.
Must need a better calibration crystal!
2 hours ago, WRQC299 said:
yes, they are dbi gain antennas, improved performance from the stock antennas they ship with.?
Any antennas can have its gain expressed in dBi. dBi is simply a unit. Perhaps you meant they have a gain of 2.1 dBi or something like that?
4 hours ago, MichaelLAX said:
I looked at the links but I am still confused as to what signal sticks do?
Antennas?
Maybe this will help:
The origin of the Super-Elastic Signal Stick
Approximately 15 years ago I made my first antenna following this general design.  These are based on the traditional “1/4 wave piano wire antenna” design; it turns out that 1/4 wave on 2m is roughly 3/4 wave on 70cm, and a 3/4 wave antenna performs roughly the same as a 1/4 wave antenna, which makes these work equally well on both 70cm and 2m.
These antennas were originally made with stainless steel wire as a fundraiser for a ham radio youth group (the one I met my wife in, actually). Over the years we’ve improved the design dramatically, most notably by changing to use nitinol superelastic wire. When the youth group shut down I was assistant advisor to it and due to continued demand I took over the project and have continued selling them as a fundraiser for HamStudy.org, a site which I am also connected with.”
Antennas?
Yep, another longer antenna for handhelds, these are very flexible and durable...I have one that gets shoved in the backpack when I travel.
13 minutes ago, MichaelLAX said:
How do they compare to the traditional 771-type models?
Probably similar gain, but you can take a Signal Stick and wind it into a loop and put it in your pocket, or use two of them to make a dipole, or multiple ones of different lengths to make a fan dipole. They’re part of a system.
The most important thing they do is make Ham Study available for people who want to study.
Little longer, little thinner, more durable. I have a Nagoya that has a little bend in it from the radio falling over and I didn't notice for a couple days. The signal stick gets folded into a u in my backpack and doesn't seem to care. Also available in colors, and the more recent ones are glow in the dark tip on all of them.
  • 6 months later...
  • 4 weeks later...
On 7/21/2023 at 4:49 PM, WRFP399 said:
I am over in Long Beach for the day. I can trigger it with a TYT MV-UV390 transmitting on 467.725 with CTS of 100.0hz.
That is the freq pair for the "Sheep 725" repeater located on Mt. Lowe near Mt. Disappointment/Mt. Wilson.
